Question about Numatic Henry Bagged Canister Vacuum
Henry's switch has come out.I found the red switch and 2 bent bits of metal. How do they fit together to make him work again?
    President:
  • 389 Answers
Rather than coming out, it sounds more like the switch has come apart. It also sounds like you haven't got all the bits. Even if you'd got everything, and knew how to assemble it, there's a good chance it will come apart again anyway. The only safe thing to do is get a complete new switch.
I value your feedback, so please remember to rate this response. Good luck!
Posted on Jul 30, 2009
Henry hoover brush not rotating so not picking up
Check the ends of the rollers for a build up of hair/thread, etc between the bar and the ends. remove if found.
Dec 29, 2012 | Numatic Henry Bagged Canister Vacuum
Hi, last week I bought a new Henry vacuum with autosave, now the autosave feature is not working. The red indicator light does not light up and the motor does not change speed. Any ideas, other than...
Sadly you need to return to dealer, any problem contact Numatic (www.numatic.com), who supply it with a good 2 year warranty, which the dealer should support. This is a fault I see about 1 in 100, so you are a little unlucky. It will need a new switch and can easily be fitted by the dealer. With Henry's usual life expectancy anything from 5 -20 years it is well worth getting sorted.
Feb 06, 2011 | Numatic Henry Bagged Canister Vacuum
New Henry Numactic Moter - How to wire?!
on the motor there are 2 connection together and one on it's own and on the brushes 1 each ignore these .and on the motor fix to the 2 tab one that you can see a wire connection on and then fix to the other side of the motor .this worked for me
Mar 11, 2010 | Henry Numatic "" Canister Vacuum
My Old Henry hoover is making a VERY loud noise when switched on! Its still works but very loud, please help!
Most likely the motor bearings have worn out. You can fit a new motor quite easily, but if you need to pay someone else to do it for you the labour plus motor cost will probably make the job uneconomical. Sorry to be the bearer of bad news...
Feb 18, 2010 | Numatic Henry Bagged Canister Vacuum
Mysterious metal piece under vacuum motor?
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
fdgf
May 07, 2009 | Bissell 8910 ProHeat Clear View Upright...
Formed metal wire inside handle
this bent metal wire goes right at the surface in a grove where the two pieces of the handle go together where your fingers grip it. I think it is to discharge static electricity.
Mar 27, 2009 | Oreck XL Ultra Bagged Upright Vacuum
I have a Henry 200 and the red on/off switch is stuck in the on position can it be fixed
Well... It probably can't be fixed, but it can easily be replaced. Depending where you are, spares are usually readily available. If you need more guidance, please post here again, and I'll see what I can do to help. Good luck!
Mar 03, 2009 | Numatic HHR-200 Henry Hound Bagged...
Electrical Burning Smell from Henry HVR200 Vacuum Cleaner
Hi! Highly unlikely that you need a new motor.  Highly likely that you need new carbon brushes.  The smell is caused by excessive sparking between the worn brushes and the copper commutator segments.  Most carbon brushes (and from memory I suspect this includes Henry's) have a copper wire buried in their last few millimeters, and you really need to change them before that becomes exposed.   The longer you run it like this, the more likely you are to damage the commutator, so change them sooner rather than later.  When you change the brushes, you can smooth off the commutator with very fine abrasive paper (the objective is to smooth it, not scratch it!), and then blow all the dust away (or **** it away if you have another vac, of course).  Incidentally, you don't say if you are using a paper bag in your Henry. Some people, because the top-hat filter is so good, try to manage without a bag.  This is false economy!  You should always use a bag. I hope this helps! I value feedback, so please remember to rate this response.
Feb 28, 2009 | Numatic Henry Bagged Canister Vacuum
My henry hoover has just stoped working its not the fuse do you have any ideas
I had exactly the same problem.there were no burning smells coming from it so nothing seemd obvious.I then took it apart and checked that all wires were connected,which they were.Then decided to check the plug.After replacing the fuse I chopped the cable of (as it is a seald plug) and connected up a new one.Hey Presto,Henry was alive again.Hope this helps.
Nov 03, 2008 | Hoover Vacuums
I have got metal numatic tubes that are stuck but wont come apart
no easy solution. try heating tube in hot water and then brute force
Sep 07, 2008 | Hoover Vacuums
Numatic Henry Bagged Canister Vacuum Logo
220 people viewed this question
Top Numatic Vacuums Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Numatic Vacuum Expert? Answer questions, earn points and help others
