Question about SkyGolf SkyCaddie SG2 GPS Receiver
My sky caddie SG2 cable is inoperative.
I have tried to find a replacement. No luck. has a serial port connection to computer with an RCA jack connection to SG2. Anyone have any suggestions. Sky golf does not carry them and doesn't plan to either.
Did you ever find a replacement serial cable for the SG2-serial? I have the same problem and can't find a replacement cable. my email address, par5s2ez@hawaii.rr.com
Posted on Aug 22, 2009
My son gave me his Sky Caddie SG2. I have the cables and the disc. It worked for about 5 rounds this year and now will not work. ???
hi Is it powering up at all if not check the battery unit might need to be replaced check that the terminals are ok for the battery also goodluck
Mar 17, 2011 | SkyGolf SkyCaddie Handheld GPS Unit
How do I connect a camera to my pavilion n5430?
Follow these steps :
Identify the ports you have on your computer and video camera. Typically there will be a small door or flap at the rear or near the bottom that covers the ports. You computer may have ports in the front as well as the rear. You video camera may have more than one of these ports and may not have all of them.
Find the i.LINK port. i.LINK is
version of IEEE-1394 standard (aka) Firewire. It is commonly found on DV (Digital Video) varieties of camcorders. You may find the smaller 4 pin connector on your camera if it is a compact video camera. Typically the larger 6 pin variety is found on computers and larger camcorders. i.LINK transfers both video and audio. For more information click on "How i.LINK Works" in the Resources section.
Find the USB port. USB (Universal Serial Bus) is another connector like i.LINK for transferring digital video and audio. Typically a mini USB connector such as the "Mini-A" will be found on your camcorder than large flat "Type A" connector typically found on computers.
Locate the S-Video jack. The S-Video jack is a round 4 pin analog connector. S-Video is for only video transmission. You will need to connect the red and white audio RCA jacks or use a phono port to transfer the audio to your computer.
5
Find RCA Audio/Video Jacks. These round single pin ports usually are found in a set of three of different colors. Yellow is video, red is for right audio, and white is for left audio. On some Handycam's, there may be a mini-plug that is an all in one Audio/Video jack that you plug in a special cable (as seen in the photo) that connects your camera to standard yellow, red, and white RCA jacks on your computer.
6
Choose a matching pair of ports you have on both your computer and your camcorder.
7
Turn both your computer and camcorder off.
8
Connect your computer and camcorder with the appropriate cable. Turn on both your camcorder and your computer.
Nov 20, 2010 | Computers & Internet
I RECENTLY PURCHASED A NEW COMPUTER ( WINDOWS 7 ) AND IT WILL NOT ALLOW ME TO SYNC MY SG-2 SKY CADDY. MY NAME IS BRUCE ALLACHER - ballacher@cox.net user name platteview 1 password riverwild
If your SkyGolf came with software, you should install it first. If you installed it and it does not work, go to the software and check for updates.
If that fails to work, UNINSTALL the program, and re-install it.
Make sure you DO NOT connect the device to the computer until the software is fully installed.
Check for updates after installation, and the reboot.
Then attach your device to the computer, and it should recognize it.
Good luck
Oct 13, 2010 | SkyGolf SkyCaddie SG2 GPS Receiver
Missing driver disk for my Skycaddie SG2
I can't tell you how I solved my problem, because then I would have to charge you, like you want/wanted to charge me to solve it. Sorry, maybe if you were more willing to help, I would be more willing to share.
Jun 25, 2009 | SkyGolf SkyCaddie SG2 GPS Receiver
No sound when my computer is connected to my Sony Bravia TV
If your computer has a svga output use input 7 on tv with vga to vga cable and 3.5-3.5 Radioshack 42-2387 cable for audio for best results. If you use the dvi to hdmi on input 6 on tv use 3.5- rca Radioshack part number 42-2551 1/8=3.5mm.
Apr 20, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
I hvae just purchased a Samsung HXT 30 sound system and connected it to the tv anbd sky hd box how do I get sound from the tv it would appear it is a problem what cables do I need I have aq HDMI from the...
You need to run a cable from your Sky (satellite box) box's 'Audio Out' jacks to the sound system's 'Audio in' jacks. Make sure the Sound system is set on the same function as where you plugged in the cables (RCA type, red & white) on the back of the sound system. (example: if you used the 'Auxilliary' jacks, set the sound system on 'Aux')
If it's sound 'from' the TV as well as the sound system you'll need to connect another set (of red & white RCA) cables from the Sound System's 'Audio Out' jacks to the Television's 'Audio In' jacks. This should give you sound from both the TV's speakers and the Sound System. Good Luck!
Nov 30, 2008 | Samsung HT-Q100 System
SkyGolf SkyCaddie SG2 GPS Receiver Logo
485 people viewed this question
Top SkyGolf GPS Experts
Oloyede Monsuru
Are you a SkyGolf GPS Expert? Answer questions, earn points and help others
