Question about Dakota LY44 Ceramic Utility Heater
I need an owners manual for my dakota spa
I purchased a used dakota spa and i cant find where to locate the drain plug and also want to check all the plumbing on it for cracks. i need a manual can anyone help?
LOCATION OIL DRAIN PLUG 2013 MURANO?
Your owners manual should show the location of drain plug. I can't see much from here. You have to safely raise and support the vehicle. Never use a jack to support vehicle use quality jack stands. Make sure tranny is in park and functional parking brake is set, block the wheels, even then there are safety issues when working under a vehicle. Safety is your responsibility.
Your vehicle is new enough, some of my automotive databases will not have this info. I did see a picture in your owners manual.
Mar 22, 2016 | Cars & Trucks
Where is radiator drain plug 02 dodge dakota
This is a post on the Dakota forums:
My 2001 Durango and 2002 Dakota they use the same radiator. You'll have the same setup. I have recent and intimate knowledge of draining them. Crawl under the left front of the truck and look up at the bottom of the radiator. At the bottom of the driver side radiator tank (facing toward the fender) is a 3/4" long flat handled plug. Twist your hand (with a pair of pliers) up there from the back side of the bumper fascia. Grip it and give it a 180* counterclockwise twist. It is now opened and draining out the little nipple sticking straight down from the bottom of the side tank. You can stick a 5/16" (or 3/8") hose onto the nipple to drain it into a bottle or pan without making a mess.
radiator coolant drain plug location Dakota Durango Forum
Nov 25, 2015 | 2002 Dodge Dakota Club Cab
2004 Honda VTX 1300 coolant drain plug location
Hi, Anonymous for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
2004 Honda VTX 1300 coolant drain plug location Google Search
How to Do Coolant Flush on Motorcycle Honda VTX 1800 Partzilla com
Honda VTX1300S Service Manual
https://www.partsfish.com/page/oem-parts-for-honda
Honda VTX1300C VTX 2004 Owner Manual
Mar 16, 2012 | 2004 Honda VTX 1300
Cant see oil filter on my dodge dakota owners manual doesnt show bottom engine view
i usually grab a Haynes or Chilton's manual at the library (for free) otherwise, you could drop around $20 bucks at your local auto parts store,. either way, call ahead for availability..
here is an older post --
if you go to autozone.com and put in your vehicle info they will have a diagram that will show you the location of course you have to use there search engine
Answered by avatar12.jpgalex MACHELL Over a year ago
Best regards,
Ck
Dec 01, 2011 | 2006 Dodge Dakota
Hi. I have 2007 Mercedes GL450 , Can you help me with oil change and oil filter change.Please tell me How to do it properly? The nearest Mercedes service is over 500 km. thanks alot, A
BEST TO LET DEALERSHIP CHANGE ENGINE OIL.YOU NEED A DEALERSHIP OIL FILTER.YOUR OIL FILTER INSIDE A HOUSING ON FRONT SIDE OF THE ENGINE. CHANGING YOUR OWN OIL NOT HARD.YOU NEED 9 QUARTS OF OIL LOOK INSIDE GLOVECOMPARTMENT FOR OWNERS MANUAL TO SEE WHAT TYPE OF ENGINE OIL YOU NEED TO USE AND HOW MANY QUARTS.IF YOU DONT CHECK READ MANUAL TO SEE WHAT OIL TYPE AND QUARTS YOU NEED. IF YOU BLOW OR DAMAGE THE ENGINE WARRANTY WILL NOT COVER THE ENGINE.FIRST OF ALL TO CHANGE ENGINE OIL YOU CRANK VECHICLE UP LET IDLE FEW MINUTES TO THIN OUT OIL THEN YOU TURN OFF ENGINE. YOU NEED TO RAISE VECHICLE USING THE FACTORY JACK.USE JACK STANDS. LOOK IN OWNERS FOR CAR JACK LIFTING LOCATIONS TO KEEP FROM DAMAGING ROCKER PANELS. AND PLACE A DRAIN PAN UNDER THE OIL PAN. UNDER THE VECHICLE.YOU NEED A WRENCH TO REMOVE OIL PAN DRAIN PLUG.WHEN ALL THE OLD OIL DRAIN OUT IN THE DRAIN PAN.SCREW BACK IN THE DRAIN PLUG TIGHTEN IT DONT OVER TIGHTEN STRIP THREADS.THEN YOU NEED SOCKET TYPE OIL WRENCH YOU USE WITH A 3/8 RATCHET WRENCH REMOVE OIL FILTER HOUSING.PLACE RAGS AROUND THE OIL FILTER HOUSING TO CATCH OIL SPILL. YOU WILL NEED TO GO TO THE DEALERSHIP FOR THE OIL FILTER AND FILTER HOUSING O RINGS. ONCE YOU GET NEW OIL FILTER AND O - RINGS INSTALL THEM IN THE OIL FILTER HOUSING.LOCATED OIL FILLER CAP ON VALVE COVER UNDER THE HOOD.REMOVE OIL FILLER CAP.POUR OIL IN ENGINE USING A FUNNEL.ENGINE HOLDS ABOUT 8.5 TO 9.0 QUARTS OIL. BUT LOOK IN THE OWNERS MANUAL CHECK HOW MANY QUARTS ENGINE NEED.CHECK OIL DIP STICK OIL LEVEL SHOULD BE ON THE FULL MARK ON THE ENGINE OIL DIP STICK.TO BE ON THE SAFE SIDE BUY 10 QUARTS OF OIL FOR A EXTRA.DONT OVER FILL MAKE SURE YOUR OIL LEVEL CORRECT.OIL DRAIN PLUG AND OIL FILTER TIGHT BEFORE CRANKING THE ENGINE.LOOK IN THE OWNERS MANUAL FOR OIL DIP STICK AND LOCATION.
Nov 05, 2010 | 2007 Mercedes-Benz Mercedes Benz Gl 450
I have a Coleman Powermate PM0435001 5000W with a Subaru EX30D 10HP OHV/OHC gasoline engine. I want to change the oil and cant find a drain plug. Did I overlook it or does it not have a drain plug? If not...
You probably overlooked the drain plug, it is usually located on the mounting base of the engine. BUT, there have been some engines (old cheap ones) that the oil was drained by tipping the engine and draining out the oil fill. I am almost positive yours is not one of these.
Your manual is here, but that is only an "insert". It does look like the drain plug is located on the base of the engine. Find the spark plug, and the drain plug is almost directly underneath it at the very bottom of the engine.
More information is available from Subaru's website, including owners manual and especially a service and parts manuals. Your drain plug is item #13 on page 2 of the owners manual located here:
http://www.robinamerica.com/pmanuals.aspx?pid=80
Jun 06, 2010 | Coleman Powermate Powermate 5000W...
Where is the trans drain plug for a 96 dakota manuale
there is no transmission drain plug, u remove the pan to drain fluid or pump it out using the fluid cooler pressure line at the radiator.
Jan 28, 2010 | 1994 Dodge Dakota Club Cab
I am new at learning how to do it yourself. what steps do you need to take to change the oil
first remove the oil filter, use a little oil put around gasket of new one screw filter back on as tight as you can by hand then use filter wrench and turn 1/4 trun more, now remove the oil drain plug on bottom of oil pan let oil drain until you see just a little stream, now put drain plug back on and tighten, just alittle dont go crazy tightening, now fill the oil to level put 4 qts and check may use 5 or 6 check your manually or use the dip stick, also grease frt end if you have a grease gun. good luck hope this helps.
Nov 29, 2009 | 2001 Dodge Dakota
How to replace a radiator drain plug on 2001 dodge dakota
with the use of a special socket that fits over the drain plug You can remove it from the bottom of the vehicle... obviously you will need to drain the radiator fluid first with the use of a drain pan to catch the fluid. Install is the reverse procedure
Nov 14, 2009 | 2001 Dodge Dakota
Trailer lights on 2006 Dodge Dakota will not work
Check the owners manual to locate the proper fuse. It is probably a "max" fuse under the hood and also may have one in dash fuse box. If it is a fuse problem, you will have to find the short in the system. Good luck
Apr 25, 2009 | 2006 Dodge Dakota
Dakota LY44 Ceramic Utility Heater Logo
806 people viewed this question
Top Dakota Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
Are you a Dakota Heating and Cooling Expert? Answer questions, earn points and help others
