Question about GE Profile PDS20MFW Bottom Freezer Refrigerator
Clicking sound, open door you see light flashing while clicking
  • GE Master
  • 4,655 Answers
That is your compressor overload. You have either a bad start relay, start capacitor or external overload. If not repaired soon compressor damage will occur. Let me know if I can help you find the parts and if you want me to help get you going. Sea Breeze
Posted on Jul 30, 2009
  • John Tripp
    John Tripp Jul 30, 2009
    Your refrigerator mother control board located on back of refrigerator can also cause this. The board part number is WR55X10656.
    Here is an example of a boartd with burn marks.
    I need you to unplug the refrigerator and remove the cover over the compressor area and feel the compressor top to see if hot. Too hot to the touch. Let me know what you find and then we will go grom there, Thanks Sea Breeze
B&d control a door mpc2 model not opening control panel has flashing green up down light and also flashing red light limit set
Check your user guide if available. It sounds like you haven't set the door open limit, so press the up arrow & fully open to the door & push set, do the same for the down arrow until door is completely closed. Push the set button again & the door should be right..
Apr 19, 2016 | Building Materials
The door won't close with one click, I have to keep pushing the wall button to close the door, remote control won't work except for one inch movement down, the door will open with one click from both wall...
Sounds like a problem with the safety photocells, to confirm locate the where the safety input is on the opener and bridge out the terminals ( not the supply voltage terminals) if the door then closes the photocells are the problem.
Apr 02, 2011 | Linear Ldo50 Residential Garage Door...
Garage door opener makes a clicking sound when activated by the remote or wall unit and the lighton the back of the opener flashes. craftsman.
If the opener is making a clicking sound when it is running the chain is too tight. Post back with the number of flashes from the light.
Dec 14, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have a Liftmaster 2000sdr 1/2 hp garage door opener. It stopped halfway through the cycle and is giving a 5-light error code (RPM sensor or motor overheat). When I try to run the system all I get is 4...
SORRY TO SAY IT SOUNDS LIKE A FRIED CIRCUIT BOARD. LEAVE THE UNIT UNPLUGED FOR AT LEAST 30 MIN. & TRY AGAIN, IF SAME RESULTS I WOULD REPLACE THE BOARD.
HOPE THIS HELPS
Oct 17, 2010 | liftmaster Chamberlain Garage Door Opener...
Myt 1/2 hp craftsmand door opener clicks and light
If the main light flashes 10 times when the door reverses it is a door sensor problem. Each sensor has a small light that needs to be lit and not flickering for them to work. They must be pointed at one another for the lights to be on. Tweak them a bit and see if the lights come on. If not you likely have a bad sensor.
Oct 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
IChmberlain Garage door does not pen or close
The light flashing 5 times is the code for "RPM sensor or motor overload" and the 10 clicks sounds like the relay for the main light bulb that flashes when the door sensors are blocked or misaligned.
If you want an owners manual and have Adobe Reader you can go here and get one.
http://www.chamgerlain-diy.com/pdfdocs/A2490M.PDF
Oct 15, 2009 | Chamberlain Powerdrive PD422D 1/2 HP...
Will not start; Several interior lights also flash
It is your battery. I just had this happen to me, had the battery checked and replaced.
Aug 06, 2009 | 2005 Dodge Ram 1500
Garage door will not open
The light flashing 5 times is the code for RPM sensor or motor overload. The RPM sensor is a small printed circuit board just in front of the motor. I would really doubt it is a motor problem unless you have been operating the opener enough that the thermal overload protector has shut it down. It will start running again as soon as it's cooled off.
May 20, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage Door Opener Lights
Some craftman operator don't have that feature. Are both photo eye lights green? Feature not available. If the photo eyes are yellow and green feature should be avilable. The operator needs to have a three button wall station. With the light on the operator off press and hold the "light" button for about a minute until the light flashes.
Jan 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
GE Profile PDS20MFW Bottom Freezer Refrigerator Logo
118 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
