Question about Vornado Silver Swan Table Fan
Noisy table fan - Vornado silver swan
Hello, I have had 2 Vornado silver swans for about 8 years. They are only used in the summer, maybe for 2 months out of the year & both have the same problem. They were once nice, fairly quite fans, but have gotten progressively noisier. After about the 1st year I could no longer use the oscillating feature because of noise; now even stationary position is somewhat loud.
Oscillating noisy is somewhat one sided. Started out as a creaking noise when it would reach one side. Now it just sounds like an airplane is in the living room - but still more predominant one one side. Anyway, can't use the oscillation at all because of this.
More troubling is that the overall volume of the fan has increased in the stationary position. I took off the cage, removed the blade assembly & cleaned it well. I couldn't disassemble further than this because the screws are really tight & seem to be made out of a rather soft metal. (Trying to avoid stripping the screw heads).
The fan is still noisy & the rather brief instructions say to NOT oil the motor. I would appreciate any suggestions on how to remedy this situations. They were a bit expense & I'd rather not replace them...
Thanks! Jen
  • jenshop1 Jul 30, 2009
    I think that the fan assembly might be spinning slightly off balance. There seems to be a little bit of play back and forth on the spindle that holds the blade assembly. I don't know if this is normal or not.
    Anyway, I can't access the motor because I can't get the screws off. Probably put in by machine, so really hard to get off without stripping. I'm hesitant to use oil on the motor since the manufacturer explicitly said not to do it.
  • 867 Answers
The electric motor bearings and/or brushes have worn. soft metal screws is an indication of the quality of the motor.not good. sometimes units are of nice design, look and high price but they throw in a cheap chineese motor. all you can do is put a few drops of oil on the motor bearings, its ok to do when this worn out
Posted on Jul 30, 2009
Speed control The speed control isn't working properly. It only goes at high speed. The low and medium speeds don't work. Where can I get a replacement part for the speed control? Thanks.
try to clean the bushing and put some oil if its not work try to replace the capacitor about 2 to 5 micro farad... like this at the bottom...
Sep 12, 2015 | Vornado Silver Swan Table Fan
I have a swan vornado oscillating table fan. I
Stop loving it. The new fans won't even last a few years.
Oct 14, 2014 | Dryers
Vornado Swan parts
Call vornado 1(800)234-0604 to order part. About $25- shipped.
Aug 25, 2012 | Vornado Silver Swan Table Fan
How do i get the fan blades off the motor ? This is a Emerson silver swan .
HELLO - is the fan cage held on by 4 or so clear small clips along the body? If so carefully undo the clips and remove the fan's protective cage in front and back, set those 2 main pieces aside.
Keep the small clips 'taped' to a sheet of paper that is marked 'fan clips', taped to the paper with clear scotch tape. So you DON'T lose them (better than placing in your pocket ... ).
Then look at the body of the fan where the blades ARE mounted. There is a large button or front cover like part . Try unscrewing to the left left is loose - right is tight, is the rule to follow. The knob or cover should loosen ...
When that is completely loosened pull it off, and voila!
The blades will be on a single casting of plastic. Or perhaps metal -- that comes off on a thin rod or pin. that has a small bail or ball that will 'click' (or lock / unlock) in forward or reverse as to a pull on / off function. Pull that blade assembly forward UNTIL it clears the fan housing completely.
WASH with mild soap. dry completely & Then with "ALL CLEAN" - reassemble =
replace in reverse steps from before. and ENJOY! (COOL AIR, hopefully).
I have never heard of a fan that had the cover 'screwed' on (with screws) as to a front casing like a nose or giant knob. giant dial with logo like covering. Most if not all were as I described to you. The fit is made to only go so far as to the nose, giant knob, giant dial, etc like cover assembly. They are not really made to 'over or undertighten'.
I am hoping this is all you need to know ... Good luck!
Aug 21, 2011 | Vornado Silver Swan Table Fan
Model FA1-0013 TYPE SWAN SERIAL # MAY00 VORNADO FAN When you plug it in and turn on the switch it does not work.
The motor has a single-use fuse in the run winding; that may be tripped. Or there could be no power going to the motor. Some of the swans had a power lead that was too short and pulled out of the switch. Take the 5 feet/screws out of the fan and remove the bottom plate. Are any of the wires loose that go to the switch? One power lead goes to the white wire that runsd directly to the motor: is that hooked up? If you need more help, contact me.
cawicks at g mail
Aug 29, 2010 | Vornado Circulating Fan
What king of oil do i use /
3-in-1 oil for electric motors
Jul 02, 2010 | Vornado Silver Swan Table Fan
Vornado Silver Swan Table Fan Logo
1,078 people viewed this question
Top Vornado Dryers Experts
Dusty Ryan
Level 1 Expert
Steve
Mack Baxter
Are you a Vornado Dryer Expert? Answer questions, earn points and help others
