Question about Sony Cyber-shot DSC-S730 Digital Camera
Powers up then shuts off. Lens is out.
Powers up then shuts off. Lens is out and will not go back in. Batteries are good.
  • trosemurgy Jul 30, 2009
    I read a similiar problem and tried what they said - gentle wiggle the lens. It immediately turned on and the lens went back in and out. Works great now! Thanks for your help... Tom
  • 300 Answers
Hi!
There could be two problems:
1. Lens problem - stuck (damaged or sand / dirt inside the reductor and / or lens)
2. Faulty motherboard - happens to the Sony S series cameras.
I'm afraid you will have to give it away for a repair, you should contact your local Sony service center.
I work in a Sony service center and I know what I'm talking about.
Hope this helps!
Tom
Posted on Jul 30, 2009
  • Toms Safranovs
    Toms Safranovs Jul 30, 2009
    Well, guess the lens were stuck, you're lucky it went so easy. :)
    Hope it will work great for you!
    Tom
Camera says change the batteries with new batteries installed
Is the lens not coming out at all? did you check is the lens is blocked somehow?
When a mechanical problem occurs, this can be a trigger for the camera to shut down, before something becomes (more) damaged. Did something happen the last time you used the camera?
Was the camera switched of for a very long time?
Nov 12, 2013 | Canon PowerShot S2 IS Digital Camera
Turn on power, green light flashes, powers off
Hi there its happens when the lens not ready for work. Some how its not able to stable his focus method. That's why its come out & go back. There is a chances of lens guide pin disturbed or damaged & thats why green light blinking continues. Its mean he inform you there is a system error. So please visit the service center for repair that. Thanks.
Apr 02, 2010 | Rokinon DZ1000 Digital Camera
Camera powers on, lens comes out and then shuts down without the lens coming back in? Whats up?
It indicates your lens is getting stuck inside .
First go with hard reset . Remove the batteries and insert new batteries . This in most case works well .If your problem still persists then check for the following :
* Carefully inspect around it for dirt or debris.
If you see any dirt or debris around the lens, use canned air to gently blow it away.
* After removing dirt and debris, turn the camera on and off.
If your problem still continues you need to contact the service center to get your problem solved .
Hope this helps .
Do rate this solution .
Nov 10, 2009 | Samsung S630 Digital Camera
Camer keeps shutting off...it's burry and powers
Digital cameras require lots of power. Bad electrical contacts can cause lots of problems so battery and camera contacts must be cleaned properly. Batteries may be fully charged, but will be viewed as low if contacts are not really good. The LCD screen is a low steady load, but when lens extension, optical zoom, focus, and flash charging are added in the capture mode; the load is very heavy. Bad contacts make cameras do strange things like making bad pictures or shutting off with the lens out.
Do not overcharge.
Reset by removing power up to one month is the ultimate non-physical repair for DVD recorders and other software using digital devices. Digital cameras reset to original settings if batteries are removed. Time required varies with function and camera, but try one minute. Check display and setup menu for non-auto functions and date/time. Remove extra memory to eliminate this as a possible problem. Insert fully charged batteries and restart the camera.
Jul 31, 2009 | Kodak EasyShare M1033 Digital Camera
Powers on Lens move in then out,Blank display
hi...The transmission system that moves the lens in and out has a problem with it's gears. There is most likely a gear or an actuator that has fallen out of alignment and is getting stuck at a certain point as the lens comes in/out.There is some disturbacnce of the lens arrangement that is preventing the lens from coming in/out.Any of these symptoms above could trigger the camera to shut itself off to protect itself from further damage. thank u rate me!!!
Jul 22, 2009 | Nikon COOLPIX P60 Digital Camera
My kodak easyshare V1253 Powers up, then shuts off
You have damaged your lens. If the camera can not move the lens it goes through a built in diagnostics test and shuts down. Beyond repair as cost to replace is beyond the value of your camera.
Jul 03, 2009 | Cameras
Rollei camera powers up and then shuts down
I would strongly suggest new, I mean NEW batteries, first.
You may be confident with your current batteries, but don't trust any rechargables you have, as they lose their 'power' (ability to supply enough current at the nominated voltage).
Also, don't trust any cheap batteries you have, definately no carbon type batteries.
Go buy some new Alkaline batteries (Energizer or Duracell, or some cheap Panasonic or Varta alkalines) and then we'll go from there.
This is an important step. Sorry if I'm stating the obvious, but a far far majority of digital camera faults and power related.
Let us know how this works out.
**.The best way to acknowledge contribution is to rate it's relevance.**
Apr 11, 2009 | Rollei Cameras
Samsung S1065 does not turn on, beeps 3 times before powering off. Lens is extended, have checked batteries, not sure what else to do??
I had the same problem, firstly you will be able to press the button on the back to view your pictures, when you do and the camera powers up quickly press the menu button. Check that your battery settings are set to alkaline, then buy some good alkaline batteries and not cheap ones. Check that they are alkaline and not like what I did and bought panasonic zinc carbon.
This worked for me and mine would not turn on either until i changed the batteries to a good make.
Oct 01, 2008 | Gateway DC-M40 Digital Camera
Powers up and then shuts off
This should work for the A520. With NEW or freshly recharged batteries, remove the camera's memory card, then turn on the camera. You'll probably see an E30 error. Next turn off the camera. Next insert the memory card, and turn on the camera.
If the above doesn't work, the following blog outlines some other repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Dec 29, 2007 | Canon PowerShot A520 Digital Camera
Lens wont retract
Lens motor is shot - check out Olympus web site for repair options-not cheap
Jul 04, 2007 | Olympus FE-140 Digital Camera
Sony Cyber-shot DSC-S730 Digital Camera Logo
190 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
