Question about Hunter 21617 Palermo Brushed Nickel Ceiling Fan
Fan clicks when button is pressed, no rotation. Light works.
Same problem as the others...installed the fan new, the light works (so obviously power is getting through). However, when pushing the button on the remote, the fan will not activate. There is a clicking sound, so some signal is being received.
All searches have led me to the conclusion that it's a defective receiver (and not the motor). Hunter said that they will replace it, but it's on backorder for weeks! I'd buy it on my own if I could find the part somewhere.
Hunter Part # is 87075-01-000
  • 867 Answers
From your description, i would say its the relay swith
Posted on Jul 30, 2009
The remote does not always control the light or fan. The light on the remote does not always come on with button depression?
The remote may need corrective therapy to restore operation. If the light does not turn on when a button is pressed, suspect batteries need to be replaced but the problem could be a stuck button. Remove the batteries and press all buttons to "unstick" them, then install new batteries and test operation.
Erratic light/fan selection can be due to power interruptions. If you disconnect power at the source and wait a few minutes before reconnecting, light/fan control may be restored.
May 01, 2016 | Dryers
Cp9430r
Fixed Hunter ceiling fan with remote light pin out wiring 9 wire plug search words
Hunter Ceiling Fan with remote, fails to turn on light, fails to turn on fan..remote receiver is Cp9430r
1) Test your remote, Hunter uses Radio Frequency remote, point RF remote one inch from antenna of working AM radio, press each button on remote, each button will produce static sound from AM radio, if no sound..check battery wiring or solder connection on loop antenna of remote. If no sound on one or more buttons, disassemble and wash key pad with dish soap, rinse and fan dry, retest. If still one button no work apply graphite paint to button to rebuild conductivity of button.
2) Cp9430r receiver is below fan and above light. Remove light assembly, check receiver dip switches, mine was #5 On 1~4 Off, check remote control dip switches in 9v battery compartment also set #5 On 1~4 Off, new 9v battery still no Fan reversal "click" sound heard coming from the large Blue fan reversal relay located inside the Cp9430 receiver. All other buttons control transistors and will make no sound even if they are working.
3) Disassemble / unplug 9 wire plug from Cp9430r receiver, place receiver on wooden table, 9 wire plug has two empty pin squares, one empty in the center, the other empty we will call #1 ..counting clockwise #2,#3...#4,#5..#6,#7and finally top center next to empty #1 is #8. Now #8 is 110v hot/black ...& #4 neutral/white.
4) Shock Danger..carefully apply ac volts to pins #8,#4 use tape if needed, locate quad operational amplifier i call it radio receiver chip HA17324 on board, google HA17324 Datasheet, locate leg #14 it is across from leg #1. Locate small yellow ceramic capacitor very near leg #14, use capacitor's neg as neg for voltmeter, test volts at #1,#7,#8 and #14. My #1 was 3.1v, #7 3.2v, #8 3.25v and #14 .01v ...why #14 so low? I monitored each leg while pressing remote control buttons...no changes. **Desperate, I sparked (1/2 second or less) #14 with 3.14v from positive leg of yellow capacitor** and retested all legs, no change except now #14 rests at .02v and jumps to 2.5v~2.8v when any button on the remote is pressed then rests at .02v. Now Lights work, Fan speeds work, Reverse rotation Works :-)
Pin Out on 9 wire plug, #1 Empty pin, #2 Alternates w up/down fan rotation, #3 goes to 5uf fan capacitor other side of cap goes to white/neutral AC Line, #4 AC Line neutral, #5 goes to Triac? speeds? , #6 Alternates up/down fan rotation goes to up/dn blue relay, #7 goes to up/dn blue relay looks to be AC hot looking for fan probably paired with #3 changing sides at up/dn blue relay, #8 AC Line hot in. Why did **sparking** work, smarter people might know, i think a small spark got stuck in the chip and sparking helped the chip release it out. No electrical education, novice. Jer. 51 8,9 and 11
Feb 24, 2012 | Hunter (25417) Ceiling Fan
Hi. Last Friday we had a new Kenmore stainless steel range hood installed along with a new range. Yesterday the range hood fan and lights would not work. The fan does not come on at any speed. The lights...
Some installers plug the fan/light into an outlet in the cupboard above. Check to see if that has power. Some of the outlets are behind a panel in the cabinet above and you have to remove the screws. I have seen the plugs laying in the cabinet just like they had never been plugged in. Yours obviously was plugged in but maybe fell out. If the fan/light is hard wired than you should make sure the power is turned off at the breaker box and then check the wiring inside the box to make sure it is wire nutted together and is holding. I would also check that the breaker for the fan/light is still putting out power. These last two might be a little tricky if you have never tried them. The breakers sometimes go bad but look like they are set. If the whole hood fan is not getting power it is probably time for an electrician or the people who installed to come back.
Aug 25, 2010 | Kenmore 52153 Stainless Steel Kitchen Hood
Can't turn my lappy on
Damaged Bootstrap You need to take it for repair
Aug 16, 2009 | Acer Aspire 5520-5908 Notebook
Bottom lights do not turn off
If you have a remote for the fan and light, then it makes sense that only one wall switch operates as a master switch. Then as far as why the remote doesn't operate the lower light, the question I would have is whether the remote you have for the new fan came with it or not? If the remote you have has a button for the upper light and a button for the lower light, then you need to make sure that the reciever in the fan has wires for both lights. On the receiver there should be a black and white for the power and neutral coming from the switch. Then there will be a white wire for the neutral to the fan, a black wire going to the fan, and probably a blue wire for one of the lights. If there is another wire on that reciever (it may be orange or some other color) that would be the wire for the other light. That would be simple... four wires from the fan to four wires coming off the reciever. What you might have is four wires coming from the fan, and three wires (other than the black and white which connect to the wires from the switch) coming from your reciever. The way around that is to connect the two lighting wires from the fan to the one lighting wire from the reciever. Then when you press one of the light buttons on the remote, the upper and lower lights will always come on together. The other possibility is that there is a problem with the lower light kit itself. I would first check the wiring inside the canopy of the fan where the receiver most likely is.
Jan 24, 2009 | Hampton Bay 52 In. White Redington...
Fan is Erratic
Ceiling fans with wireless remote controls have an electronic receiver installed in the fan, which controls the light, dimming, and fan speed. Sometimes the receiver goes bad and needs to be replaced. If you have had any power outages or power surges, they may have fried the receiver. I've noticed that my ceiling fan light turns on when the power is restored after a power outage. Now, whenever my power goes out, I shut off the light switch that powers my ceiling fan so It doesn't experience a surge to to the controller when the power comes back on. I've purchased new receivers on eBay and Amazon to replace my blown remotes and receivers.
Sep 07, 2008 | Hunter 22451 The Brookline Brushed Nickel...
Canon LV-S1 New bulb but won't power up
Have you cleaned the filters? In this situation, the fan and power shuts down even before the bulb lights up and heats up the unit, but perhaps the unit can detect clogged filters.
You can download the manual here if you don't have one. Instructions for cleaning the filters are on page 37.
May 20, 2008 | Canon LV-LP12 Projector Lamp for LV-S1,...
Hunter 21617 Palermo Brushed Nickel Ceiling Fan Logo
655 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Brandon Berry
Brandon Berry
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
