Just replaced power supply on cpu. When I turned the computer back on the modem stopped working the dsl light flashes green then red. As soon as the computer is turned off the dsl light is solid and I get a wi fi connection through my router.
  • 6 more comments
  • futhermucker Jul 30, 2009
    Even though my computer comunicates with the router could it still be the card?
    Also it still lets me go to the modems ip address but says the adsl line is not connected.
    The phone line goes to the modem then modem to router then to the cpu but the only time it(the modem) works is when the cpu is off.
  • futhermucker Jul 31, 2009
    Ok I did as you said with no success. I pulled an old network card from an old cpu put it on this one and nothing. It has to be some issue with the power. When the power supply my cpu is plugged into is turned off I get a connection. As soon as I switch on the power supply the light on the router for my cpu lights up then I power the cpu on and when it shows the windows logo the light on the modem flashes. The only way to get a dsl connection is to power down but only when the power supply is shut down about a minute after does the modem light stay solid. Is it posible I forgot to connect a harness from the power supply to the motherboard (one small square on motherboard one large rectangle and one to each hard drive/cd drive)or the replacement power supply doesn't completly fill the gap the way the old one does, I was only able to install two screws. Maybe its not grounding correctly.
    I also tried turning the power supply on with the computer ethernet unplugged. I get the same result without even turning the cpu on?
    Sorry didn't want to post that three times. I only have my cel.
  • 1,684 Answers
It sounds like your network card was damaged by a power surge, most likely what brew the power supply too. When you power up the PC now the network card tries to start and kills the network line going to the router, when PC is off the card does not short and the router works like it should. You should be able to put a new network card in a open slot in the pc and connect that one to your router.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Jul 30, 2009
  • Buddy Mcsparrin Jul 30, 2009
    Hello again,
    Does your phone line go connect to your computer such as to a phone modem? Something is interrupting the dsl data line and that is what is causing the blinking lights. Your previous info stated that when you turned the PC on the modem lights went red and when the pc was off the light went back solid and you could connect with WIFI. How are you getting to the router? re you using the same PC or are you connecting wireless?
    First I would unplug the PC from the router and turn the router on, check the light and see if they are green and all looks ok. I would bet that if you then plug the cable from the router back into the pc when its on that the router lights would start flashing red. That would show what was first described, replace network card in PC.
    Try that test and let me know.
    Buddy
When i connect the dsl cable to it the dsl light starts flashing green then red
Put tinfoil over your splice connectors and filters as they leak signals that totally confuse your modem. Never leave any bare wires, I tinfoil the entire modem to prevent the neighbors from hacking me. I don't use wireless, only CAT5 ethernet cable.
Jan 02, 2013 | Gateway 2wire 2701hg Wireless Dsl Modem
Tip
Troubleshooting DSL Modems
Ever look at your DSL Modem and wonder what all those lights mean? Why do some flash, while others remain solid? What if your lights are different colors? How do you tell if your DSL Modem is working correctly?<br /> <br /> Each light on your DSL Modem represents a function. The light is an indication of whether that function is working properly. Sometimes the placement and title of each function can vary by modem manufacturer, but they are pretty standard in interpetation. If you look closely your modem, you might find that each function is labeled in small print to help identify them.<br /> <br /> A standard DSL Modem has a light for power, internet, ethernet, link and wireless connection. A healthy DSL Modem will have a steady green light that does not blink or flutter for all features other than internet, ethernet and wireless. A flashing or fluttering light indicates movement and useage. When you are connected to your DSL Modem wireless, the light for this feature will blink indicating a connection and/or active useage. If the internet connection is working properly the color of the light will be green. If the connection is working but experincing a problem the light can turn to yellow or orange. If the connection fails, the light on the DSL Modem can be red or absent depending on the problem causing the trouble. If your service is turned off by the provider, more than likely the light will be "off".<br /> <br /> If your lights turn a different color, are absent or your internet connection fails try power cycling your modem before reporting the trouble to your provider. Power cycling helps the DSL Modem to reset its connection and repair your internet services.<br /> <br /> If you are using a DSL Modem alone to connect to the internet (no additional router) you can power cycle it by first turning off your computer and then unplug the modem itself from the power source at the wall. Wait for 1 to 2 minutes and then plug it back into the power source and wait for the warm up to finish before rebooting the pc.<br /> <br /> The DSL Modem should go through the normal warm up procedures of blinking lights, making them all stable and solid green ect. You will know when its finished warming up when the features are set at solid green (other than eithernet, internet and wireless connection as explained above). When the modem finished the warm up, reboot your computer and check your internet connection.<br /> <br /> Power cycling your DSL Modem can help keep your connection healthy and running at optimal speeds.<br />
on Mar 30, 2011 | Computers & Internet
Modem d-link dsl 2640U status : connected Power : Red Light LAN (R1) : Green Light DSL : Green Light Internet : Red Light seems that the modem has crash! can't even rest it ! so what should i...
hi
I am techbuddies from fixya .i would like to give a try on your issue.
first of all shut down your modem and your computer then unplugged cables that goes from modem to your computer once it is done then wait for 30-50 sec and then replugge all your calbe and then first turn on your modem and then your computer .This kind of method is called as power cycle of modem.
Once you have done that then check that wether is works or not if not then try to check that is their any kind of red X on your computer on right hand side bottom ,if yes then on run type devmgmt.msc then click OK and the you would be able to log in to device manager .Once the device manager is open look for network adapter click on the plus sign and then under lan right click and click on to enable it .
check wether your internet is working or not .
Also check what is the ip address if comming on your computer .
Inoder to reset your modem .check is their any small hoel in rare-end of the modem if yes please insert a smal pin in to it and press it untill all light flash on and off .
if still the problem comes get back to me on fixya
Sep 09, 2011 | D-Link DSL-2640B Wireless 11/54Mbps ADSL2+...
My 2wire has the power light red and the ethernet green and th wireless solid green and the dsl off and the internet off....what can i do
I had the same problem on the Gateway 2701HG-B supplied from ATT for use with their DSL service. From searching the web, I learned these variety of modems apparently have an expiration date on the power cord at about 18 mos to 2 years. Mine is almost exactly at 2 yrs.
I replaced the power cord and now it works fine. You can order the OEM replacement from att e-store or try Radio Shack for a universal cord.
May 20, 2010 | 2wire (1000-000057-000) Modem
2Wire 473 router problem
Take the modem and plug it into a GFCI outlet. You can find one in the bathroom or the kitchen.
If the power light comes on solid green and the dsl comes on red then the modem is good. Was it plugged into a power strip by the computer? If so, plug it straight into a wall outlet.
If the power light comes on solid red then the modem has hardware failure. I would contact your ISP and have them replace it if it is still underwarranty.
Mar 23, 2009 | 2wire (1000-400108-001) Router
4100 Light flash no connection
*if the DSL light on your modem is blinking..
TRY: using different filters// check physical connection
IF: not resolved call ISP for a trouble ticket for their line department
*if all the lights constantly blinks
DO: purchase new modem, maybe deffective already or check if modem still under warranty so provider can replace it
NOTE: plug 4100 modem directly to the back of the computer tower without the linksys router and check if light status still the same...
HOW: cable connected from back of modem shud be plug in directly to port at the back of PC tower.. completly remove linksys and turn linksys off..
Jul 16, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
I have tried to replace my dsl modem with a wireless modem router (thompson speedtouch 585) using aol.After dissconnecting the old modem I followed the step by step instructions supplied by aol.All seemed...
Try contacting the DSL provider, if not All-Operatingsystems-Lost.
U may try Start-controlpanel-network connections-local area connection-properties
Ensure correct card under connect using.
click on configure.
click on advanced.
reset to auto detect
click ok
reboot
There are sometimes issues with the PPPOE. the DSL provider should be able to resolve this.
Good Surfing
Mar 16, 2008 | Computers & Internet
Blinking light on the DSL modem.
Unfortunately it sounds like the modem may need to be replaced. I had the same issue. Even after doing a complete shutdown, resetting all the cables, restarting the modem and then the computer, it still did not work. After you get the modem replaced, I would suggest you get a spare, possibably from e-bay, so if this happens again, you will not be without DSL Service.
Dec 17, 2007 | Siemens SpeedStream Modem (4100) (SS4100)
Computers & Internet Logo
197 people viewed this question
David Payne
David Payne
