Not sure what you mean "high voltage rpm power generator out", however many people have asked how to adjust the engine for proper voltage output. On generators with~out a voltage regulator, I adjust the engine RPM by using a digital voltage meter that has a Hz setting. Adjust the governor untill the meter displays 60 Hz. With the geneator producing 60 cycles, I know that the engine is turning 3600 rpm (the engine produces max hp when it is turning 3600 rpm). At this point, read the voltage output to verify that the range is between 115 ~ 120. On generators with a voltage regulator, verify/adjust that generator is producing 60 cycles then adjust voltage by turning screw at the regulator (some regulators are sealed with potting compound and can not be adjusted). If your power demands are not that great and you appliance can operate at 50 cycles, adjust governor as needed. Lowering to 50 cycles will also reduce output voltage. Good luck
The C50 can be lowered, but not by adjusting the shock. Adjusting the shock only stiffens or softens the ride.
To lower the Suzuki Vl800 (C50), you will need to purchase a lowering kit, which consists of a new set of "lowering bones" (so named because they are shaped like dog bones).
You will need to remove the stock bones from the shock, and replace them with the new bone from the kit. You can buy kits on eBay that will lower your bike 1 to 3 inches.
By lowering the WATTS from 550 down to 300, you may find the P.C. starts shutting down or restarting, as it does not have enough power to operate everything inside the tower. You need to add up all the WATTS on the different things running on power ( i.e. Motherboard, Graphics Card, RAM, Fans, Sound Card,USB plug-ins, HDD, CD/DVD drive). You maybe not have all listed but by lowering the power might be not worth it to be honest.
Hi, you can try lowering the screen resolution, the color quality and the screen refresh rates. Work from there and observe each setting/increment. soon as the monitor quits, press escape to revert to previous setting.
I get the impression that you are familiar with electronics, the problem is your monitor horz. freq is playing catch up and eventually fails. Lowering your PC setting then might do the trick.
To lower the settings, right click on desktop, properties, settings tab & advance button - Monitor.
Hope this be of some help. Good luck
