Had a paper jam. Cleared it. ''Clear misfeed'' light still on.
Savin 9918. Had a paper jam. Cleared it, but now ''Clear misfeed'' light will not go out, therefore, machine will not function until it is off. Can not find ANY pieces of paper inside machine. HELP!
Have you tried turning of the power and unplugging ALL cables including telephone line . leave for 1 min then recconnect and try again. Or could be a very small piece of paper as a little near the sensor will confusew the machine
Posted on Jul 30, 2009
LEXMARK X7550 JAMS &MISFEEDS TROUBLESHOOTING
How to clear and avoid paper jams: To clear the paper path: 1 Pull firmly on the paper to remove it. If you cannot reach the paper because it is too far into the printer, lift the scanner unit to open the printer. 2 Pull the paper out. 3 Close the scanner unit. 4 Press check. 5 Reprint any missing pages. To avoid paper jams, do not force paper into the printer.
The Lexmark X7500 Series User's Guide will be able to give you more detailed instructions on how to troubleshoot paper jams and misfeeds on your printer. You can download the user's guide from the Lexmark website at http://bit.ly/mdAcJO and go to page 177.
May 10, 2011 | Lexmark X7550 InkJet Printer
MISFEED INDICATOR BLINKING
DEAR SIR WHERE YOU REMOVE THE PAPER IN THE MACHINE THAT SECTION THERE IS PAPER PATH SENSOR ,THAT SENSOR POSITION IS ABNORMAL PLEASE CHECK THE SENSOR OF THAT SECTION WHERE YOU REMOVED THE PAPER
Hope this may help;
Regards,
VOTIT
Aug 29, 2008 | Sharp AL 800 Copier
We can not clear the paper jam error. We have cleared the paper jam, turned the unit on and off, unplugged the unit, moved all the rollers, can not see any pieces of paper that are still in the misfeed but...
This copier has 4 sensor
1. paper sensor
It is called paper sensor its installed paper tray
2.Drawer sensor
3. Drive sensor its installed middle position
4. Exit sensor it is in fuser unite.
May be any sensor displace or broken.So you should check it.
Good luck.
Feb 16, 2011 | Sharp AL 1631 Copier
IT IS GIVING ME CLEAR MISFEED (A) I DID THAT AND IT STILL TELLS ME TO CLEAR MISFEED, I EVEN TURNED AND UNPLUGGED IT AND CLEARED AND CLEANED AND STILL HAS THAT MESSAGE
you may have a bad switch. sometimes paper hides behind the drawer. remove your paper cassettes and look begind them for a paper
Jan 06, 2011 | Office Equipment & Supplies
I have a Sharp Al-2040cs when I turn it on the misfeed indicator is blinking. I checked it there no misfeed paper or piece of paper inside. How can I fix this problem?
The MISFEED Indicator blinks when a MISFEED has occurred. Remove the misfed paper referring to the the description of MISFEED REMOVAL beginning on page 65 of the pdf Manual at:
http://files.sharpusa.com/Downloads/ForHome/HomeOffice/PrintersFaxMachines/Manuals/cop_man_AL2030_AL2040CS.pdf
When the MISFEED Indicator is blinking you should look closer at the paper feed area (see page 66 of the PDF). You may need to remove the paper tray to find any remnants of paper. If after closing the side cover the light does not stop blinking you will need to follow through as per the illustrated instructions.
Remember after removing jammed paper, you need to press the clear key to clear the MISFEED error.
If after doing all this the error signal has not cleared, power down the printer; unplug from the power supply; let rest 5 - 10 minutes; plug back i to power supply; turn printer on and see if this resolves issue.
Trust this is helpful. Please vote. :)
Dec 12, 2010 | Sharp AL2040CS Digital Laser Copier,...
I have a Savin 2015 DP and it says that there is a paper jam. there is not, i have already cleared it and the light wont go off, therefore, my machine is out of service. any advice?
There is a sensor lever that gets stuck on these models. The sensor is located just below the drum . (might be on its own door cant remember) it should move freely if it is stuck in the jam position the jam wont clear.
If you still nee help reply and I will try and assist futher.
Good Luck
Apr 09, 2010 | Savin 9935DP Laser Printer
The traingle is flashing orange the rest not flashing. the printer does not print
In the Attention state, the Attention light is blinking and the Go and Ready lights are off. This state can be reached in the following circumstances:
● Paper tray is empty
● Door open
● Toner Cartridge Missing
● Paper jam/ Tray Misfeed
Pressing Go attempts to reset after a jam is cleared or is ignored in the other error cases. It may be necessary to clear the error manually and press Go or close the top cover. If the error still persists, the device will return to the Attention state.
Note
The LJ1010 product series does not have paper out sensors. When the printer is in an Attention state because the paper tray is empty, the user must reload paper and press Go.
Nov 13, 2009 | HP LaserJet 1010 Printer
My copier continues to misfeed even though I have cleared the jam
there are little plastic fingers on the drum and heating rollers (hot), one of those is raised up from the surfaces of either component, causing your paper to catch. both move back and forth on tiny springs. on the fuser you can actually remove several of these fingers if they are the problem and still use. on the drum they must be repositioned or replaced
Jun 15, 2009 | Toshiba e-STUDIO 16 Printer
Paper misfeed indicator light continues to blink even after paper
some machines will want all covers to be opened, then closed, for good reset. if you are having jams in the adf, then open all adf covers, and lift the adf upward, if it allows. also, try turning unit off, then back on. some jams only clear that way.
Apr 02, 2009 | Sharp AL-1641CS Laser Digital Copier
How do I clear misfeed.
In most cases where the machine says there is a jam, and there is no paper in the paper path, it's because the paper never got out of the paper drawer and didn't reach the 1st jam sensor. If you can open the machine and it resets, then chances are the paper feed roller is either slipping or in some cases not turning at all. If you can't clear the jam by turning off the machine, and back on, then you have a bad jam setect sensor or perhaps a small piece of paper lodged on the jam sensor. This will take some additional troubleshooting on your part. Need to know if the jam indicator goes away when you restart the machine. Let me know and I'll try to guide you from that point. Aloha, Bill Monroe
Sep 17, 2007 | Ricoh Aficio 1018D Copier
256 people viewed this question
k24674
