Question about Hampton Bay Heating & Cooling
I have model HBLG1004C- runs well but doesn't cool well. air is barely cool not cold right out of unit. unit is 5yrs old.
  • jkrice Jul 30, 2009
    condensor coil is clear and clean, filter is clean.. Fan is running over condensor. condensaton is in bottom of unit. how often should this be serviced,as far as replacing cooling chemicals?
    time will tell if solution is ok or not.
    President:
  • 1,714 Answers
Is the condenser coil clear of obstructions and CLEAN? Give it a look and make sure it is. Also, check the fan that blows air over the condenser too, is it running?
Posted on Jul 30, 2009
  • Craig Butler
    Craig Butler Jul 30, 2009
    Is the compressor motor actually running?
Ive owned the 10x6c for 2 years never used it because of my wiring doesn't have a ground,,let my neighbor borrow it and it doesn't blow cool air I hear the compressor turn on but no cool air?
If the compressor is coming on and the air is not cold, it could be that the freon has leaked out. Easiest way to check for no freon is to take the cover off the unit and run it in cool. The high side which is the smaller line coming into the top of the compressor should be hot, and the low side which is the large line coming off the side of the compressor should be cold when the compressor is running. If there is no temperature difference between the high side and low side tubing, you have no freon. Also check for oil residue once you have the cover off. If you spot oil, you had a leak and have no freon.
Aug 14, 2011 | Haier hwr10xc6 Air Conditioner
BLOWS AIR BUT NOT COLD SPLIT UNIT 5YRS OLD TRAN
. Do you hear the compressor come on?
Aug 07, 2011 | Heating & Cooling
Just bought a 2 yr. old Danby DAC5209M window a/c unit that doesn't cool the air before it blows it into a room. The wiring looks brand new, it was barely dirty on the inside, anyway, I've...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jul 24, 2011 | Danby DAC5020 Air Conditioner
Freezer and Refrigerator are not cold enough. Freezer barely keeps things cold and fridge doesn't keep cold at all.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 07, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Model#1051 small dorm size...doesn't matter where i set thermostat..it sill freezes everything,,,suggestions?
Repace thermostat. You didn't tell us that it runs ALL the time. It does. You don't have to tell me, I know it does. The first thing the power does is go thru the thermostat and its job is to turn the power off to the pump when it gets cold enough. If it gets cold and freezes everything then everything else is working right. There is no fixing the old thermostat either. That little tube that looks like a heavy bare wire ending next to the freezer coil has a little "freon" in it that expandes and contrectes with temp. change and the change in pressure is what ativates the thermostat. Chances are the "freon" leaked out.
Note, this is not the same "freon" that is pumped around the fridge to cool things. This is sealed in the thermostat and tube only.
Jun 23, 2011 | Goldstar GR131CN Compact Refrigerator
My 5yrs (about) old westinghouse fridge at home is not cooling anymore (since yesterday)! Like to know why and how it can be fixed. Other functions seems to be working fine such as fans, lights...
heatman101
May 25, 2011 | Westinghouse Refrigerators
Freezer is very cold, refrigerator not cooling on Maytag side-by-
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
s
Nov 25, 2009 | Maytag MZD2766GES Side by Side...
Heat Pump no longer produces cold air. Blows good but not cold.
make sure the coils are clean run unit a bout 20 min take cover off and feel the lines on the compressor the big one should be cold and small hot feel top of compressor to make sure running
if big line not cold most likley freeon has leaked out if compressor not running low psi may have unit out look at the compacitor if swelled up bad hope this helps
May 22, 2009 | Heating & Cooling
The freezer works very well but the refrigerator is not cool enough
check if fan in freezer is running , stryo is air diverter leave alone. ck frz temp rkm
Jul 11, 2008 | Frigidaire FRT21P5A Top Freezer...
No cold air
if unit is more than 5 yrs old dump it!!! most frigidaire models just dont last...that is why they are so cheap...get it???
Jun 09, 2008 | Frigidaire FAH085N1T Air Conditioner
Heating & Cooling Logo
Top Hampton Bay Heating & Cooling Experts
Tim Whalen
AJMAL KHAN
Are you a Hampton Bay Heating and Cooling Expert? Answer questions, earn points and help others
