Question about Dell E173FP 17" LCD Flat Panel Monitor
Monitor says Step 2: Self test and displays color bars
  • sarartist Jul 30, 2009
    The monitor was shut on and I left the computer came back and it was showing the Step 2: Color Bar
  • 15,935 Answers
It is in self-calibration mode.
What were you doing just prior to this incident?
Was the PC on - and the monitor shut off??
Were you just starting up?
More information is helpful for diagnosing remotely.
Thanks :D
Posted on Jul 30, 2009
  • blueextc3221
    blueextc3221 Jul 30, 2009
    Connect the display to a PC with analog graphics via a VGA-DVI adapter...my Dell E176FP had the same problem, but started running like normal after connecting it to an analog video source.
    If your monitor works with a analog video signal, use the buttons on the front of the flat panel to open the OSD, and complete a 'factory reset' for all settings.
    After rebooting the PC and turning my monitor on and off (both with and without a signal), the problem has not returned.
  • blueextc3221
    unplug the monitor for 30 minutes and re-try it.
No display on monitor
Open your computer and discharge static by holding the chasis casing of your system unit for 1 minute. Then start cleaning your video and memory card and also the their slot by using vacuum cleaner and small paint brush. Then put it back again and test for a display. Most of the time because of the dust covered the slot or the pin of the video and memory so the system did not detected that hardware that is why those hardware will not functioning. Clean and test have a nice day!
Jun 04, 2011 | Computers & Internet
* verify if all cables are properly connected.
* Perform monitor self test by unplugging the video cable (ex.VGA) from the monitor, if you see colored bars showing on the monitor that means your monitor works fine but if there's NO colored bars showing on the monitor that means the monitor needs to be replaced.
* Go to safe mode, if successful, perform system restore. If system restore fails, run hardware diagnostic by going to F12. If no failure found, perform pc restore, if it still fails-you can reinstall you operating system.
*If all fails, you can contact your manufacturer.
***PLS NOTE that performing PC RESTORE and OPERATING SYSTEM REINSTALLATION will cause DELETION of DATA. IF YOU HAVE IMPORTANT FILES, BACK UP YOUR FILES FIRST BEFORE DOING the suggested resolution.***
Jun 04, 2011 | Intel D865GBF Motherboard
Dell E153FP monitor won't display any video from system (Dell GX260). My e173FP monitor works fine. E153FP powers up, runs Self Test Feature Test fine, menus all seem OK. Tried Factory Reset... still no...
You probably have tried this, but make sure monitor is set to correct display... i.e., Analog or Digital
Also, try starting in safe mode and verify Monitor is able to handle the display settings resolution
Apr 10, 2017 | Dell E153FP 15" LCD Monitor
My hp desktop will not operate. It reports a message that I have a paper Jam. I have checked the printer as advised and there is no paper inside. I have also conducted all recommended shut down and...
You need to clean NVRAM on Lexmark X5470 printer. Please follow the steps given below to clear NVRAM on Lexmark X5470 printer:
1. Turn the printer off.
2. Hold down "#5" button and turn the printer back on.
3. Keep holding "#5" button for about 5-10 seconds.
4. Press "Menu" button once.
5. Press the right arrow until display shows "Tools."
6. Press "Check" button once.
7. Press the "Right" arrow button again until display shows "Maintenance."
8. Press "Check" button again.
9. Press the "Right" arrow button again until display shows "Manufacturing."
10. Press "Check" button again.
11. Press "Right" arrow until display shows "Clean NVRAM."
12. Press "Check" button to clear nvram.
Next, try this printer self-test by following the steps given below:
1. Make sure the printer is in “Copy Mode.”
2. Press the “Menu” button once.
3. The screen will display “Copy Menu: Copies”.
4. Press the left arrow button once. The screen will display “Copy Menu: Tools”.
5. Press the check button once. The screen with read “Tools: Maintenance”.
6. Press the check button once. The screen with read “Maintenance: Ink Levels”.
7. Press the right arrow button until the screen reads “Maintenance: Print Test Page”.
8. Press the check button once. This will start the Self-Test. Once the page has printed, the printer will stop. The test is not continuous.
The self-test should at least print out a set of either a solid black or solid color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, please try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only a color cartridge installed (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed). If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know. This includes any print quality issues - we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
If the self-test prints your test bar(s) clearly, the printer hardware is not at fault.
May 02, 2009 | Lexmark X5470 All-In-One InkJet Printer
Lexmark x3330 Error message
Please remove the cartridges from the printer. Take a dry lint free paper towel and gently wipe the contacts on the back of the cartridge (not the bottom from where ink is present). Wipe the contacts inside the printer (on cartridge carrier). Please snap the cartridges back into the cartridge carrier.
1. Turn off power.
2. Press and hold the "Black Copy" and the "Power" buttons at the same time. Continue holding then until the screen displays "Mfg Menus Enabled."
3. Press the "Menu"(--->) button 2 times.
4. Screen will read "LCD Button Test," press "(-)" button 2 times.
5. Screen will read "Single Test Page," press the "Menu" button once.
You should see text followed by a thick 1-inch black bar. Under this bar, should be a process gray bar about a 1/2-inch thick. Below this line should be a set of railroad like bars of cyan, magenta, and yellow.
Should this test fail, try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only the color cartridge installed. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know. This includes any print quality issues, we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
Apr 28, 2009 | Lexmark X5470 All-In-One InkJet Printer
Error1102 occurs after new ink cartridges are installed
To clean the NVRAM, please follow the steps given below:
1. Press the "Up-Arrow" button and "Menu" Buttons Simultaneously.
2. Press the "Down Arrow" button until the LCD displays "Clean NVRAM."
3. Press "Select." The LCD should display “Success” or “Failed.”
If it is successful, please try this printer self-test by following the steps given below:
1. Press the "Menu" button.
2. Press the down arrow button 9 times until the screen displays "Print Test Page."
3. Press the "Select" button to begin printing the self-test.
Apr 21, 2009 | Lexmark P4350 All-In-One InkJet Printer
Not showing up on my computer
It seems there is a possibility of a problem with the printer itself, or perhaps the cartridges. You should first self-test the printer. Since we are unsure where the problem exists, we must do eliminative troubleshooting to rule out parts of the printing system. The self-test allows us to rule out software and the cable by testing the hardware by itself. Please note that this is not a "fix," but rather a diagnostic test to determine if your hardware is at fault.
1. Please turn OFF the printer.
2. Press and hold the "Color copy" button.
3. Now, turn ON the printer.
4. Once you see "0" on the display, release the "Color copy" button.
5. Press the Up arrow button until "2"appears on the display.
6. Press the "Black copy" button to start the self test. Once the page has printed, the printer will stop printing.
The self-test should at least print out a set of either black or color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with the color cartridge installed by itself. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, let us know. This includes any print quality issues, we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
If the self-test prints your test bar(s) clearly, the printer hardware is not at fault. The issue may be a communication problem, or perhaps a software conflict.
However let me know the name and version of the operating system (Windows XP / 2K / NT, Windows Vista, Mac) that you are using on your computer. This information is important for me to troubleshoot the issue further.
Apr 14, 2009 | Lexmark X2600 InkJet Printer
Print cartridge missing
The self-test should at least print out a set of either black or color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with the color cartridge installed by itself. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let me know.
Apr 13, 2009 | Lexmark X2650 All-In-One InkJet Printer
Color and other problems with SyncMaster 910 MP monitor
Go to => http://www.samsung.com/us/
Type 910mp in the search dialog box.
Select Download English Manual. It's about 20mb.
The manual has instructions for setup including adjusting your monitor. There is even a section troubleshooting and a self-test. Good Luck.
Dec 12, 2008 | Samsung SyncMaster 910MP 19" LCD Monitor
My samsung lcd monitor is very dark and can't be adjusted
Hi strat1971,
So the monitor buttons don't work also right? Yeah, normally you should try to adjust the brightness control first on the monitor. If that doesn't work next step would be ofcourse to check the cabling of the monitor to the computer. Try reseating the video cable from the back of the computer. If no go, then the next step is running the monitor self-test. You can do this by just disconnecting the video cable from the back of the computer, and leaving the monitor plugged into the power outlet.
All monitors has a form of self-test that it does to check the functionality, usually a picture or a color bar display on the screen or even a message that the monitor is on self-test. If it's still dim on that screen, then sadly you already have a hardware problem that may require to you buy a new monitor.
Hope this helps!
Peace! :)
Oct 22, 2008 | Computers & Internet
Dell E173FP 17" LCD Flat Panel Monitor Logo
Alun Cox
