In the cars, the engines use liquid cooling which comprises of various components and thus the system is a bit complicated. Here are a couple of tips you should follow to keep the Hyundai Verna engine cooling system running fine so that it doesn't surprise you in the middle of nowhere, check out the mention link
=> Top 4 Tips to Maintain Your Car Cooling System
=> How to Maintain Car Cooling System
SOURCE: My hyundai remote for Hyundai Verna is not
Go to carhelpsite.com it is free as long as you click on 2 of the ads at the website then your questions will be answered by an ASE certified mechanic,you don't have to buy or fill out anything on the ads,so help keep the site free.
SOURCE: L/B green signal - Hyundai Verna 1999
I have the same problem with my elantra 1999 you should check oxygen sensor or replace it but before that cut the yellow from the oxygen sensor if the problem gone then replace it else i dont know but try
SOURCE: my hyundai verna"s engine cooling
Before pay someone to fix the problem, make sure that:
Fan blades are tight with motor shaft.
Fan blades are not jammed.
The fan motor is O.K.
The fan fuse is O.K.
There is no temperature sensor code.
This will narrow the diagnosis. Hope will help.
