SOURCE: problems transfering apps from iphone to Ipade
You are able to use any appstore app with the iPad. Make sure your iPad is listed as a connected device in the left side bar of iTunes. Check your sync settings to make sure they're set to sync with your iPad and if needed restore your iPad using the restore button and try to sync again.
To make an application fullscreeen tap the small "2x" button in the bottom corner of your iPad. This will upscale the app to fullscreen.
Hope this helps, if you found this helpful please leave some feedback. Thanks.
SOURCE: The PC on which I had itunes that synced with my
You can use iPad to PC Transfer, which can help you transfer from iPad to PC. iPad to PC Transfer is a professional sofeware, which can help you transfer Music, Movie, Photo, ePub, PDF, Audiobook, Podcast and TV Show from iPad to PC or iTunes library.
SOURCE: new i pad air. need appointment to transfer info from old pad
The best way is to use iCloud.
Backup your old iPad to iCloud and then restore to the new iPad Air.
