it depends if it is your high pressure or low pressure line if it is the high pressure line you can purchase at an auto parts store for about $60-$70. If it is your low pressure line good luck finding a replacement. But what I did that cost me about $5 was buy a gas line that fit and a couple clamps and I cut out the section with the leak and installed the gas lin in its place. But remember you can only do that simple fix with the low pressure line.
most likely this is not a problem with you TV it is a problem with the Antenna or the cable.
you need to check all the connections from the cable box or from your Antenna not to be loose. also- contact your cable company and have they look into the quality of the transmitting you are getting.
Fuel injected? If so, those lines are feed and return. They both just slip off the tank nipples when the release collar is pulled down. There should be an o-ring in there that probably needs to be replaced.
Please download each file in the Computer to a folder. After that open the folder where the file was downloaded and double click to begin the installation. Then, please follow the onscreen instructions to complete the intallation process. Make sure that you restart the Computer after each installation. Installing all the above Driver/Utility in the correct order should fix the issue with the Volume/Brightness Function Keys.
