Question about KitchenAid Refrigerators
Kitchenaid Superba ksrs25qfwh00 side/side water disp dead ice ok
Kitchenaid Superba ksrs25qfwh00 side by side refrigerator with ice and water in door. Ice maker works fine - ice dispenser in door works fine - Water Dispenser does not work. It sounds like the microswitch broke, it no longer makes a clicking sound when you push in the water dispensor. I cant figure out how to take the door apart and i dont want to break it. Where do i begin? Thanks
  • 23 Answers
SOURCE: Kitchenaid Superba Ice Maker quit
Make sure your manual doesn't say something about inline filters, or a float that might be sticking in off position. Depending on how ice is made sometimes they have a float to where water rises so hight then gets shut off to freeze and form the ice.
Posted on Dec 08, 2007
  • 35 Answers
SOURCE: KitchenAid Superba KSCS25FKSS00 SideXSide Refrigerator
Replace the ERC board.
Posted on Dec 09, 2007
SOURCE: KitchenAid Superba ice maker not dispensing ice
the problem is that the bottom piece is missing from the ice maker housing. i have the same problem and im looking for that peice
Posted on Oct 31, 2008
philbran
  • 242 Answers
SOURCE: in door water dispenser leaking on my kitchenaid superba
Hello , I can help , If water is coming out of the tube in the door the only problem you could have is the water inlet valve not sealing all the way causing water to seep out and leak, this is normal to happen over time and the only way to fix it without turning your water off to the unit is to replace the water inlet valve , it is not extremly difficult and will cost about 50 dollars. it is the part that you connect your water line to in the lower rear of the unit. This should get you going if you have any questions just ask. tell me how it works out.
Phil
Posted on Jan 07, 2009
jmgldsmth
  • 2005 Answers
SOURCE: musty smell/taste from water dispenser in refridgerator
replace your dispenser water filter
Posted on May 03, 2009
Icemaker is not making ice.
check water valve /filter it maybe the ice maker
Apr 02, 2009 | KitchenAid Superba KSRS27CN Side by Side...
Water dispenser is not working
a possibility is that the water tank has frozen up in the refrig side. what i do is remove the middle crisper drawer and put a hair dryer blowing on the water tank in the back. do this for about 5 mins then start trying to get water out of the disp and it will clear it out. peyton
Jan 17, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid superba 42 side by sside water dispenser
usually when i get a kitchen side by side i trouble shoot the wtr valve first by using a cheat cord that applying volatge directly to the vlave to see if it opens but usually the wire harnes under frezeer breaks the wires so my money is on the wires under the frezerr door cut the sleve off and chec the wires one by one the one to the water is broken
Oct 29, 2008 | KitchenAid Superba Architect KSCS25INSS...
Not dispensing Ice or Water thru door
Found someone that was not going to charge me money for advice.
Sep 21, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid side by side model ksrs25ikss01
CHECK YOU SECOND VALVE IS WORKING IF THATS OK YOU MIGHT NEED YOUR ICE MAKER CHECKED AND SERVICED.GOODLUCK.MOHAMED
Sep 06, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid superba ice maker stopped working
the oil in the compressor has pumped up to the top hence the ice is not formed the lead valve in the compressor is not working properly so change the lead valve and you could make ice as before
Jul 12, 2008 | KitchenAid Superba Architect KSCS25INSS...
Ice maker not filling with water
I have a model KSRG25F and found that the solenoid that controls the water to the icemaker was not working. I tested by switching the water dispenser connection to the ice maker coil.
And then had the wife push the water fill in front of the fridge. I had aready changed out the control board in front because I didnt have the flash codes or solid led when simulating door closed. the parts is about $55 and hope that does it. Good Luck
Jun 29, 2008 | KitchenAid Superba Architect KSCS25INSS...
KItchenaid Superba KSRB25QABL water dispenser
Chances are is a bad water valve.  The water valve is on the back of the fridge at the bottom.  You will see the water line going into it.
Oct 12, 2007 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
513 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
