Question about Ricoh Aficio IS420 Flatbed Scanner
Doc not feeding
Hi!
I just purchased a used IS420, the unit will feed and scan a page but it does not eject the page all the way. The first page gets stuck and results in a jam.
  • 58 Answers
You need a new paper feed tire assembly
Posted on Jan 29, 2009
MX522 will not print when doc's are fed in using ADF. A blank page is ejected.
Are you feeding the page through upside down?
Most ADF Units require the page to be writing side up as they loop over the scanner and feed out with the text facing down.
Check the ADF Tray as it will have a picture showing how the pages are meant to be placed to be fed through the ADF.
Sep 11, 2014 | Office Equipment & Supplies
Scan streaks with HP LaserJet Pro 200 color MFP M276nw
This may not always be the solution, but in my case it was. If you are getting black streaks on your copies, try this first:
The problem is that that there a small piece of glass that the doc feeder use's to scan the original. You will have to clean the small glass it's about a half of a inch piece and is normally under the doc feeder unit. It will either be to the right side of the main copy board glass or it is under the doc feed unit where the paper goes down through the feeder. It is mostly some white out or other residue, on the glass, just clean with a monitor wipe or take a cloth & wipe, etc...... Good Luck
Online tip from Chris Coughlin, but I changed a few of his words.
Feb 05, 2013 | HP LaserJet Pro 200 color
Any doc feed results in numerous vertical lines edge to edge. Is there something to clean or replace to get a clean doc fed copy?
Check & clean the SMALL glass window under doc feed unit. Likely there are marks on the glass causing this.
Oct 19, 2010 | Brother MFC-7820N Laser Printer
Doc Feed Problem
I would replace the Pick-up roller, Feed Belt, Sepearation roller, and torx Limiter for starters IF you cannot replace them, Clean them with warm water and soap, let them dry, and try the doc feeder, Most Multi feed problems are Torx limiter or clutch problems.
Apr 11, 2009 | Office Equipment & Supplies
Epsoncx11nf doc feeder inop
This is usually caused by the grey cable connecting the ADF to the scanner unit. A wire inside often breaks and the cable requires replacing by a technician.
Feb 03, 2009 | Epson ACULASER CX11NF All-In-One Printer
HP Officejet 6300 All-in-one machine makes black streaks
The problem is that that there a small piece of glass that the doc feeder use's to scan the orginal. You will have to clean the small glass it's about a half of a inch piece and is normally under the doc feeder unit. It will either be to the right side of the main copy board glass or it is under the doc feed unit where the paper goes down through the feeder. It is mostly some white out on the glass, just clean with a dam cloth with water or windex..... Good Luck
Nov 15, 2008 | HP 190 Copier
Black line on copy
Have you try to print with other tray also. Is it fine.
Your printer need cleaning of the roller, just open the cover and try to clean all the dust and ink.
Regards
ELLIN
Sep 23, 2008 | HP LaserJet 3330 All-In-One Printer
Scanner take a minute a page using form feed.
Yes, there is something you can do..... Get a bigger and faster copier.. There is not much you can do.... It is slow..... Sorry, can not help you with that.
Apr 23, 2008 | Sharp AL-1642CS Copier
Ricoh IS420 is not evenly scanning text pages - light side edges not do to obvious cleaning, what next? If I switch to custom resolution and manually adjust contrast, can get text but also blackens edges....
Dear David, I bought a second hand IS420 on ebay, and bought a service manual at: www.electronicsrepair.net/scan.shtml See #86 You can buy it for $10. Good luck, Brad
Aug 03, 2006 | Ricoh Aficio IS420 Flatbed Scanner
Ricoh Aficio IS420 Flatbed Scanner Logo
146 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
