Question about Sole Fitness Sole F63 Treadmill
Wall breaker trips when power switch is flipped on
We had an electrician run a dedicated 20a breaker for the treadmill. The panel breaker still trips.
    New Friend:
  • 28 Answers
Bad Transformer on treadmill
Posted on Feb 08, 2019
    Habit-Forming:
  • 62 Answers
By dedicated breaker, do you mean a dedicated line with It's own breaker? If it is a gym quality unit then call the same electrician back in to explain his work. With a dedicated line the breaker should not be tripping.
Posted on Jan 16, 2018
    New Friend:
  • 21 Answers
Find the specification tag on the treadmill and note how many amps it draws...
SOURCE:
SolutionGuy
  • 331 Answers
SOURCE: Dryer trips breaker after 5 minutes...BRAND NEW!!
Hi Shel,
Based on your description of the problem, I came up with a theory. Your new dryer is of higher wattage than your old one and is therefore pulling more amperage. I'd also make a bet that your dual breaker in the basement has the number "30" printed on it. Whether it does or not, your breaker should be replaced.
NOTE---> Ideally, you'd begin by removing the breakers (there are 2 of them) from the panel and take them with you to Lowe's, Home Depot or Ace Hardware and ask one of the sales associates for a 40 amp version. This way, you'd be sure to get the right ones. If you don't want to do that, then open up the breaker box and copy all the information off of the dryer breaker (also take not of how wide it is... 1/2", 3/4", etc...). Basically you'll need who made it (Square D, G.E., etc...) and how wide it is. Use this info to shop for a 40 amp version.
I don't need to tell you that working inside a breaker box can be EXTREMELY DANGEROUS if you are not careful. Here is a picture of the inside of the box, NOTICE THE LUGS AT THE TOP! THEY ARE ALWAYS "HOT" AND SHOULD NEVER BE TOUCHED!!!!!
Before you remove the panel to access the interior of the box, TURN OFF YOUR "MAIN BREAKER" (it's shown in the picture above).
Now that all of the safety stuff is covered, all you gotta do is pull the bad breaker out and install the new one! Piece of cake, really. Here's a video on how it's done.There ya go! If this has been helpful for you, please remember to rate this solution. Thanks for using FixYa!
SG
Posted on Apr 03, 2009
john224
  • 1378 Answers
SOURCE: polaris booster pump overheats and trips the breaker
The motor may be repairable. Check with local electric motor repair shops in your area. The motor may need to be replaced though and if so, we sell it at www.arrowmotor.net
Posted on Jun 14, 2009
  • 132 Answers
SOURCE: two 15 amp arc fault breakers installed on two
It's possible that the first breaker that you said does not trip - it could be that breaker is failing to trip on a bad circuit. That is, it could be you have a bad circuit but that first breaker is not detecting it and pretends everything is OK. If your new breaker trips on the first breaker's circuit, the curcuit it probably bad and the breaker in not working properly. The most common problem for failed circuits is a stray ground wire in a box somewhere in the curcuit resting against a hot or neutral wire. You'll have to take apart every connection on that curcuit to find it. Not fun.
Posted on Jun 27, 2009
SOURCE: outside unit tripped the breaker. flip the breaker
either the start/run capacitor,or , fan motor is bad.-
Posted on Jul 06, 2009
agent91
  • 2100 Answers
SOURCE: I have replaced my pump and have hooked up the
You have something along the line that is grounding. One of your wires is going to the wrong place. If you have it wired for 220 v, you have 3 wires going in, or 4, one will be ground, one will be neutral, and 2 will be hot. The connector at the motor should say line 1, line 2, white wire to neutral, and the ground possibly outside. If it is 110 v, it will have only 1 hot wire going in. If it is on a gfi breaker, then it has to be right or it will never stop tripping. The slightest thing wrong and it trips. If it still trips after all that, try it at 110 v and see what happens, It might be the motor at fault.
Posted on Feb 25, 2010
Will not power up. Trips dedicated breaker. power supply OK to junction unit
any unit that trips a dedicated breaker needs urgent attention from an accredited electrician
turn it off and leave it off until this is done
Jun 21, 2015 | Boating
I have just brought a older style lie Down sunbed! My thing is the bottom section works fine ! But the top one as soon as I plug in the plug it trips the switch
Some of these units use more than 10amps [2400watts at 240volts 1100watts at 110volts] AND will cause the fuse to blow/or circuit breaker tripping every time on a normal wall outlet/circuit.
Best option is to get your local ELECTRICIAN to run a "DEDICATED" 15amp [or larger] CIRCUIT and wall outlet in the room where your Sun Bed is installed ...
The electrical amperage requirement for your unit should be found on the manufacturer's Compliance Plate [on your unit] ...
ALSO it is possible that there may be a FAULT in the top unit [sometimes caused by a damaged supply cable on the older type "CLAM-SHELL" units] ...
Probably best to have it CHECKED/TESTED by your local Electrician.
Sep 20, 2014 | Health & Beauty
Wire schematic
If the welder is single phase 110v use a dedicated 20A standard household circuit. If 220v single phase use a 50A RV or weld receptacle connected to a 50A dual breaker with common trip. Make sure the breaker is the same brand as your panel. If the welder is 3-phase connect the wires B-O-Y (Brown Orange Yellow) at the breaker (3 phase 50A) and see if a color code match can be applied at the welder, although the only issue is whether the wire feed will run forward or reversed. If the wire feed is reversed then move any two wires of the B-O-Y set to change the rotation.
Aug 25, 2014 | Welding Tools
No power
Check the reset/off circuit breaker located on the
treadmill frame near the power cord. If the switch
protrudes as shown, the circuit breaker has
tripped. To reset the circuit breaker, wait for five
minutes and then press the switch back in.
Mar 07, 2014 | Proform XT 70 Treadmill
Precor 9,31 treadmill tripping internal breaker
You may want to check how many outlets or other items that you have on the breaker. When those treadmills go faster, they draw a lot of amperage. Not much that you can do except for unplugging what you aren't using on that circuit until you are done. If you run an extension cord to another circuit, that draws even more amperage or hire an electrician to install a larger breaker for you.
Jul 10, 2017 | Exercise & Fitness
I have a Ntl 1094 Track C 1900 and the problem i have is ; the drive motor for the belt trips a breaker in the house breaker box. The belt will start and run for approx 5 seconds and the the breaker...
first check and see what the circuit is rated at. it you have too many thing on that circuit(light,tv,etc) this will trip your breaker because of the amp draw of the treadmill. nordictrack recommends a dedicated circuit of 20amp. you may nned to have a circuit put in with 12/2 wire
Oct 17, 2013 | NordicTrack Exercise & Fitness
What does Error E7 indicate? Thanks!!
Elv. Motor out of range Calibrate elevation motor
On/Off Switch Check if unit is turned on
Fuse Check fuses on MCB
Insufficient power source Plug unit in a dedicated
120V, 20A outlet
Run software calibration for easy diagnostic and fix it.3af94116-465b-4b36-b53e-109e9b5ccac3.gif
God bless you
Jun 10, 2013 | Lifespan TR 1200i Folding Treadmill
Circut board trips electricty board
Treadmills are machines with a considerable pull of electricity. Make sure you are operating on a dedicated circuit.
Most users have the machine plugged into a spare bedroom outlet ehich is either not dedicate (power source spread out to more then one outlet) or is a GFI outlet (Ground Fault Indicator).
These outlets are used so homeowners do not overload an outlet in an area where a resident will sleep and be in danger of a fore or death.
Usually in the first few pages of your owners manual it will give you the requirements for your machine.
You can run an extension cord to another room with a dedicated outlet, but the extension cord does not transmit all the power coming out of the outlet and will eventually lead to other issues, usually electrical issues within the machine.
You can use a multimeter to see what else could be the issue with your outlet, but will want to consider having an electrician put in a dedicated outlet.
Jan 05, 2013 | Proform 400 CT Treadmill - Treadmills
I have a rodgerblack gold treadmill ag-10302 when i switch it on at wall it trips the circut in my fuse box help please
1) please use a table lamp in connect in wall circuit. if the c.breaker trip again, the problem is your outlet wall. Call electrician or test the wires for touch each other or ground improperly, and fix it.
If the circuit is NOT trip, test the power cord for defective 2) test the main switch for shot circuit 3) test the c. breaker for defective 4) test the motor see the if the motor if short circuit see my personal TIPS for help motor , see the diagram attached. 5) test the output board, the board can be short circuit and replaced. Happy NEW YEAR God bless you
Dec 31, 2012 | Reebok Exercise & Fitness
Sole Fitness Sole F63 Treadmill Logo
159 people viewed this question
Top Sole Fitness Exercise & Fitness Experts
Art Wilson
Art Wilson
Level 1 Expert
Ross Metcalfe
Ross Metcalfe
Are you a Sole Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
