Question about Dometic Rooftop RV Air Conditioner
Duotherm sunchaser compressor wont kick in today-worked yesterday
I turn it on to cool, the fan comes on---yesterday the compressor cycled and cooled just fine, today I could hear the comprossor start a few times but never stayed on long enough to cool--then eventually just quit cycling altogether with just the fan running;
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 46 Answers
CHECK YOU RUN CAPISITOR ON THE ROOF YOU WILL HAVE TO REMOVE THE COVER ON THE ROOF THERE WILL BE A ACESS PANEL USUALLY THE MODEL NUMBER AND SERIAL NUMBER ARE ON A STICKER ON THE ACESS PANEL REMOVE PANEL LOOK INSIDE YOU WILL SEE TWO CYLINDRICAL LOOKING TUBE DEALS WITH A BUNCH OF WIRES WITH SPADE TEMINALS ON TOP OF THEM DO NOT TOUNH THESE WITH AND PART OF YOUR BODY OR TOOLS !!!!!!!! JUST LOOK AND SEE IF ONE IS SWOLLEN OR MELTED IF SO UNPLUG THE UNIT FROM SHORE POWER AND VERY CAREFULLY REMOVE THE MELTED OR SWOLLEN CAPISTOR GET A DIRECT REPLACEMENT NOT ATER MARKET AND REPLACE TAKING CAREFUL NOT OF WIRE PLACEMENT IF THIS DOS NOPT SO0LVE PROBLEM GET TO A QUALIFIED SWERVICE CENTER AS THERE IS NOTHING ELSE A CONSUMER SHOULD TOUCH AFTER THAT
Posted on Aug 01, 2009
DOMETIC DUOTHERM KICKS THE BREAKER MAY RUN FOR A DAY OR MAY RUN FOR 8 HOURS BEFORE IT DOES IT IN MILD OR HOT WEATHER. ALREADY REPLACED BREAKER AND MADE SURE WIRES ARE TIGHTNED. HELP PLEASE.
If all appears OK, no noise, good cooling suggest check thermostat. If the thermostat is allowing the compressor to short cycle, restart under load the breaker would be expected to blow do to overloading the compressor.
There is usually a 5 minute time delay in the thermostat that prevents this.
Jun 20, 2017 | Dometic Heating & Cooling
Frigidaire window air conditioner LRA157MT1 worked yesterday. Today fan works but it doesn't cool?
unplug it if you can and let it set for 20 minutes, set the temp control where you want it and plug it in, wait a bit and see if it starts cooling. you can confuse these things if you turn it off and on rapidly or change the temp control up and down sporadically. The compressor has to take it's time to kick on after it has been shut off and then on again.
Jun 11, 2017 | Frigidaire Heating & Cooling
Ac works but when compressor cycles, it wont come back on until i rev engine to 4500 to 5000 rpm's and compressor kicks back on until it cycles again. i have to repeat reving engine every time com
you need to check the pressure of the system if the system is a little low on freon it will cycle more also if the cooling fan is not working the pressure will raise and also shut off
Aug 17, 2012 | 1997 Nissan Pickup
Hello, My Feder Air conditioner model number A2Q10F2C. The air conditioner has worked great up until today. It has been off since yesterday and turning it on today I can hear electric going into the unit...
Check for a bad start relay/capacitor on compressor. That motor will not start running unless it gets a kick in the behind from those devices.
Sep 05, 2017 | Heating & Cooling
Have an lg reverse cycle was sitting for 12 months. the fan works fine but cooling or heating is not working.when i first turned it on it took about 5 minutes then compressor kicked in once in got to...
I think, your compressor gets over heated due to condenser block-clean it. Less rpm fan speed. -Replace capacitor. 3.Check compressor running capacitor. If weak replace it. Helpful?
Dec 29, 2010 | LG Heat cool Window Air Conditioner
The fan on my duotherm a/c doesn't work. I can hear the compressor come on but the a/c doesn't blow any air. There was a fairly loud pop when it quit working. Am I looking at replacing a condenser or relay...
SOUNDS LIKE A OVER HEATED CONTROL SWITCH   THE SWITCH THAT CHANGES HIGH, LOW FAN, HIGH COOL, LOW COOL. REMOVE INSIDE CEILING SHROUD AND LOOK AT SWITH FOR BURNT TERMINALS OR LOOSE WIRES TURN OFF POWER FIRST AT BREAKER.
Apr 18, 2010 | Dometic Rooftop RV Air Conditioner
Amana Cooling Condensing Unit fan won't kick on
be aware that not repairing this asap that you are causing yourself more problems First I would change out the fan capacitor and see if this could be the problem. Secondly if the capacitor isn,t the problem change out the motor . By continuing to allow the system to cycle like this the compressor will take a dive on you costing more . Good Luck
Dave
Aug 04, 2009 | Amana PTH123B25AJ Heat Pump Air...
Duo Therm AC Not Cooling
most likely a thermostat problem most rooftop air units fan will blow cont. and compressor cycles
Jul 26, 2009 | Heating & Cooling
DuoTherm compressor starts but will not continue to run
check condenser fan if running. it will make compressor comes on and off if broken
May 31, 2009 | Dometic Rooftop RV Air Conditioner
Dometic a/c, duotherm thermostat, turns right back on after it reaches desired temperture.
I have a dometic 13500 BTU Roof mount a/c. It is set up with the duo-therm analog thermostat. The system cools fine. The problem is that the a/c gets down to the right temp, then it turns off like it should but turns right back on within a few seconds. Any help would be greatly appreciated.
May 13, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
106 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
