Question about Cell Phones
How to use the touch screen mode? - Cell Phones
    President:
  • 1,884 Answers
Use the stylus that came with the phone. Or use your finger to touch the icons on the screen.
Posted on Jul 30, 2009
Repairing Touch screen
Have you check its manual particularly its features, does the unit capable on touch screen mode, or may be you need to set some settings to enable touch screen mode..
Jun 04, 2015 | Minolta bizhub 200 All-In-One Printer
Position of Touch Panel.
It's been awhile, but I think you go into the test mode then hit one of the hard keys (start, threader, reverse). I know there is a backdoor for this.
On newer Brothers you touch the screen and hold while powering on, but I'm not sure yours does it that way.
Oct 18, 2014 | Brother PC-8500 Pacesetter Embroidery &...
TOUCH SCREEN
Initial Mode Function Setting Procedure
1. Remove the Compact Flash Cover [1].
2. Press the Warm Restart switch [2].
3. When "." appears at the center on the left-hand side of the screen, enter "3" from the
10-Key Pad.
4. Enter the 8-digit service code and touch [END]. (Default value: 00000000)
Initial Mode: Total Clear
Touch Panel Adjustment
Marketing Area
Image Data Clear
Clear FAX Setting
Date/Time Setting
Trouble Reset
• To adjust the position of the Touch Panel display
• Make this adjustment if the Touch Panel is slow to respond to a pressing action.
• When the control panel is replaced.
1. Touch [Touch Panel Adjustment] from the Initial mode screen.
2. Following the arrow mark, touch the four points (+) sequentially on the screen using a
pen.
NOTE
• Be sure to touch the very center of each point.
• Use care not to damage the screen surface with the tip of the pen.
Feb 12, 2014 | Konica Minolta Office Equipment & Supplies
Touch screen on minolta bizhub 200 not working all the time
Need a new touch screen.One other option. Push utility/counter meter count then press stop 00 stop 02. Places machine in maintenance mode. Then press the utiltiy/counter will see maintenance mode press that find touch screen adjustment. follow the screenthen press start. T clear maintenamce mode and flashing start button. Power off machine main power left side of the machine to the rear.
Feb 07, 2014 | Minolta bizhub 200 Copier
Recovery mode with out using the power button
An iPod Touch's "Recovery Mode" is for alleviating major operating system issues.
Recovery Mode rolls back your iPod's operating system, stripping problematic updates and downloads from the unit.
The goal of this total system recovery is to revert the iPod to a stable, usable version.
Before you use Recovery Mode, exhaust other troubleshooting methods.
In some cases, Recovery Mode is triggered automatically after a failed system update or system restore.
When it goes into Recovery Mode automatically, you cannot use your iPod until you complete the recovery process.
You can get your iPod Touch out of Recovery Mode using Apple's free iTunes software.
Turn on your computer and open iTunes.
If you are prompted to download any new iTunes updates, install the updates before proceeding.
Plug an iPod USB cable into your computer.
Do not plug the other end into your iPod Touch yet.
Turn off your iPod Touch. If the iPod Touch is already shut down, skip this step.
Press and hold the Home button on your iPod Touch, and plug the other end of the USB cable into your iPod Touch.
Release the Home button after you see a white USB icon and the iTunes logo appear on your iPod Touch's screen.
At this time, a pop-up should appear on your computer screen, explaining that the software has detected an iPod in Recovery Mode.
Click "OK."
Click on the iPod Touch from underneath the "Devices" heading on the left-hand side of your screen.
Click on the "Home" tab, and then click "Restore."
Once it's restored, your iPod Touch goes out of Recovery Mode and you can start using it again.
The restoration process takes a few minutes.
Do not disconnect your iPod Touch until a prompt appears, letting you know the system restored successfully.
iOS: Unable to update or restore
http://support.apple.com/kb/HT1808
Jul 31, 2013 | Apple iPod touch
How do I turn down the volume on outgoing fax transmisions for a Konica 7022 Copier.
To disable the speaker, perform the following:
1. Access the Key Operator Mode (press HELP, then touch Key Ope mode at the left front of touch screen and then enter Password if necessary).
2. Touch 2. FAX from the Key Operator Mode screen.
3. Touch Line Parameter Set from the Fax Initial Setting menu screen.
4. Use the UP and DOWN arrows to select Line Monitor Audio.
5. Touch EDIT to switch from ON to hear transmissions, or OFF based on customer demand.
good luck
Jul 15, 2009 | Office Equipment & Supplies
I want to change my konica sitios 7020 printer to english,its in japanese
Procedure
Touch 1. System Initial on the Key Operator Mode Screen to display the System
Initial Setting Menu Screen.
2 Touch 2. Language to display the Language Selection Screen.
3 Touch ENGLISH, FRENCH, SPANISH, GERMAN, or ITALIAN
Touch OK to complete the setting and return to the System Initial Setting Menu
Screen.
5 Touch RETURN to restore the Key Operator Mode Screen.
6 If no further changes are required, touch RETURN to restore the Basic Screen to
perform copying operations
Jun 11, 2009 | Konica Minolta Office Equipment & Supplies
Ricoh Aficio 3025 Copier LCD Touch Screen out of Allignment
It's not in service mode, but rather in the 'self diagnostic menu'. Access it as follows:
Press "clear modes", 1 9 9 3, "clear/stop" (5 times).
** Do not try any other adjustments in this mode...only touch screen
please rate me :)
Apr 10, 2009 | Ricoh Office Equipment & Supplies
SCREEN WON,T STAY LIT UNLESS I TOUCH IT
You are simply in blackout mode. This is so at night you aren't blinded by the glow of a screen. Here are instructions right from the manual to turn on or off.
Blackout Mode On and Off
When Blackout mode is turned on, the monitor display will turn off to
reduce power consumption.
This additional power enhances the sound quality.
1 Touch [VISUAL] on the main source screen.
The VISUAL selection screen is displayed.
2 Touch [OFF].
The backlit-display portion goes out.
3 Touch [OFF] again to cancel the display backlight.
To make the setting, set to “Setting the VISUAL Touch Button” (page
34).
If any button on the unit is pressed during Blackout mode, the
function will be displayed for 5 seconds to show the operation before
returning to Blackout mode.
While the backlighting is turned off, the function indicator
Jan 24, 2009 | Alpine IVA-D310 Car DVD Player
Tuoch screen
i have a problem with my P990i that my touch screen is not working properly only the bottom line is working and when i touch the screen it always shows the network and button with text says flight mode.
Aug 17, 2007 | Sony Ericsson P990i Cellular Phone
Cell Phones Logo
15 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
