Question about Asko W6221 Front Load Washer
W 6221 stop working
My W 6221 is about 5 years old. It stopped working, it will not start the wash cyle. if I click the timmer button off and on some times it will sound like it is trying to drain. There is a click sound when I press the start/on button but the machine doesn't start, fill or spin
  • Anonymous Dec 19, 2007
    Same problem, replaced control card, no help.
  • Anonymous Apr 23, 2008
    W6221 - all functions stopped working. Have power as indicator light turns on.
    Opened top of unit and saw the control circuit card had a burnt power supply unit on the PC board. Replaced the control circuit card with a new one.
    Checked capacitor at the power input connections. Electrical meter indicated .4 on the 200 micro farad setting.
    Question: What caused the control circuit card to short circuit and how can I be sure when I restore power I won't short circuit the new card?
    President:
  • 1,294 Answers
Suggestion: Plug off the wall; open up behind. Take a good look to see if all the electrical connections are fitted well into their respective places, and that nothing has come loose. The fit should be tight, or it will just come off when the machine vibrates...
Posted on Nov 26, 2007
Why does my 5 year old machine keep stopping mid-cycle?
Check the door sensor and clean it. Or one or more(i believe there are three) of your tub sensors may be bad.
Sep 11, 2015 | Washing Machines
My Kenmore he front load washer stopped at the rinse and spin cycle. I don't know the model but it only a few years old. It made a load noise before stopping. I attempted to get it going again wit
Kenmore front loader. stopped at rinse. First ck to see if you washer works at different settings if so its very possible its your timmer or what called the wig wag or solonoid this switches the machine to spin & rinse. A basic service call should resolve your problem.
Jan 30, 2012 | Washing Machines
Timmer switch turns on but pump does not start. I have to go out and turn off timmer swith for a few seconds and turn timmer back on and pump usually starts auto matically. Some times when timmer switch...
The flashing re light is trying to tell you what is wrong! It will flash 2 to 9 times and you need to count the flashes and then refer to the troubleshooting chart on page 27 of your owners manual.
To me it sounds like your pump loses it prime some I would suspect a leak on the suction side of the system.
http://www.inyopools.com/manuals/210/IntelliFlow4x160_OM.pdf
Jul 20, 2011 | Pentair 4-Speed 230v IntelliFlo 4x160...
Kennmore 110.22422. 100 hummms when reaching the spin cycle
your timmer button has given up replace the timmer and it will be fine
Jun 19, 2010 | Kenmore 22422 Top Load Washer
25 years old,top load. put on new belts 3 weeks ag...
Timmer may be bad. Bad contacts on timmer for spin mode. Check to see if timmer goes though cycle to end. Also check lid switch.
May 17, 2010 | Washing Machines
Whirlpool washer will not spin
sounds like the timer is shot.
Apr 30, 2009 | Whirlpool Washing Machines
Stops between rinse and spin cycles giving a ld code..
ld sure sounds like lid switch problems. Suprised to see this so soon, but I did see one come apart on a fairly new Whirlpool. Luckily, it should be easy to check. Unplug the machine first.
Apr 29, 2009 | Washing Machines
Maytag front load washing machine Model MAH5500B misses spin cycle
either balance load sensor or machine failing to drain in the allocated time, check pump/filter for blockage
Nov 01, 2007 | Maytag Neptune MAH5500B Front Load Washer
Washing machine gone crazy
Does the timmer advance at all? Timmer motor. on timmer if timmer not advancing.
Mar 30, 2007 | Frigidaire GLWS1233A Top Load Washer
Asko W6221 Front Load Washer Logo
285 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
