Question about Dual Electronics CECT P168 Cellular Phone
How to stop the phone from making a clicking sound!
How to stop the phone from making a clicking sound every couple of minutes when its not in use? SciPhone I9+++ about the same as I68
  • nita76ra Jul 31, 2009
    I already found out on another posting Thanks. It's the autolock that makes that noise, I had to deactivate the autolock and it works just great!
Just check phone settings n u wil get d ans:)
Posted on Jul 31, 2009
The fridge stopped working last night. The light works, but the fridge just makes this clicking sound every couple of minutes, doesn't sound like anything is running and it does not get cool at all. Any...
Not a good sign, clicking. Usually that click comes from the compressor power circuit. The compressor is attempting to start but it does not. The clicking is from an overload protector that heats up from current draw. It clicks and cuts the power to the compressor, cools down, and the cycle starts again. Could be a start capacitor went bad, but it is probably the compressor.
Mar 11, 2015 | Refrigerators
My STR-DE945 5.1 channel, works "fine" just a small issue that started to bother me... when i start the thing the 5 speakers have sound (also the bass), but after like 5 or 6 minutes, i hear a...
Commonly your problem is a result in bad thermal connectivity on the power transistors.
Each power transistor is coupled to a heat sink with thermal paste / thermal conductor. When they run hot, they **** more power. There is commonly a thermistor which acts as a protection from blowing out the transistors.
There is probably a transistor that is nearing the end of its life. It will work for a while (when you power up the system) but after a couple of minutes, it starts to **** power, heat up, and trigger an thermistor up stream of the transistor, and it shuts the power stage of the amp off.
This is unfortunately a problem for a technician, or you would need to be armed with a schematic to be able to work with this problem effectively.
Mar 17, 2011 | Sony STR-DE945 Receiver
I am getting repeated and constent "alert notification" sounds. Every time it happens my computer locks up for a moment but there are so many of them it's making my puter almost unusable. The events view...
To see if the problem are really caused by the sounds just disable them all from: right click on the empty are of desktop, Personalize, Sounds and select No Sounds from the list of Sound Scheme options and click the OK button. If that fixes it and you still want some sounds back just go back there and create your own set of sounds.
Jul 18, 2010 | Computers & Internet
Replace Coupling, Now it's making a rapid CLICKING noise.
That dark brown gunk is the oil from the gearcase (transmission). If you had the washer tipped back, or laid it down, you shouldn't have. The oil will leak out. Leaking oil is also a symptom of a transmission going bad. It sounds like you need to replace the gearcase now. They aren't that expensive if you shop around. Searspartsdirect.com and appliancepartspros.com carry them. The part number is 3360629. The following link explains how to replace one if you decide to perform this repair yourself:
http://www.fixya.com/support/r699497-replacing_gearcase
If you have any questions, plese let me know. I hope this helps you.
Jun 30, 2009 | Washing Machines
Kenmore elite gas range clicking sound
If unplugging it for a couple minutes and plugging back in does not rectify then it sounds like a bad spark module or a shorted wire inside. All 4 should spark at the same time when any burner is used. (Does trying to light a burner make the other 2 spark too?)
Eric
Jun 20, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
I have a barracuda 7200.7 80 Gbytes. The dirve spins but stopped booting. Started making clicking noises. I smacked it a bit a few times. Now, the system doesn't recognize the drive in BIOS at all. I...
this hard drive is toast and sadly you are half the reason as you never, ever ever open or hit a hard drive.  There are data recovery firms however, they are very expensive.
Nov 27, 2008 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Kyocera lingo..5 minute beep..help
My Kyocera phone has been beeping every 5 minutes for several days. The only way I could make it stop was to turn my phone to silent, but then I missed all my calls and texts. I finally called my carrier and they told me how to fix it. I had to take the battery out while the phone was turned ON. After removing the battery, I had to hold the send button down for 15-20 seconds (while the battery was still out), then replace the battery and turn the phone back on. This apparently resets the phone. I waited 30 minutes before posting this solution, and the phone has not beeped again!!!
Mar 06, 2008 | Cell Phones
Dual Electronics CECT P168 Cellular Phone Logo
226 people viewed this question
Top Dual Cell Phones Experts
William Alequin
Computer Repairing
Computer Repairing
Shehu Pro
Shehu Pro
Are you a Dual Cell Phone Expert? Answer questions, earn points and help others
