SOURCE: my lipi 6306 line printer showing error "paper
Dear Sir,
Problem in paper calibration, u can go through given details 1) Offline, Test, Daig, Calib, Paper out, Enter, then u see Remove paper. then press enter. sum reading will come (4.something). After insert paper, (2.something). And Save == Offline enter, config enter, configuration enter, save enter, Power up. enter.
Next option 2) U can check the paper out sensor front one black sticker missing.
Parashuram Patil
SOURCE: paper moving fault
If the paper is moving freely in the printer and you are not experiencing any paper jams etc it may be possible the error is being indicated falsely.I would recommend firstly to ensure the tractor feeds on the printer are clean and free from a build up of paper dust etc. As the paper motion sensors are located on the tractor feeds.
If after the printer is cleaned the error is still see the problem may be related for a setting for the Paper Motion Threshold in the printer. this is the point at which the printer detects an error. This value is dependant on a number of factors; Paper Type, condition of the printer etc.
Once you have completed the above sequence press and hold down the LINE FEED and ENTER KEYS to turn tech access off, you can then test the printer. If the above does not clear the message try increasing the value further.
If the problem persits you may have a faulty paper motion sensor.
