Question about Sony Televison & Video
Need to understand what to order. TV will not go
Need to understand what to order. TV will not go on, red light indicator goes, meaning lamp needs to be replaced. Do I need just the lamp and/or housing too? Can I do this myself?
  • 261 Answers
Actually you need just the lamp, I mean you can get the housing also, but it's not necessary. WIth the lmap itself you'll be just fine. It's not hard to change, there's this page where they have video guides of how to replace them. www.fixyourdlp.com
Posted on Jul 30, 2009
How much is it to replace the lamp and how do I do it. The red light flashing for lamp means the lamp needs to be replaced for sure?
I'm sorry that the LAMP light flashing. If the screen becomes dark, the color looks unusual, or the LAMP indicator on the front of the TV flashes, it indicates that the lamp of the TV needs to be replaced. Based on the information you have provided, it is the time to replace the lamp with a new one. XL2100 is the replacement lamp for the TV.
The Original Replacement LAMP costs $199 from Sony. Please click hear to order it online.
Please refer page # 16 of the Instruction Manual of the TV to get the instructions to replace the lamp.
Click hear to download the Operating Instructions if you don't have one handy.
I hope the information helpful. Thanks for understanding. Please let me know if you require any additional help/clarifications.
Aug 01, 2011 | Sony Grand WEGA KDF-42WE655 42" Rear...
When you turn of the TV the POWER indicator flashes green for several minutes. The TV never comes on. After the several minutes of the POWER indicator flashing green, it stops, I hear a click and the...
A continuous flashing red light with the word LAMP on it would definitely mean you're going to need to spend a few bucks on a new lamp....or for a few more, upgrade to a TV from this century that doesn't require lamp changes :)
May 11, 2011 | Panasonic PT-52LCX66 Projection Television
I have a Panisonic PT-52LCX15 I replaced the lamp and now I'm trying to reset the LCD meter, I have tried holding the vol button and the split button and the red lamp light still is on, maybe you could let...
The lamp light should NOT be RED.
The lamp light should be yellow for the lamp timer warning.
There are two ways of retting the lamp timer=
1) on the TV use the vol - button. push until vol goes to zero, then keep holding it down
on the REMOTE push the "split" button
the yellow light should go out indicating that the lamp timer has been reset
if this fails to work,
on the REMOTE, use the "PLAY" button, instead of "split".
you may have to try this a few times to get it to "take". you'll know when the YELLOW lamp light goes out.
However, a RED LAMP light means you lamp is not working or missing.
reseat your new lamp into the TV...and be certain the LAMP DOOR is securely CLOSED.
Apr 12, 2011 | Panasonic Televison & Video
I have Philips 50PL9126D/37 The red light on the front where the power indicator is keeps coming on. What does this mean? When it comes on my screen goes blank. Any suggestions?
The tv projection lamp in this tv been in the tv it like 2 years or more,tv in used daily like 4 or 5 hrs every day?The red LED light indicator is on,have a "LAMP"word written on the bazel frame?Yes,tv projection lamp life is over or eding.Tv reqire a new projection lamp.
Apr 05, 2011 | Philips 50PL9126D/37B 50" DLP TV
Status indicator flashes 3 short times, then one long red flash
Once the status light blinks 3 times, this is an indication that there's a problem with the lamp. The lamp may need a replacement.
If you replace the lamp, but get the same problem, check the inverter board.
If you're not sure where the inverter board is, then you may need to contact a pro for your safety.
Good luck and have a good evening!
Feb 14, 2010 | Mitsubishi WD-52327 52" Rear Projection...
Lamp Indicator is Red
a 41 error code for a short is usually caused by the power PWB. The power board will need to be replaced
May 30, 2009 | Mitsubishi WD-52525 52" Rear Projection...
SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
A1085447A* LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
May 18, 2009 | Sony KV-36FV26 TV
My Sony HD-TV KDF-50E2000 is about 18 months old. The picture went out. The green on light stays on for only a few minutes then goes off and the red lamp light flashes. You can turn the Tv on again and the...
How many times Red Lamp flashes, its important as it shows problem and its location in tv. Below is detail of lamp blinks and you may know the problem area in tv by counting lamp flashes.
Need further help, let me know.
Sep 13, 2008 | Televison & Video
No picture-lg ru-52sz51d
Depending on what light is flashing it could be a few things. If the Lamp light (the middle one) is flashing that is problem with or around the lamp. That orange or amber light is an indication that the lamp is reaching the end of its life
If it is the Temperature light (the far right one) then the TV is shutting down because it is over heating and you need to check the cooling fan.
Nov 14, 2007 | LG 52SX4D 52" HDTV
Televison & Video Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
