Question about MGE UPS Pulsar Ellipse 300 (89301) UPS System
Ups does not power up - MGE UPS Pulsar Ellipse 300 (89301) UPS System
  • 63 Answers
BATTERIES ARE DEAD either replace the batteries or get a new UPS. this is a common problem with most UPS.
Posted on Aug 04, 2009
Steps to reset tablet which is stalling up again
hard reset in android tablet PC's
different keys have hard reset in android tablet PC's
u can try like this method
  • volume down + home button + power button
  • volume down + power button
  • volume up + menu + power button
  • volume up + power button
  • volume up + cam +power
  • volume up + lock button + power
Hope this helps !
Dec 19, 2014 | Tablets & eReaders
Monster Power HT UPS 1000
sbonner:
Probably the battery of UPS. you can contact the manufacturer for the replacement of battery. Also please check the manual if you can replace it yourself.
It could be the power built in power supply, but I would check the battery first.
Regards.
Dec 25, 2007 | Monster Power PowerCenter HT 1000...
My dell 4100 mp will not power on
try taking out the battery.
unplug the power adapter.
leave the battery out, but plug the power adapter back in. See if it powers up
If it powers up, put the battery back in while its powering up
If it doesn't power up with the battery out, then there's a possible issue with the port on the laptop, or the power adapter, or even possibly something shorting on the motherboard.
Mar 07, 2011 | Video Game Consoles & Games
How to charge ups for pc's
Your PC connection must always come via UPS, and your UPS will always keep charging.
UPS Power cable should be connected to DC, and your PC power cable should be connected to UPS.
And this way your PC will always be safe.
Nov 06, 2009 | QVS NetStar (UPS650A) UPS System
I have the same Issue
Could be a device has failed. Unplug all devices from the computer. Hard drive, cd drive etc.....anything that uses power. the only thing drawing power should be the motherboard. Try the power. If it comes up then power down and plug in the devices one at a time power back up and repeat for each device. if it doesn't come up then the last device connected may have failed. If the power still doesn't come up then pull all the boards and memory and try again connecting one board at a time. Still no, pull the cmos battery and check it. Still no power check the power switch and connections. Try to start the computer by shorting across the power switch buttons. Still no power...make sure it's plugged in.
Jul 30, 2009 | Gateway GT4022 PC Desktop
Laptop keeps losing power at start up and shuts down repeatedly
does it run with the power cord plugged in? if so your batterys dead, otherwise harddrive/bios/motherboard fault? is your power supply charging the battery?
May 09, 2009 | Compaq Presario R3000 Notebook
UPS does not supply power to equipment after power trip
Some of the less expensive UPS devices have two sets of plugs.  One set provides backup power and the other set only provides surge protection.  You need to ensure that the devices for which you want backup power are plugged into the correct outlets on the UPS.
Apr 20, 2009 | Computers & Internet
Inverter problem
If you got the store bought APC 350 UPS, you most likely overloaded them, and killed them beyound repair.
People should never buy a 350VA. They are way to small for power supplies most of us now have. you need to start out to 1000VA plus you need to do the math to figure out how big of a UPS you actually need in the show room.
What am I talking about? What is the significant, or the math of what I am saying here. 115V x 1 amps = 115VA x .778 power factor = 89.47 watts Start up 50 watts = 39.47 watts
115V x 2 amps = 230VA x .778 power factor = 178.94 watts Start up 50 watts = 128.94 watts
115V x 3 amps = 345VA x .778 power factor = 268.41 watts Start up 50 watts = 218.41 watts
115V x 4 amps = 460VA x .778 power factor = 357.88 watts Start up 50 watts = 307.88 watts
115V x 5 amps = 575VA x .778 power factor = 447.35 watts Start up 50 watts = 397.35 watts
115V x 6 amps = 690VA x .778 power factor = 536.82 watts Start up 50 watts = 486.82 watts
115V x 7 amps = 805VA x .778 power factor = 626.29 watts Start up 50 watts = 576.29 watts
115V x 8 amps = 920VA x .778 power factor = 717.76 watts Start up 50 watts = 667.76 watts
115V x 9 amps = 1035VA x .778 power factor = 805.23 watts Start up 50 watts = 755.23 watts
115V x 10 amps = 1150VA x .778 power factor = 894.70 watts Start up 50 watts = 844.70 watts
115V x 11 amps = 1265VA x .778 power factor = 984.17 watts Start up 50 watts = 934.17 watts
115V x 12 amps = 1380VA x .778 power factor = 1073.63 watts Start up 50 watts = 1023.63 watts
115V x 13 amps = 1495VA x .778 power factor = 1163.11 watts Start up 50 watts = 1113.11 watts
115V x 14 amps = 1610VA x .778 power factor = 1252.58 watts Start up 50 watts = 1202.58 watts
115V x 15 amps = 1725VA x .778 power factor = 1342.05 watts Start up 50 watts = 1292.05 watts
115V x 16 amps = 1840VA x .778 power factor = 1431.52 watts Start up 50 watts = 1387.52 watts
115V x 17 amps = 1955VA x .778 power factor = 1520.99 watts Start up 50 watts = 1470.99 watts
115V x 18 amps = 2070VA x .778 power factor = 1610.46 watts Start up 50 watts = 1560.46 watts
115V x 19 amps = 2185VA x .778 power factor = 1699.93 watts Start up 50 watts = 1649.93 watts
115V x 20 amps = 2300VA x .778 power factor = 1789.40 watts Start up 50 watts = 1739.40 watts
Sep 16, 2008 | APC Back-UPS ES 350 - UPS ( external ) -...
Ups
Off-line(also called standby) UPS, it remains idle until a power interruption occurs, which it then switches from utility power to its own power source. On the other hand, double conversion (also called online)UPS continuously gives power from its own battery and then replenishing the power instantaneously through the AC power from the socket...
Jul 24, 2008 | Online Double Conversion 1500VA 1050 Watt...
I have an ASRock AM2NF6G-VSTA motherboard that will not power up. I upgraded the system and powered it up and it ran fine, except I had not received the new upgrade power supply. I received and installed...
check the power supplies you have if it is working well. then reset cmos.
then if it would not power on, your motherboard maybe a deadset (meaning dead/unusable).
Mar 12, 2008 | Computers & Internet
MGE UPS Pulsar Ellipse 300 (89301) UPS System Logo
270 people viewed this question
Top MGE Computers & Internet Experts
Jax Planet
Jax Planet
Raj Patel
Are you a MGE Computer and Internet Expert? Answer questions, earn points and help others
