Ford transit 2001.. put ac on after ac service.. no prob works well for 20min then goes warm..stand vehicle for 20min start up again its cold for 20min..no loss of refridgent... any ideas
    Champion:
  • 233 Answers
Moisture or floating restriction, replace the metering device, and drier, evacutate and recharge.
Posted on Jul 31, 2009
Can you tell me my 2001 focus 1.8 keeps making a loud click when i looked in the engine the AC compressor stops and then clicks and starts spinning again should it stop like that regards Dave
The A/C compressor on a vehicle does this. It turns on and off according to the engines output. If the sound is very laud or gets worst, have it checked by a mechanic.
Jun 07, 2016 | 2001 Ford Focus
My ac will start cold then goes warm and some times will go cold again
Assuming the compressor is turning all that time, then you need to check your freon charge.
If the compressor kicks on and off then it is probably the compressor.
Aug 08, 2011 | 2002 Ford F250 Super Duty SuperCab
2005 Ford Transit not starting. Battery fully charged,engine turning over ok. Heater plugs ok and engine getting fuel. Anyone know what it might be. Engine relay problem maybe????
I have difficulty in starting my 2005 Ford Transit during the cold weather.There is no problem during normal temperatures.Are ther engine cold start heaters and where are they positioned on the engine.
Oct 27, 2010 | 2001 Ford Focus
Ac blows warm air after it cool the cabin
My Durango did the same and it was a high pressure switch bad. If you stand at the front of vehicle it is located on the left side next to the radiator support by the radiator. There is a rubber flap you may have to lift to see it. Switch was a dealer item $ 40.00 I have not had no more problem out of it.
Mine would cycle on and about the time it would get cold the compressor would shut down, it may start a little later or it may be the next day before it would get cold again and then would shut down.
Jul 17, 2010 | 1999 Dodge Durango
2001 Pontiac Montana - what is a misfire #5?
Without your actual trouble code, I am assuming that you are have a misfire on cylinder # 5. The computer cannot really tell what is causing the misfire only that cyl 5 is not putting out full power. If it misfires when cold then smooths out as it warms up, I would say it is probably an injector that is sticky, as it warms up it starts working properly.
Apr 29, 2010 | 2001 Pontiac Montana
Ford transit2.5 td 99v immobiliser probs wont start
back of fuel pump, take apart and run a wire straight from ignition to solenoid,
if stuck get back 2 me
Jun 30, 2009 | Code-Alarm Code Alarm Transponder
AC blowing warm air
When they refilled the refrigerant did they put die in it to check for leaks, it sounds like there may be a leak.
May 09, 2009 | 2006 Ford Expedition
Ford transit lock problem
i, i get this all the time, had lots of old transits. get as many ford keys as you can borrow friends from escort mondeo transit, these locks are **** some 1s key will open it, when doors are open u have to remove locks and soak them in oil leave under engine oil all night, fixes ur prob.
Feb 08, 2009 | Code-Alarm Code Alarm Transponder
03 jetta heater
Hi!
Looks like a classic air lock scenario! you need to perform a system bleed.
Park vehicle on level ground, when cold remove coolant filler cap. Start engine and leave to idle, turn heater to hot blower on full.
When at operating temp stand clear of coolant filler area, listen/watch hopefully gurgling and a boil over, top up when settled with very warm water/coolant, wait as it may do it a couple of times. Check for heat inside vehicle if hot and coolant settled replace cap but watch temp gauge for a while as another air lock may be in the system.
Please press the Blue button when sorted!
Paul 'W' U.K.
Jan 28, 2009 | 2001 Volkswagen Jetta TDI
Heating & Cooling Logo
119 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
