Question about Frigidaire Affinity ATF7000E Front Load Washer
Main control board and water pump went out just bought my washer 2 months ago. frigidaire was suppose to send me the parts overnight delivery but failed to do so. I heard there is a recall on the water pump. Is this true?
  • 26 Answers
No your source on this is wrong..no known recalls on the frigidaire affinity/
Posted on Jul 30, 2009
We are at our wits end. See details. What else can we do? LG Tromm 2277 Washer no power.
either of 2 things I can suggest . 1 would be call the repair man or 2 buy a new one .
Oct 05, 2014 | Washing Machines
My Front Load Affinity washer shuts off after a few minutes
Good Afternoon Lori - Thank you for your post! Based on the symptoms you are describing, you may either have a communication error from the main control board or the timer itself may not be operating correctly. If you noticed a humming noise, then once again it could either be a clogged drainage hose or pump that needs to be cleaned, or it could possibly have another issue with the door lock assembly. I would personally contact a professional to accurately diagnose the washer to determine the root cause to reduce the risk of unnecessary parts.
Jul 11, 2013 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire oven wont heat up but stovetop and digital all works
Hello angeleyez82 - The EOC (electronic oven control/control board) basically sends power to both the broil and bake elements. As long as the power supply to the range (240VAC) and wiring between the elements is correct, then typically only the element(s) or EOC could prevent the unit from heating. I hope this information helps to some degree.
Jun 25, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire oven
Yes, that sounds like a relay on the oven control board. Here is the part to order that has a 365 day, any part, any reason return policy so you may want to order from them.
Jun 25, 2013 | Ovens
ERROR CODE E20 FIDGFIDAIRE (ATF7000EGO) FRONT LOAD WASHER
You are experiencing a water pump issue. . Check the drain hose for restrictions. Restriction, correct problem. No restriction, go to step (2). 2. Start the washer and check for 120VAC at the drain pump. Zero, replace the Main Control Board. 120VAC, remove the pump and check it for blockage. If blocked, remove the restriction, if not, replace the pump.
Aug 23, 2012 | Frigidaire ATF6000ES Front Load Washer
Getting E20 error code on frigidaire front loader. It's 6 years old and has had one main panel board replacement already. Is this the same problem?
You are experiencing a pump issue. Typically a professional is needed to :
1. Check the drain hose for restrictions. Restriction, correctproblem. No restriction, go to step (2).2. Start the washer and checkfor 120VAC at the drain pump.Zero, replace the Main Control Board. 120VAC, remove the pump and checkit for blockage. If blocked, remove the restriction, if not, replace the pump.
Jul 28, 2012 | Frigidaire GLTF2940ES Front Load Washer
We have a frigidaire front load washer about 3 years old. We moved and has been sitting for about 2 months now. Just tried to plug it in and use it and it will fill with water and stop. Now it's not...
The first thing to check is your water supply lines and make sure there is no sediment build up.You may need to replace the main control board,also check to make sure the drain pump is not block or restricted.
make sure you have the proper voltage to the machine.
Sep 07, 2010 | Frigidaire ATF6000ES Front Load Washer
Kenmore Elite HE4 front loading washer. I bought this washer 2 years & 2 months ago. According to Sears the warranty expired 2 months ago. I was getting a F 02 it would not spin or empty water, so I called...
ya, first question? they said $1000.00 to fix?wow Did the tech give you that in writing?
ok, take off the bottom kick plate and you will see a pump right in the middle. there is a trap there unsrew the cap and get the stuff out of there., word of caution have towels ready cause when you take this off the water will come out. you should get as much water as you can at first.from the tub.you will not get all the water out.
let me know what you find.
Dec 06, 2008 | Kenmore Elite HE4 Electric Dryer
Whirlpool Callypso Model #gvw9959kl2 Serial #cm3202070
I had the same problem, it turned out to be the "U-Joint", which was a fairly easy repair. The part comes as a kit, (It is probably very common), the cost I got from Sears was $112. With tax and a $44 overnight delivery charge, my total was $170. And while I had it apart, I also cleaned all the gunk out.
May 19, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Frigidaire Affinity ATF7000E Front Load Washer Logo
380 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
