parcel them up , address them to your relative at the correction center by post
the parcel will be opened and inspected and if appropriate material , will be passed on
call the correction center direct and speak to the warden and check how to do it first and what sort of shoes you can send
Address for returns is just what it sounds like. If whatever you are sending needs to be returned, where do they send it. Usually your current living address.
I wrote to Kef support about an identical issue. Their replay is below.
By the description you have given, it sounds like the power amplifier board in the subwoofer has failed.
Unfortunately your subwoofer is no longer covered under warranty as the electronics inside comes with a one year warranty as with all KEF electronics, and the warranty card would have been supplied inside the box.
However, you can return the amplifier section to us by removing the screws on the very outer edge of the back of the unit and disconnecting the cables inside. Once removed, carefully package the amplifier and then contact the Service department on 01622 672261 with the serial number to hand, they will then give you a returns number. Once you have a returns number, you can send it to the following address with a covering letter. When sending the parcel, please make sure that you send it recorded delivery or get a tracking number if sending by courier.
PLEASE NOTE THAT ITEMS NOT BOOKED IN WITH THE SERVICE DEPARTMENT BEFORE DESPATCH, MAY INCUR FURTHER DELAY.
The address is as follows:
F.A.O. SERVICE GP Acoustics Eccleston Road Tovil Maidstone Kent ME15 6QP
f you want to send us a bulb we'll get you some - and give you the address of a supplier
i'm from the Uk and moved back to the UK for a period - and had the same kind problems - now I live in california
best
T
If you can't find proper service from your country, please send your Trilobite to Finland So have done some other people around europe too! :) I am a professional with Trilobite robot's. No service manual available, even for me... For error 3 If you can't find proper service from your country, please send your Trilobite to Finland So have done some other people around europe too! :) I am a professional with Trilobite robot's. No service manual available, even for me... For error thre is several possible reasons.
Check first all visible, is the surface clean and no visible damages.
If OK, yuo must sent it to service.
Br Jari Viitanen Address for service is: Oy JVV Tekniikka Ab Mestarintie 43 SF-28800 PORI tel. int +358 400 126597 remember add your return address with short description of fault and put the charged in the parcel Address for service is: Oy JVV Tekniikka Ab Mestarintie 43 SF-28800 PORI tel. int +358 400 126597 remember add your return address with short description of fault and put the charged in the parcel
