Question about Frigidaire Affinity ATF7000E Front Load Washer
Its leaving the white clothes dirty with spots that were not there before i dont know what part of the machine is dirty enough that it would stain so much
Run some CLR in an empty load, you are probably getting rust spots on your whites.
Posted on Jul 30, 2009
The machine is doing yellow spots on several clothes and it is clean from inside and nothing could cause rust stains inside
Search Results
    Washing Machine Stains: Possible Causes And Cures
    www.stain-removal-101.com/washing-machine-stains.html
    Have you ever experienced washing machine stains, where your machine is the culprit for ... Just never put clothes in when doing this as it will discolor them. ... I get largeyellow spots on my Battenberg linens after washing, or maybe they ...
    Removing Yellow Stains from Washing ' Clorox
    https://www.clorox.com/...laundry/removing-yello...
    The Clorox CompanyFeb 4, 2010 - I do my laundry at a neighborhood laundry that has. ... into the machinefor the wash cycle but still get the yellow spots. ... Since you diluted it in a gallon of water, the yellow spots/splotches should not be from the liquid bleach. ... Rinse and air-dry to see if it has any effect before doing a large number of items ...
    Weird yellow spots on whites - Home Forums - GardenWeb
    ths.gardenweb.com > Home Forums > Laundry Room
    Jul 27, 2010 - I wash on warm/cold using powdered Tide and nothing else. The laundryemerges from the machine with yellow spots in places. Not pale ...
    Mysterious yellow spots on clothes, bedding, etc ..
Feb 03, 2016 | Washing Machines
Leaving brown stains on clothes, messing them up,
If it isn't rust, I suspect cotton can decompose if moist for a long time (in the laundry or machine), causing brown spots. In that case, the spots probably cannot be removed. Or can they?
May 09, 2010 | Washing Machines
The machine is spotting the clothes/ It looks like dark fuzz, but its staining the whites. How do you remove the agitator???
Amazing, my washer was doing the same thing, i was getting unremovable stains on my dark clothes. to fix this problem you have to changed out the gearcase...leaking oil....
Sep 13, 2009 | Washing Machines
My Frigidaire Washer Leaves Stains all over our clothes
Since this happened from day 1, your water may be the problem. Do you have well water? If so, get a softener system. This will get rid of the iron, which is responsible for rust stains. I really doubt that a new machine would cause rust or grease.
Why didn't you do something five years ago when you first noticed this? It will be much more difficult to get a resolution from the manufacturer after5 years.
Jul 31, 2009 | Frigidaire GLTF2940ES Front Load Washer
Oil-like stains on wahsed clothing.
Around the white plastic rim right above the steel tub, link gets caught. I have only been able to remove it with my fingers every week or so and this seems to stop the "spotting/striping" of stains on my cloths. I would also like to know the RIGHT answer to this one. Thanks
Mar 28, 2009 | Speed Queen AWS52NW Top Load Washer
Rust stains and bleach spots.
I'm sorry but the white spots will be due to bleach. It may be that there was undissolved bleach in the washer after the first load. Maybe some of it came out with the whites and lay in wait in the basket.
I doubt the makers would guarantee anything for 7 years, so no free basket or installation is likely. Seems there is a chip in the enamel and dampness / water from the previous wash days before sits there collecting iron as rust particles.
For the time being you could try rinsing the machine out before the first load. That might prevent the rust marks or reduce them.
May 01, 2008 | Kenmore 22422 Top Load Washer
Looks like a water stain on screen
IT SHOULD NOT NEED A "REPAIR" PER SAY. HOWEVER, I OWN AN LCD TV, BUT NOT A PROTRON. YOU'RE GONNA FIND THIS PROBLEM WITH ALL LCD TV'S. IT SOUNDS LIKE IT IS SIMPLY DIRTY. THIS IS THE WAY YOU CLEAN YOUR SCREEN. IT IS VERY EASY AND FAST, AND YOU SHOULD HAVE THE SOLUTION IN YOUR KITCHEN AND BATHROOM. TAKE THE CLEANEST, MOST SOFT CLOTH YOU HAVE IN YOUR HOUSE. DAMPEN,NOT SOAK IT, WITH WATER, AND LIGHTLY RUB A SMALL SECTION OF THIS STAIN, AND SEE WHAT HAPPENS. IF THIS DOES NOT WORK, ADD A SMALL AMOUNT OF SIMPLE RUBBING ALCOHOL, AND TRY ANOTHER SMALL SPOT OF THE STAIN. IT SHOULD COME OFF. SOME OF MY "HI-TECH" FRIENDS USE STRAIGHT RUBBING ALCOHOL, AS IT HAS A TENDENCY TO EVAPORATE A LOT FASTER THAN WATER AND LESS LIKELY TO LEAVE ANY "WATER STAINS". HOWEVER, IF YOU CANNOT SEE THROUGH THIS STAIN, THEN YOU'RE BETTER OFF BUYING A NEW TV. SOUNDS LIKE SOME KIND OF LEAK OR MAYBE THE TV IS JUST NEVER SHUT OFF, THEREFORE BURNING IMAGES INTO THE SCREEN. FORTUNATELY, IF IT IS STILL UNDER WARRANTY, YOU MAY GET HELP THERE. MY FIANCE TOUCHED THE LCD SCREEN WITH HIS FINGERS, AND IF YOUR FINGERS ARE DIRTY, THEY WILL LEAVE OIL STAINS. PEOPLE DO SOMETHING TO A PRIZE POSSESSION IN YOUR HOUSE, DONT TELL YOU THEN ACT LIKE THEY DONT KNOW WHAT HAPPENED. ITS HILARIOUS. HOPEFULLY THE ISSUE YOU HAVE CAN BE FIXED BY YOU!
Jan 01, 2008 | Protron PLTV-32 Television
Grey gunge discharged ion clothes leaving spot stains from the drum on clothes
Colud be oil from the bearings, which means that the bearings is on their way, or it could be that the machine is dirty inside. It happends when washing just on low temperatures (60* and lower).
Dec 19, 2007 | Zanussi FJD1666W Front Load Washer
Oil Like Stains on dark cotton Clothes - Whirlpool duet
Problem Solved !!!
Ok, I had to stop and tell everyone about my latest experience. When we moved here we bought the nice Whirlpool front load washer and dryer set. I Love them....still don't understand how my clothes get clean with so little water, but love them. ..................That is until lately. I was really upset about a total of 4 white blouses that looked to have some kind of light splattered stains on them after washing. I would try to wash them again with a stain remover sprayed or scrubbed on the spots, but they wouldn't come clean. I gave up and considered the blouses ruined. I told William what was happening and he called the repair man out because he thought it might be some kind of part in the machine that was leaking oil onto the clothes when they were washing. The guy came out and told William that there wasn't anything that could go into the washer tub and get onto the clothes. He then looked around in the washer and at the little detergent dispenser drawer. He suggested that we use 1 cup of Clorox and 1/4 cup of dish washer detergent (cascade with dawn degreaser crystals) on a hot to medium water temperature and turn it on a complete wash cycle to make sure that we didn't have mold and mildew setting up in our machine. After he left, I proceeded to do what he told us. I though.....the blouses are probably ruined anyway. I had tried to get out all the spots to no avail, so what the heck......I threw them into the mix too! Would you believe they came out clean, very bright white (instead of yellowed or dingy from continued wear) and the washer smells as sweet as it did when it was new. Why didn't they tell me about this when I bought it ??????????? I plan on putting the detergent mix in the washer every couple of months and throwing in all the whites that I can find to take advantage of the cleaning effect on the whites. (I thought that maybe some of you had gotten stains on white clothes that you would like to get out too)
Dec 06, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Black particles in clothes after using a top loading samsung fully automatic washing machine
You said these particles stick to the clothes, do they come off and then leave a stain? It may be grease or oil coming from a leaking drum bearing seal.
If it is, This is a major repair and not one for DIY.
Sep 28, 2007 | Washing Machines
Frigidaire Affinity ATF7000E Front Load Washer Logo
205 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
