Question about Garden
Replacing the belts on a 20 year 8/26 MTD snowblower
Is there a way to get at them from the bottom or do I need to take the auger housing off? The transmission belt is blown and I thought I would do both at the same time as they have never been changed.
PS couldn't find snowblower in the subcategories
  • afdueck Jul 31, 2009
    Kind of thought so, thanks.
  • 26 Answers
You will need to take the housing off.
Posted on Jul 30, 2009
Replace snowblower belt
Locate the two top auger housing fastening bolts and remove. The auger housing will tilt forward and then lift the housing off of the bottom 2 bolts/bushings. You will need to support the traction frame as it will try to fall onto the handles.
Feb 27, 2017 | Mtd Garden
Tip
How to replace belts on a snowblower and removal of auger from housing.
hello,, How to replace the auger drive belts on a MTD,Yard Machine,and other two stage snow blower,that don't allow enough room to slide belts between the pulleys.
1.Tilt machine up on front end to remove the bottom frame cover,there should be six screws to remove,tilt back up right.
2.Remove the chute crank from the left handle and from the shoot.
3.Remove the black belt cover,there should be three screws.
4.Remove the support guide bracket,that the cable is running through,and remove cable end from idler pulley arm.
5.Remove belts from upper pulleys. (hint if there is a bolt holding the pulleys on it is easier to remove the bolt and slide the pulleys off to be able to remove the belts.)
6.Remove the six bolts and nuts holding the front half to the back half together,slide front part out to be able to remove old belts and install new belts. (hint make sure you get the new belt under the belt keeper on the bottom.)
7.Reassembly in reverse.
8.Set of two belts 0.312x34.75, part number 954-040B, $30.28
This first part is for replacing belts.
To remove the auger assembly completely follow these steps.
1.After removing the belts,and separating the two halves, remove the bolt holding the pulleys on,pay attention how bolt comes off and the way the washers are on be sure and put back on the way they come off.
2.Remove the pulleys and make note how they come off of the adapter pulley.remove pulley note how comes off.
3.Remove the bolts and nuts on the side of the housing.
4. Pull the auger out and place on work bench,making note how the end parts come off.
5.Remove the shear bolts to get and slide augers off, be sure and mark which way they turn as not put back on backwards.
6.You can access the auger gears by removing the bolts,to make repair.
7.also check the ball bearing in the rear housing where the auger shaft goes through to make sure it is not egg shape,if egg shaped needs replacing.will cause belts not to stay on and jump off the pulleys.
8.Check the end hex flange bearing (the plastic piece) to see if it is out of round,if is replace it.
9.Also you can download your manual if you don't have one depending on your model and number.
hope this helps,DON'T FORGET THE 4 THUMBS UP,,,any comments welcome,thank you.
on Feb 27, 2010 | Garden
Was wondering if anyone would know the age of this snowblower and hp output, its for sale and before I buy I would like more info about it. It says Snow Champ 5/24 power propelled
Looks like the UP605/8461 was made for Aircap by MTD for just 1 year (1989)... the equivalent MTD model number was: 319-550-002
Here are some links to sources for available parts along with obsolete replacement/aftermarket recommendations:
MTD UP605 8461 319 550 002 Snow Champ Self Propelled Snow Thrower 1989...
MTD 319 550 002 UP605 8461 1989 Parts Parts Diagrams
The parts that go bad the most often are the wear skids on the outside of the auger housing, and the shave plate along the bottom edge of the auger housing.
Carburetors tend to gel up from the 15% ethanol the farm lobby got congress to put in all our gasoline, but that's not really 'going bad' - often you can actually clean the 'varnish' out of the orifices and passages with aerosol carb cleaner... shops would have a heated (about 105F) ultrasonic parts cleaner, but it's usually cheaper for DIY'ers to buy a new carb.
Mar 08, 2015 | Garden
Auger on snowblower doesn't engage
how do I find good anime movie on Netflix help me fam
Feb 11, 2015 | Mtd Garden
MTD 8/26 snowblower
Either there is a belt or a chain off, or the linkage became disconnected or there is a pin sheared. Take one of the three. If you have power spinning like you said then those are your choices! Best of luck to you. Hope you beat the weather!
Auger belt keeps coming off when engaged with new belt or old
Put a straight piece of metal or wood on the top pulley and slide it down. Both pulleys have to line up if you slide it down and it hits the bottom pulley you will have to replace or shim the pulley (top or bottom) with washers so they are perfectly lined up
Jan 14, 2014 | Mtd Snowthrower Snowblower 5 24" Parts...
I have a MTD 5/20 snowblower that won't engage in Forward. It will transfer to neutral and reverse, but I can't any forward power. If I tilt it forward, the wheels will spin. I installed a new belt and...
ALL SNOW BLOWERS HAVE WHAT THEY CALL A FRICTION DISC DRIVE IT SOUNDS LIKE THE FORWARD SIDE OF THE DISC IS WORN OR THEDRIVE WHEEL HAS A RUBBER DRIVE RING THAT IS WORN. IF YOU REMOVE THE BOTTOM PLATE YOU WILL SEE TWO DRIVE WHEELS ONE IS JUST A METAL DISC AND THE OTHER LOOKS THE SAME BUT HAS A REBBER RING FOR GRIPPING THE DISC TO MOVE THE BLOWER FOREWARD, WE END UP REPLACING ALL THE DRIVE DISC AND DRIVE WHEELS ON OURS EVERY SPRING THE FOREWARD DRIVE TAKES THE MOST PUNISHMENTTHERE FOR WHEARS OUT THE FASTEST. MTD HAS A WEB SITE FOR ORDERING PARTS AND ARE NOT HARD TO INSTALL.GOOD LUCK LET ME KNOW HOW IT GOES
Feb 05, 2011 | Mtd Genuine 9460897 Snow Blower Auger...
Auger stopprd working on an MTD snowblower.
The manual has a step by step procedure for adjusting the cables for the auger, speed selector and drivewheels. One socket wrench and about 10 min should do it.
My Yardworks is an MTD product and it's manual should be similar to yours. If you lost it, you can download it from MTD's site.
Dec 23, 2008 | Craftsman Garden
Garden Logo
481 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
