Lexmark X1240
WD-40 works the best, as most parts would not be damaged by it. Try to figure out by looking at it when it is printing what parts are rotating (this may or may not require some disassembly). If you decide to spray something that rotates (like the hubs of the little rubber wheels that move the paper), be careful to use it sparingly and don't spray it all over everything. A spray of 1/100 of a second or less will usually do the job. Good luck.
Testimonial: "Thanks! Getting the case off in order to apply lubricant is proving to be the biggest challenge."
SOURCE: With what can I lubricate the legs onmy aluminum Mafrotto tripod?
Dear Winnieg,
I would avoid using a lubricant on your tripod legs, because you run the risk of the legs not tightening down anymore. I would try cleaning the tripod thoroughly first, because most of the time this is caused by dirt. If that dosen't work I would try rubbing on a small amount of candle wax onto the legs, and then wipe the legs down with a clothe.
Sincerely,
Allan
Go Ahead. Use Us.
SOURCE: 2000 Silverado L/T Z71 4X4 Lubrication Diagram
Lube points should be: All moving joints in suspension. Ball joints, idler arm, tie rod ends etc. On 4X4's, all universal joints on drive axles (excluding C/V joints... just inspect boots) All slip-joints and "u" joints on driveshafts. Many of these items may not have zirk fittings on them from the factory. If the component has a plug installed, it should be removed & replaced with a fitting. If there is no place for a fitting, when the item wears out, the replacement will have a fitting.
SOURCE: kitchenaid K5-A mixer ''growling''
Hi . Chevron FM ALC EP-2 grease is what you need for the lubricant. This has a Mineral Oil base, allowing for it to, at some time, drip into whatever it is that you mix without concern for your health. From what I can, tell this is the only thing that needs to be done. Clean out as much of the old grease as possible.
Goto www.mendingshed.com and download for free a Kitchenaid Service Manual that will cover your mixer.
If this solution has assisted you, please rate it. Good luck! ricardok45
SOURCE: bajaj boxer motorcycle 100cc gearbox
Oil changes are all you need to do for engine lubrication. 10w40 motor oil is what goes into the gearbox. NEVER use synthetic lubricants in the engine. Thay can mess up the clutch. Please rate my answer. Thanks.
Hi Tilda Wald, we want to help you with your question, but we need more information from you. Can you please add details in the comment box?
Not sure on your scanner but I would think if the scan head moves along two metal rods I would get machine oil (usually used in sewing machines) put a few drops on a tissue and then rub tissue along the metal rods. And then let us know if you indeed have rods like I describe and if it helps with the screeching.
Hey Brett, I did one rod with the machine oil. Everything else seems to be tucked behind plastic. I will look for the other rod, and keep searching for screws to get the case off. Thanks to everyone for their time.
Good idea Brett.
