Question about Canon Office Equipment & Supplies
Canon MP460 doesn't recognize ink cartridges (OU51)
After replacing black ink with new cartridge this message appeared. I have used a few refills from Cartridge World. Is there an easy fix?
eagle338
  • 4889 Answers
SOURCE: Canon MP460 cartridge error
Verify that you are using Canon(TM) cartridges. The technology has progressed to where they have modified the ink to be identified by their printers. You cannot currently use refill cartridge inks to refill Canon cartridges. If that is not your issue, then try removing and replacing the cartridge(s)and reset the ink level indicator. Lets hope for the best! Regards, Eagle
Posted on Oct 10, 2007
SOURCE: replacing NON Manufactored ink cartridges in EPSON PHOTOS STYLUS R380
hi im jules_09,apparently it will not work because every copier orprinter has its own designated ink cartridges.or even the ink will not work on it too.it goes to all copiers and printers that do not use a imitation of toner or ink or youll have problem with the machine if you want it to work just transfer the new ink into the old cartridge,re use only the cartridge but remember that compatile ink and toner can ruin the operation or even cause big problem to the machine
Posted on Nov 11, 2007
Benimur
  • 6966 Answers
SOURCE: ink cartridge can't be recognized
To my knowledge, only two (2) possible corrective actions:
  • clean the gold contacts of both the cartridge and the cartridge holder in the printhead; or
  • replace the printhead assembly, specifically the logic chip and sensor.
In some instances, there are reset procedures that maybe employed to trick the printer back into recognizing the cartridge. However, they are brand/model specific. If you could possibly postback the brand/model of your printer, perhaps we can come up with a procedure.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 10, 2008
  • 8 Answers
SOURCE: refill instruction
I cannot tell you how ti refll the Brother LC61. But I know where you can pruchase the ink cartridges for as little as $4.50 per. If you are interested, contact a representative at cartridgecorner@yahoo.com
Posted on Jan 04, 2009
MXM450
  • 62 Answers
SOURCE: need to change the toner/ink cartridge for our cannon 7130 copier
Yes. Open the copier up (push the gray button on the left side) then grab the installed cartridge and turn it clockwise til it meets a mark (they are triangles i believe) then you should be able to pull it towards you.Careful thou, you might get little dirty! for installing the new one just do the same thing but on reverse gear :P (or read the instructions on the cartridge box, ok i needed to say it; my bad)
Posted on Jan 22, 2009
I have changed the colour ink on my canon mp460 but it still say empty
CL41, this is the one you are using for your cartridge.
Did you change your cartridge with brand new one or refilled one??
If you did with refilled one, the ink level won't go back with full.
This is the method how printer measures the ink level.
1. Each cartridge has a serial number.
2. As soon as installation in printer, printer recognizes the cartridge by serial #.
3. And the printer starts to count the printing document.
4. After reaching certain print counting, the ink level will show "low ink"
So my answer is even if you refilled your cartridge, the ink level won't change,
since printer cannot weight the cartridge or.....some other technology to measure each color ink level.
Thanks.
Jun 15, 2011 | Canon PIXMA MP460 All-In-One InkJet...
My canon pixma iP 1800 does not recognise refilled colour cartridge. Can you suggest a fix?
  1. For the not-so-tech friendly, installing ink cartridges in printers can be messy and time-consuming. Although companies such as Canon are constantly trying to make designs more convenient for all users, there are still several tips that can help new printer owners install Canon PG-40 printer cartridges without mess or hassle.
  2. Compatibility
  3. Although many printer cartridges are specific to only a few models, the Canon PG-40 printer cartridge was designed for use with many models of the Canon Pixma and even some of the Canon fax machines. As of September 2010, the Canon PG-40 ink cartridge can be used with the Pixma iP1600 through iP1800 printers, the iP2600 printer, the MP140 through MP190 printers, the MP210 printer, the MP460 and 470 printers, the MX300 and MX310 printers and the JX200 and JX210P fax machines. This versatility allows users to stick with the same type of ink cartridge over the life of several printers and allows small business offices an opportunity to buy one type of cartridge for all office printing requirements.
  4. Refill
  5. Replacing printer cartridges can be expensive and, if it is possible, as it is with the Canon PG-40, refilling is a cheaper and more environmentally friendly option. Refill the PG-40 by gathering a 10 cubic centimeter syringe with a 1.5-inch needle, a pair of latex free gloves, an MIS Yellow Drill Tool, Scotch tape and black ink. Remove the label from the top of the cartridge and use the yellow drill tool to open the vent hole that was covered by the label. Next, load the syringe with 20 CCs of black ink and inject it into the ink hole (where ink leaves the cartridge for the page.) Make sure the needle reaches the bottom of the ink tank and then slowly inject the ink into the cartridge, stopping when the ink begins to well up at the needle insertion point. Now remove the needle and clean the top of the cartridge off to avoid color contamination. Put a small strip of Scotch tape over the vent hole and poke a small hole in the tape with a pin. Now reinsert the cartridge and run up to three cleaning cycles to calibrate the printer.
  6. Resetting the Ink Level
  7. While refilling ink in a PG-40 can save money, it can also cause difficulties when using the automatic ink level sensor. Reset this sensor by removing the cartridge after the printer has been calibrated and placing a thin strip of Scotch tape on the line of gold-colored leads nearest the ink hole on the bottom of the ink cartridge. Replace the cartridge and wait for the computer to display a warning about the ink cartridge being loaded incorrectly. Remove the cartridge and move the tape from the first to the second level of leads and replace the cartridge. When the PC displays a message that the cartridge is not recognized, remove the cartridge and replace without the tape. The ink level will be reset.
Jan 09, 2011 | Office Equipment & Supplies
Why won't my canon printer MP460 read my ink cartridges? It keeps saying "Cannot read ink cartridges" on the black ink.
Hi, are you using Canon or refilled cartridges? If you are using Canon, there's a problem with the cartridge. If you are using refilled cartridges it's because the cartridge has been used. When you first put a Canon cartridge in, the printer reads the cartridge and knows it's a new one, I'm not sure of the mechanics of it, I don't know if it blows a chip or fuse in the cartridge but it can read a new one. If it's been used, it can't read it so you get the message that it can't read it.
Turn off the staus monitor and the message will go and you can carry on printing, it won't tell you when the cartridges are empty, you'll just notice the print quality going downhill.
Jul 05, 2010 | Canon PIXMA MP460 All-In-One InkJet...
Canon mx700 not recognizing cartridges
I suspect that your have a damaged refilled cartridge. Also, you may have a clogged nozzle. Canon printers are sensitive to the quality of the ink used in the cartridges and refill ink sometimes does not meet the manufacturer's specifications. You can check this by inserting a new OEM cartridge, running the deep cleaning utillity three times and a aligning the printhead. The other problem may be that the electronic chip on the refilled cartridge may either be damaged or blocked by dried ink. In any case, you need to discard the failing cartridge and replace it.
Let me know if this solves the problem. Thanks.
Feb 22, 2010 | Canon MX700 Office All-In-One InkJet...
Canon MP460 will not recognize its own brand ink
Try removing the installation of your printer then install it back again. If you do not have the drivers, you can find them on Canon's site.
Hope that will help!
Feb 21, 2010 | Canon PIXMA MP460 All-In-One InkJet...
Canon ip1200 black cartridge wont recognize after i refill
Dear lim,
Here a solution for you. The cartridge of this printer has memory chip that store ink level data inside. Once the cartridge is empty we cannot restore ink level data to be full. To continue using refilled cartridge you need to deactivate ink level detection function first. Perform this step: when the message 'The following cartridge cannot be recognized' appears press Resume/Cancel button. Do this for each cartridge you refill;if you refill both black & colour cartridge do this tip two times (once for each cartridge).
Please rate this as fixya ok.
Regards,
Dec 02, 2008 | Canon PIXMA iP1600 Printer
Error message U051 on canon MP460
Check the Label on the cartridge if it covers a certain area then you will get an error message. Compare it with a good cartridge the label should nearly touch the lugs at top end. Only applies to refilled Carts.
Oct 04, 2008 | Canon PIXMA MP460 All-In-One InkJet...
Cannot recognize ink cartridge
I have about 6 canon printers with a 3in 1 using PG40 and CL41. I have never encountered the problem you have. I have looked into some other sites and noticed a number if CLI-8 cartridges being replaced by Canon. I think there are only 2 probable problem areas, he cartridge or the software you are using. I suggest you call up Canon and complain about this problem. Seems like you got the printer 6 months or so ago. You should able to get to do something like replace the printer or cartridges. I'm assuming that you don't refill or have your cartridges refilled so the contact points should not be messy w/ ink. You can try cleaning the contact points on the cartridges and printer. But I'd call Canon and explain to them the situation and see if they can solve your problem. Solve I'm implying is to replace your cartridges or printer. Let me know if this helps.
Jul 22, 2008 | Canon PIXMA MP460 All-In-One InkJet...
"Verify that you are using Canon(TM) cartridges. The technology has progressed to where they have modified the ink to be identified by their printers. You cannot currently use refill cartridge inks to refill Canon cartridges. If that is not your issue, then try removing and replacing the cartridge(s)and reset the ink level indicator.
Regards,
Eagle"
Honestly.. There is absolutely no way for Those Canon printers to "look inside" or "Detect" the formulation of ink inside the cartridge...
Canon CL-31, CL-41, CL-51, CL-52 Print cartridges have the highest electronic _Failure_ rate of anything other inkjet cartridge on the market. Canon is aware of this. Replacing the Cartridge is the only sure-fire way of fixing this.
*sometimes the printer will tell you its the color cartridge, when in fact its the black cartridge. its advised to replace them both during these error messages.. it'll save you a trip, and the customer service rep's head. haha"
Using an Aftermarket or "re-filled" canon original cartridge is a sustainable resource for anyone looking to re-use an end-user item, and save money in this "tied-selling" market.
I proved you wrong by replacing my inkjets with Oringinal Canon PG-40 black, and CL-41 color cartridge. I ran them until they were empty. Bypassed the Ink Metering System explained to me through the canon software provided during the printer installation, and continued to print with them until they were 110% bone dry empty, laying absolutely no ink on the page. this took approx. 3 hours from perfect start, to finish.
If "canon printers have progressed so much as to distinguish formulations of ink" then.. this canon sure was the PICK of the litter. it continued to print *** as the day it was purchased, while not laying a single droplet of ink on the page.
get a life. stop dissing the aftermarket with your un-supported facts!
reguards,
inkjetech_007
Oct 10, 2007 | Office Equipment & Supplies
87 people viewed this question
old marine
old marine
