Question about Dryers
No heat i know that there is a wire leding from the motor to somthing that tells the heting element to warm but that wire is fried so the signal to heat is inoperable is there a wy to bypass this so tht the heat is lways on or do i just need to get a new dryer
  • 2 more comments
  • brown2181 Jul 30, 2009
    yes but the wiring harness is expensive and difficult to remove/replace and im need to bypass for a short term i can replace the thermal fuse if need be have alredy once part is less than 10 bucks
    yes i have seen the burnt wire leading from the motor to its connector on the back of the dryer i hve reconnected it twice nd both times the wire heated up so badly the connection severed i can use the timed dry option to control burning or scorching from the heat being always on but repealicng one wire doesnt seem to be an option given it is connected to the harness itself
    tested the thermostat last time and found there to be continuity is that bad or good
    the dryer is maytag mde308dayw...how do i replce/reconnect the new wire to the harness also will i need to buy a new spade connector as well
    President:
  • 704 Answers
I think the problem is that your dryer element is likely bad. You would have to do some diagnosis steps to determine just what isn't working before you continue. I'm going to let you know that bypassing any control device that would allow the heat to be "ON" all the time while the dryer is running IS NOT a good idea, unless you want to have all your clothes badly scorched and/or burned up! (I've seen it happen!)
If you have a multimeter and are comfortable working aroung 220V-AC, you can fairly easily detemine if the heating element is bad or if it's something else. If you have seen a damaged wire, you should be able to get a replacement wire at most appliance parts centers or even at an electrical supply house, of the correct gauge and type.
I always look at the age of the appliance and the overall condition, before embarking on a repair. I always use the 60% rule - if the cost of the repair (or just the parts, as I do the repairs myself) exceed 60% of the cost for a new replacement appliance AND the appliance is more than 10 years old - I'll opt to get a new appliance.
If you can take some time to figure out what is defective or failed, you should be able to repair it for a relatively small cost. Dryers are pretty basic appliances and can normally be fixed fairly easily by most DIY'ers with some working knowledge of electricity and circuits. The trick is to know how to use a multimeter and be safe when you get to checking the functionality of everything once you restore power to the appliance.
Hope this helps you with your thought process as to what to do next.
Posted on Jul 30, 2009
  • Mark
    Mark Jul 30, 2009
    OK, now that we know the element is good and you've already tried to replace the burnt wire, only to have it burn off at the connectors again, let's clarify how to properly repair this problem.
    You will need to get the proper wire gauge that has high temp, TEFLON insulation. This IS NOT the typical wire you can find at a big box or any hardware store. The wire will need to be copper, likely #14 Awg, possibly #12 Awg . The key to replacing the faulty wire is to use the correct type and gauge wire to replace it, otherwise, you'll keep having the wire burn.
    The other thing is when you strip the insulation off the wire ends that you use a good quality wire stripper and MAKE SURE you DO NOT nick or cut off any strands of the conductor, as loss of strands will cause failure at the temination (connector) fairly quickly. Also, use the right sided termination (connector) normally it's a .25 tinned, female spade terminal, but you need to get the right one. Then properly crimp the terminal onto the wire ends without crushing the termination. This is all important as nicked/cut strands and improper crimping of terminals, etc. will cause failure due to thermal runaway at the wire ends (connection points).
    Also, please provide your make and model number of the dryer so I can at least give you the correct wire type and gauge to obtain for your repairs. I still DO NOT recommend bypassing any safety control and anyone that does has no concern for the safety and welfare of people and their homes.
  • 6,784 Answers
Bypassing is not recommended. it will blow the thermal fuse if done. the best action is to replace the wiring harness. this wire you speak of is directly connected to the timer or control board. if it is severed, it will not communicate with the element.
replacing the wiring harness will correct this issue.
The control sector is the principle initiator of all related drying functions. the motor and element receives the go command from the timer or control board, via wiring harness.
  • 1 more comment
  • Michael Masters
    Michael Masters Jul 30, 2009
    I would advise to test the thermostat as well. it seems to be stuck open.
  • Michael Masters
    (((Correction)))--Stuck closed
  • Michael Masters
    That is good. no issues there.
How can I tell if my water line tank heating element is broken? Should it get warm to the touch?
no it should not. If fridge fan is working water should not freeze.
check for fan motor operation.
Apr 03, 2015 | Samsung RF26XAERS 26 Cu. ft. French Door...
My washing machine model no ewf 1421,is writing e60,why
Insufficient heating measured by the main board during washing cycle and also during drying cycle at washer-dryer.
Could be faulty: heting element, pressure switch, NTC sensor, printed circuit board (PCB),
wiring between PCB - heating element,
wiring between PCB - NTC sensor,
wiring of pressure switch.
Dado
Nov 20, 2014 | Electrolux Washing Machines
Water Heater Issues
An electric water heater contains two elements (usually upper and lower). Normally hot water is maintained at a certain temperature to assure an immediate supply. When hot water is turned on at the fixture, the second element is turned on to boost the temperature. From your description one of the heating elements may be defective or set to incorrect temperature.
Apr 28, 2017 | Water Heaters
Water tank not heating
Either your heating element is broken or the pressure switch. With a votage tester test the leads going to the heating element. To do this you need to remove the right side panel and test the heting element leads. You should have power going to this, if you do and its not heating you need to replace the hating element. If no power check your pressure switch, by removing the cover and with an insulated screwdriver push the contacts together and check the voltage at the heating element.
Dec 16, 2012 | Nuova Simonelli Aurelia Espresso...
Replaced heating element in lower oven of my ge . I am not getting warm up from it. What else could it be?
may have blown the circut braker or even worse burned a wire on the outlet or plug ,, look around some more then get back to me ,, be careful if it is HOT !
Dec 07, 2011 | Ovens
I changed the heating element in my lady kenmore dryer, but still not heating...
If the previous element was burnt out, the following test can be done.
First unplug the dryer. then bridge the active and neutral on the plug with a bridging jumper. ( a piece of skinned wire will do ) then set the dryer control on heat (hot or warm) make sure the door is closed ( door switch cuts element as well as motor.) If this is impossible then you may be able to operate the switch by clamping it with something. then disconnect the element wires from the element. You should be able to read continuity across two of the element wires. If you can, then select the other temperature setting (hot to warm ect.) if you can read continuity across the common and the other then the element is faulty if you cant, then check hot temp switch, warm temp, switch belt breaker switch. if it has one.
Aug 31, 2011 | Whirlpool 279843 Whirlpool Kenmore Dryer...
Milwaukee 8977 - 20 Variable Temperature Heat Gun blows air but no heat. how do you troubleshoot the circuit board or the heating element?
With out the thing plugged in with an OHM meter the heting element can be checked with the nose removed. Most of the time once the nose is removed the problem is easy to see the end is burnt off the element connection. Remake the connection reinstall the nose and test. The heating element runns right off the switch and the connection there is easy to see with the handle opened. This is simple unit and wires burnt off from being too hot is almost always the problem. look it over carfully and the problem will be seen.
Apr 21, 2010 | Milwaukee Tool Milwaukee 8977 - 20...
No heat in a Kenmore stackable washer dryer
there should be a small fuse on the heater box,if that is not working the element will not work also-mike
Apr 16, 2009 | Kenmore 88752 Top Load Stacked Washer /...
PROBLEM WITH SHARP R-1874TF CONVECTION OVEN
sometimes an over heat will shut down the oven for a little bit but lets look at other things
i dont believe the board to be bad but i do believe the heating element inside is fried or a wire got fried by heat
if you know how to use ohm tester i would check heating element and wireing first
then try to see if the timer gave out
Dec 06, 2008 | Sharp R-1874 Convection/Microwave Oven
Dryers Logo
189 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
