Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://homenol.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
SOURCE: Need a remote control code for a Sansui TDC2075 TV/VCR/DVD combo
Contact Fox International parts at 1-800-321-6993
or Sansui troubleshooting hotline at 800-289-0980
thanks
SOURCE: universal tv remote control codes for a hikona tv/dvd combo
you have to set the code for TV alone, then code for DVD
SOURCE: innovage jumbo remote control code for emerson tv/vcr combo
Press code search till light comes on, press device once, press on/off button once and aim at device, when the device turns off, press enter to store code.
To find out the code of the device:
Press code search till light turns on, press device, press code search once, then go through 0-9-when the light blinks first, that is your first number, repeat numbers to get second and third.
SOURCE: I need a remote control code for my hikona tc-1400 to work with my topup tv remote control
my remote is not working
