I'm trying to find out where are the end shields
I'm trying to find out where the end shields are located,to oil the unit
    Champion:
  • 233 Answers
If you are referring to the fan motor there will be small plastic or metal "plugs" at the motor end right where the shaft enters the housing. use 20 weight oil if the motor has the plugs, if not the motor is considered permanently lubed and does not require oiling.
Posted on Jul 31, 2009
Where is the oil sending unit on a 2008 chrysler sebring v6
Looks to be located just below the heat shield for the exhaust header on the right side. Here is images with locations: http://www.autozone.com/repairguides/Chrysler-Cirrus-Stratus-Sebring-Avenger-Breeze-1995-1998/SENDING-UNITS/Oil-Pressure-Sender/_/P-0900c1528008965d
Aug 16, 2016 | Chrysler Cars & Trucks
Belt falls off
see the next steps and fix it. God bless you
Drive Belt
Remove the screws or bolts securing the ends of the pedals to the crank axles. Slide the ends of the pedals off the axles. Remove any screws or bolts securing the left and right disc shields to the base unit. Pull or pry the disc shields off the base unit and set them aside.
Remove any screws or bolts securing the left and right side shields to the base unit. Detach the side shields and set them aside. Examine the interior of the base unit and locate the drive belt.
Pull the drive belt free of the crank pulley, flywheel and any other pulleys. Discard the old drive belt and install a new belt in its place. Turn the crank axles by hand to confirm that the belt will turn smoothly when the device is in use.
Dec 18, 2012 | Schwinn 150 Upright Bike
Older proform crosstrainer ( recumbent bike ) just assembled from box and when I pedal grating sound from pedal area?
B) Lubricate your FITNESS BIKE. very important.
Sincerely. Mery Christmas.
Ernesto Cuadra
Managua, Nicaragua.
Dec 24, 2011 | Exercise & Fitness
Belt came off and need to put back on
SINCERELY. GOOD LUCK.
ERNESTO CUADRA
MANAGUA,NICARAGUA
Nov 25, 2011 | Proform PFTL79807 - 850 W/ Gamefit...
I have a commercial cardiozone elliptical cg3 500 with automatic stride adjust. The elliptical is giving an err 2 message when we try to use it. Restarting the machine does not fix the issue. How do we...
Removethe bolts or screws securing the console to the upright assembly. Lift theconsole and confirm that the cable connections are secure. Remove the coverfrom the console's battery bay and install a fresh set of batteries. Replacethe battery cover.2
Detachthe ends of the pedals from the crank axles. Remove the left and right discshields and side shields. Inspect the interior of the base unit and locate theflywheel.3
Inspectthe flywheel as it turns. Locate the magnet installed on the flywheel. Turn theflywheel until the magnet passes in front of the nearby reed switch. Loosen thescrew securing the switch in place. Rotate the switch to reduce the gap betweenit and the magnet. Tighten the screw.4
Replacethe left and right disc shields and side shields. Reattach the ends of thepedals to the crank axles.
Good luck, sincerely.
Aug 24, 2011 | Cardiozone Supersport Hr Club Commercial...
Location of oil switch 2002 chrysler 2.7 engine
should be on driver's side right above the oil filter
Jul 18, 2010 | 2002 Chrysler Sebring
Where is the oil pressure sending unit located on a 2000 jeep grand cherokee 4.0 liter
Removal & Installation
  1. Disconnect the negative cable from the battery.
  2. Raise vehicle on hoist.
  3. Remove front splash shield.
  4. Disconnect oil pressure sender connector (4).
  5. Remove the pressure sender (2).
Oil pressure sending unit
To install:
  1. Install oil pressure sender.
  2. Connect oil pressure sender wire.
  3. Install front splash shield.
  4. Lower vehicle.
  5. Connect the negative battery cable.
Jan 12, 2010 | 2000 Jeep Grand Cherokee
Where is the oil sending unit switch located on a 2003 4.0L jeep grand cherokee?
To install:
  4. Lower vehicle.
Oct 08, 2009 | 2004 Jeep Grand Cherokee
Where is the oil filter on my 2004 Audi A8L located?
your oil filter is under the front end you have to move engine splash shield.under the front bumper.
Jun 19, 2009 | 2004 Audi A8
Where is the oil pressure sending unit on 2004 dodge stratus?
per the Haynes manual for the 95-05 Dodge Stratus on the 2.0L & 2.4L DOHC 4 cyl engines, the oil pressure sending unit is located at the left end of the rear side of the block. On 2.4L SOHC 4 cyl engines, the sending unit is located at the left end of the rear side of the block. On 2.5L & 3.0L V6 engines, the sending unit is located on the oil filter housing, on the front side of the block. On 2.7L V6 engines, the sending unit is located at the left end of the rear side of the block. To access it, remove the heat shield.
Jan 23, 2009 | 2004 Dodge Stratus
Heating & Cooling Logo
22 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
