Question about HP PSC 1210 All-In-One InkJet Printer
Cannot install HP PSC1401 aal-in-ine
I recently had a new hard drive put in my computer and more memory. When I plugged everything back in I could not get my printer to install. It did not come with a CD to install, it had the info in the printer when I first got it and the info came up on my screen and I just followed directions. Now I get the install wizard and it won't install. The wizard said it cannot find my printer online to install. PLEASE HELP. I need my printer. Thank You
Drema from West Virginia
    President:
  • 2,666 Answers
Go here select your OS and download software and drivers
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=1103491&lc=en&cc=us&dlc=en&lang=en&cc=us&submit=Go%20%BB
Posted on Jul 30, 2009
Computer sticks when after 2 min...of having the computer on....I have removed cmos battery n memory for about 30 min....resetted the memory n the cmos battery back on to the computer...started the...
Based on everything your saying I would replace the memory modules and verify the fans on the CPU and Graphics processor are working properly. Typically you get this problem when a ship overheats, a memory module is going out or the power supply is fluctuating.
Oct 13, 2011 | HP Compaq Presario SR5450F Desktop PC
HP a6412p added 2nd hard drive but wont work get blue screen
you should try switching the sata port you plug your new drive into. also, you should go into your BIOS setup f2 and save setting then exit.
Jan 25, 2010 | HP Computers & Internet
Upgrades for hp pavillion 533 such memory
This is everything I could find on your computer.
Base processor and speed Celeron 2.0 GHz
  • 400 MHz Front side
  • Socket mPGA478
Back to top Chipset 845GL Back to top Motherboard manufacturer
  • Manufacturer for computer serial numbers starting with KR and CH: Trigem Glendale
  • Motherboard for computer serial numbers starting with MX: ASUS IT8708F NOTE: The serial number can be found printed on the back of the HP Pavilion computer, or while holding down the Ctrl and Altkeyboardkeys, press S. A screen will pop up with the serial number.
Back to top Memory Component Attributes RAM (installed)
Allocated to Video 256 / 2100 DDR
Up to 64MB Maximum allowed 1 GB (requires replacement of the installed 256 DIMM) Speed supported PC2100 / PC1600 Type DDR SDRAM DIMM slots Two Open slots One Back to top Hard drive 60GB Ultra DMA Back to top DVD-ROM/CD-RW combo drive 16x/8x/8x/40x maximum speed Back to top Diskette drive 1.44 MB (3.5-inch) Back to top Fax and data modem Cheetah 2 V.92 Modem Back to top Video graphics Integrated Intel Extreme Graphics with up to 64MB shared memory Back to top Sound/audio Integrated AC97 audio Back to top USB specification USB 2.0 Back to top Network Integrated on motherboard: 10/100Base-T LAN interface
Dec 26, 2009 | HP Pavilion 533w (P9859AR#ABA) PC Desktop
Stop:c0000221 unknown hard errorsystemRootSystem32 tdll.dll I get this error message when installing a brand new hard drive onto a HP laptop.
  1. UNPLUG THE POWER TO THE COMPUTER
  2. OPEN THE CASE
  3. UNPLUG YOUR HARD DRIVE RIBBON AND POWER CABLES AND PLUG THEM BACK IN.
  4. CLOSE EVERYTHING UP AND PLUG IT BACK IN
  5. POWER IT UP
Dec 12, 2009 | HP Pavilion zd8000 Notebook
HP Pavillion dv6700 - black screen
Do the following without the battery inserted.
Let the computer sit with no battery for 24 hours. Do not put the battery in at all. Try using your original memory stick ONLY, with no hard drive and see if it will POST. If it does, insert the hard drive and try again. Could be the new memory...
Another thing you can try is reseating the processor. Turn the ZIF screw, take the processor out (WATCH THE PINS!!) and put back in GENTLY. Leave the memory in the computer, hard drive removed, try to power on.
These models have been known for bad motherboards. Contact HP and arrange to send it in. If you do enough digging on HPs website, you'll find the service advisory.
-Dell & HP Certified Technician
Oct 29, 2009 | HP Pavilion DV6700T Notebook PC
My HP a420n won't start after replacing cd-rw drive
Please try to remove all the connections from your computer and also connections inside the motherboard, the power cord for your hard drives and also the power cord from the power supply to your motherboard.After that, remove the memory and clean the pin by using an eraser of the pencil. And then insert again the memory stick and connect all the connections from the power supply to motherboard and everything. Lastly reset your bios and put it back to normal again. Hope this would help. Thanks..
Oct 22, 2009 | Computers & Internet
Laptop not booting up after XP install
Can you press f10 to get to the HP recovery screens?
May 28, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Putting the Computer Back Together
I need color of the wires that are in question. since some wires are not used. please make sure that the hard drive and cd roms are all plugged in and especially the fans are what I am concerned with.
Apr 27, 2009 | HP Pavilion xe743 PC Desktop
Performance is very slow
It will not add preformance, but you will be able to have more stuff on your computer. If you want temporary memory (which lets you run more things at the same time) then you want to get RAM. There are 3 slots on the inside of your computer. Only 1 or 2 are being used when you buy it. These are RAM slots. Shove the RAM into there and click it in and youre done! if you want more actualy memory then you will have to buy a new hard drive. These are fairly easy to install, they look like rectangular metal things. Un plug the one in your computer and plug this one in. Note that this is where all of your data is stored, and you will have to re-install absolutely EVERYTHING. You wont have to install any programs to use RAM or new Hard Drives.
Jul 06, 2008 | HP Pavilion a310n PC Desktop
My scanner won't work
I have the same printer and I recently had to download the same software. I found it on the HP website. You can find everything you need here. First start by choosing your OS.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=311255&lc=en&cc=us&dlc=en&submit.y=8&submit.x=4&lang=en&cc=us
Nov 29, 2007 | HP Officejet 5510 All-In-One Thermal...
HP PSC 1210 All-In-One InkJet Printer Logo
32 people viewed this question
Seeker5211
Seeker5211
