Question about Kenmore 23822 Top Load Washer
HOW DO I REMOVE TOP COVER FOR ACCESS TO LID SWITCH
  • 5,911 Answers
The following link explains step-by-step how to replace a lid switch on a Kenmore top loading washer:
http://www.fixya.com/support/r385198-replacing_lid_switch
If you have any questions about this repair, or require additional assistance, please let me know. I hope this helps you.
Posted on Jul 30, 2009
Won't start when cover closed
your lid safety switch is shot,you need to remove 2 side control panel covers that pop off,then remove 2 screws that are under here, then control panel will separate from top to let you unplug lid switch connection to the control panel,then open the top cover by popping clips inward on the 2 front corners with a putty knife or something flat like this between the top and front covers,then raise top up and lean back against the wall there you can access this switch to replace it,this switch is designed to shut off unit if lid is raised during spin cycle for your safety
Dec 11, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
How to remove washer top for broken lid switch access
if it is a top loader,,,remove the screws in each end of the control panel,,,some units you have to remove the end caps to access the screws,,,then pull slightly forward on the panel and flip it back it is on hinges,,,,then remove the 2 clips that hold the back to the base,,,unplug the lid switch,,then open the lid and grab the inner lid section and pull the rear of the base towards you slightly and lift off the base,,,, then you can access the lid switch and replace it ,,,,
Apr 29, 2010 | Washing Machines
LS error
The machine control detected that the lid switch is not functioning properly. Raise the top part of the washer to gain access to the lid switch.
Disconnect the machine from the power source. Gently pry the emblem from the front of the machine and remove the T20 torx screw hidden behind it. Slide the top of the washer forward and raise its front. Prop it up high enough to allow easy access to the lid switch.
The lid switch is activated by an actuator (part number 19119) mounted on a hinge. It will not work properly if the actuator is damaged.
Check the operation of the lid switch using a multimeter. Disconnect the lid switch wiring harness and connect the test leads of the multimeter (set to X1 or ohm) to the terminals of the lid switch and activate it. The multimeter should read zero ohms while the lid switch is activated and open when deactivated.
Replace the lid switch if it is broken or if it fails the test above. Remove the lid switch mounting screw and install the new lid switch. Reconnect the wiring harness and slide the top of the washer back into position. Reinstall the T20 torx screw and the emblem.
Feb 11, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Ho do you access lid switch
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
To get to the lid switch on a Kenmore Top Load, you have to remove the cabinet.
See GURU JSROCK516 Description of how to remove cabinet and access the transmission. http://www.fixya.com/support/r699497-replacing_gearcase
Basically, you will remove two covers if your model has them, two screws, unolug the lid switch from the console and pull the cabinet forward.
Sep 05, 2009 | Kenmore Washing Machines
Washing machine will not drain or spin.
HELLO: YES THE LID SWITCH IS BAD. TO REPLACE THE LID SWITCH YOU MUST REMOVE THE COVER ON THE MACHINE. FIRST REMOVE THE TWO PHILLIPS SCREWS FROM THE CONTROL CENTER ON TOP BACK OF MACHINE . TILT BACK THE TIMER AND CONTROL CENTER GENTLY. THERE ARE TWO FUNNY LOOKING LID RETAINER SPRINGS THAT HOLD THE ENTIRE THREE SIDES OF THE MACHINE TOGETHER REMOVE THESE WITH A FLAT BLADE SCREW DRIVER. REMOVE THE POWER PLUG FROM THE WASHER UNDER TOP. SLIDE COVER OFF MACHINE THEN REMOVE THE TWO PHILLLIPS SCREWS FROM THE LID SWITCH ASSY. UNPLUG SWITCH FROM COVER AND REPLACE WITH NEW UNIT . THERE IS ALSO ONE GROUND SCREW 5/16 THAT WILL COME OFF FROM UNDER NEATH THE COVER. THIS SOUNDS A LITTLE COMPLICATED BUT THE WHOLE PROCEDURE CAN BE DONE IN LESS THAN 10 MINUTES. THANKS FROM RUSTY AT RVANS@NETZERO.NET
Jun 08, 2009 | Whirlpool Washing Machines
Wahser wont run spin cycle.
Door switch is probably bad or connection is loose. Remove the top cover to gain access to the switch.
David Le
Apr 21, 2009 | Kenmore 22422 Top Load Washer
Machine won't drain or spin.
The whole top assymbly has to be lifted off. Sometimes, you can gain access to the switch from the rear panel without removing the top. I just replaced one for my mother last November. I was able to get to it without removeing the top cover. Some are just not easy.
Mar 31, 2009 | Kenmore Washing Machines
Whirlpool Thin Twin Lid Switch and Return Pump access
where the washer and dryer attach just above washer lid there should be screws to rmove cover between units yours may have clips instead of screws that need to be removed to remove lid and top on rear edge of top there is a plug that hooks lid switch just watch when reinstalling top to be sure it reconnects..sorry for mix up those units had 2 different layouts over the years and without an image hard to tell which one you had
Jun 12, 2008 | Washing Machines
I have a Whirlpool Thin Twin model LT7000XTNO and the water will not drain after the wash or rinse cycles. I have tried it in each of the different settings (normal, permanent press etc.) Could it be the...
on most of those remove 2 screws in cover under console /timer on back edge of top will be 2 screws remove screws slide top forward switch connection is on front edge to acess pump 2 screws 1 on each side just below top on in side of panel remove and lift panel up
Jun 10, 2008 | Whirlpool Washing Machines
Removing top cover to access switch
You have to pretty much use a putty knife to remove the front panel. Insert the putty knife into the edge of the front panel where it meets the top lid panel about and inch or two from the sides. One clip on each side. Push in the putty knife and give a little pull on the front panel repeat step for other side. That should get you into where you need to be.
Hope this helps you out. Feel free to ask any more questions about this if you run into anymore issues.
Mar 22, 2008 | Kenmore 22422 Top Load Washer
Kenmore 23822 Top Load Washer Logo
180 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
