Question about Garmin Edge 305 - LL Bean
When I training indoor my edge 305 doesn't show me speed and distance even if the cadence sensor works properly
  • Jean-Luc Steffann Sep 27, 2010
    Do you capture sattellites when you are in this situation ?
    If so, then this is normal as sattellites GPS do not detect any movement.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 81 Answers
Try start your training device outdoor for a check. If then it is working, the issue is about the device needs to see sattelites to perform measurements and register speed.
You may try switch GPS device off, which is said to be an indoor mode for training.
Menu>Settings>System>GPS Mode
Posted on Oct 11, 2010
How to use garmin edge 705 cadence/speed sensor
you must disable the gps speed and enable the sensor
Feb 02, 2010 | Cadence Garmin Edge 705 Bundle W/spd Hrm...
Can not get speed and distance to register although cadence does register
Looks as if your GPS is turned off (GPS transceiver). Or the cadence is OK but the device on the wheel to capture rotation is not well installed.
See GPS device via
Settings>System>General>GPS and check that GPS is ON
Dec 09, 2009 | Garmin Edge 305 GPS Receiver
I used my 705 on my trainer and it did not record distance or speed like my forerunner does. The 705 works fine on the road
the Garmin Edge series rely on GPS to track your location from point A to point B thereby calculating your speed and distance. Its no different from any other GPS unit which require a clear view of the sky. It does not sense wheel movement, so using any GPS on a trainer will show no movement and using it indoors will give you a bad signal. The sensor on the crank used on the Edge 705 is only for cadence and not speed.
Jul 16, 2009 | Garmin Edge 705 Handheld GPS Receiver
Cadence does not register on edge 705
This is probably a pairing problem. Device and cadence should be paired. Pairing is often lost when changing battery.
Pairing the Edge 305 and sensors
Once you have installed the Garmin Edge 305 and the cadence sensor they need to be paired. As they communicate wirelessly with each other the Edge needs to connect to each sensor before it can receive input from it.
The initial pairing needs to be done away from other wireless systems this allows the Edge to pick up the sensors it is supposed to be monitoring. This is a little like black magic, but it seems to work quite easily.
The cadence sensor has a small press contact which puts the sensor into pairing mode. The HRM just seemed to connect by itself.
Subsequent pairing is much faster as the Edge 305 seems to remember which sensors it is paired with. If you have problems or need to change one of the sensors then you can use a setup feature to either turn the sensor off or to re-pair it.
Jul 14, 2009 | Garmin EDGE 705
No buttons work including power and the device is frozen.
My husbands did too. Then like three days latter it restored itself
May 24, 2009 | Garmin Edge 305 Bundle Includes Hr And...
Garmin 305 Edge and GSC 10 not receiving one another
Solution copied from Garmin
Feb 22, 2009 | Garmin Edge 305HR GPS Receiver
Recently purchased a edge 305cadenec/heart rate monitor.cadence is not coming up on the monitor. every thing else is working. Pushed the reset button on the sensor the speed light was fine the cadence...
Suggest you first try changing the battery in the sensor...then reset, then rescan for it on unit. It seems like quite a few have been shipped with dud batteries.
Oct 07, 2008 | Garmin Forerunner 305 GPS Receiver
Distance and average speed don't compute.
My solution included changing the battery in the cadence sensor (GSC10). You might not need to.
1. After changing battery, take bike outside. Turn on Edge 305 to acquire satellites (might not be necessary..)
2. Press reset button on GSC10. Should see red/green flash.
3. On Edge 305, go to SYSTEM.
4. Scroll down to ACCESSORIES.
5. On Accessory page, scroll to bottom, under Cadence Sensor, and press RESTART SCAN.
That fixed my Edge 305 - cadence and speed do appear now.
Apr 07, 2008 | Garmin Edge 305 GPS Receiver
Garmin Edge 305/GSC10 Cadence and speed sensor
Had the same problem. Here is how I fixed it.
1. Changed the battery in the cadence sensor. (GSC10)
2. Turned on my garmin 305 edge outside to acquire satellites (probably not nec but did it anyway)
3. Pressed reset on the GSC10, saw red/green flash (what order?)
4. Here's the missing step: On the Edge unit, go to SYSTEM.
5. Scroll to bottom, choose ACCESSORIES.
6. On acc. page, go to bottom, under Cadence Sensor, to the option RESTART SCAN. Press That. Now your cadence and speed should work.
Feb 23, 2008 | Garmin Edge 305 GPS Receiver
Garmin Edge 305 - LL Bean Logo
158 people viewed this question
Top Garmin Cycling Experts
SHARCNET-USA
SHARCNET-USA
perdue40
TO Lady
Are you a Garmin Cycling Expert? Answer questions, earn points and help others
