Question about Sony Dvcam DSR-PD150 DV Digital Camcorder
When I record audio on my sony PD150 it cuts out for a second every 3 or 4 seconds. I tried adjusting the channels and settings, but it still cuts out
2 Suggested Answers
  • 149 Answers
SOURCE: Playback of all recordings sound goes in and out
clean the head with the head-cleaning cassettes
Posted on Oct 08, 2009
Recorded album and first track is cut at beginning everytime
you are going from a record(vinyl) to what before you are doing the ipod? a cd or a tape..when recording the tape..remember theres 30 seconds of plastic leader on those reels..need to forward the tape past that leader to the actual tape before the recording begins..the only other thing is that some recordings that are protected will automatically screw up your recording so as to stop copyright infringement..it may be sending a purposely blank signal for a brief period..and thats encoded into the original recording..
Mar 15, 2014 | Sony Sound Forge Audio Studio 9
When i install application or games on my sony ericsson aino it display operation failed, how can i fix this?
Sony IC RECORDER ICD BX-800 (!without USB connection!)
What you need:
- newests audio drivers in Windows 7 (updated audio-drivers)
- audio cable 3,5 M (male) both ends M-M (male-male)
- freeware application Audacity for Windows (with LAME)
Howto step by step:
- one end of audio cable connect to dictaphon's headset (earphones) jack in recorder Sony IC RECORDER ICD BX-800
- other end of audio cable connect to PC/notebook microphone (or LINE IN)
- nothing special setup (adjust) regarding Audio in Windows 7, the device for record Audio keep Microphone (default)
- in Audacity set very little volume "Input Volume Slider" and "Output Volume Slider" (for example both 0,1)
- in Audacity like Input Device set "Input (Audio device High Definition Audio)": !Don't set in Audacity like Input Device "Microphone"!
- Audio Host: MME
- Output Device set "Speakers (Audio device)"
- Input Channels set "2 (Stereo) Input"
- Sampling (Hz) set 4410
Jul 10, 2013 | Audio Players & Recorders
Non of the right side outputs work on the second channel I've tried the rca main and record and eve the 1/4
I do not know this mixer but it is possibly the pan control, it may simply be adjusted to one side. It sounds like the mixer failed.
Jul 03, 2012 | Numark Dxm06 2–channel Digital Tabletop...
I have a Sony ICD-BX800 IC Recorder. I have purchased and hooked up the Audio Cable to transfer the recordings to my computer (I need to email them to someone.) However, I did a test recording, and the...
What you need:
Howto step by step:
- Audio Host: MME
- Sampling (Hz) set 44100
Dec 26, 2010 | Audio Players & Recorders
Recording and Playback error
I'm not sure what the solution is, but I am having the same probelms, and I would appreciate any help with this since I am shooting a childrens camp and I am fairly isolated and don't have the time to swop cameras or send it to get fixed. I need to know if the recording is fine (video and audio) but the playback is not working correctly...or is it not recording correctly or playing back correctly. The sound cuts out from time to time in playback. Thank you.
Dec 09, 2009 | Sony Dvcam DSR-PD150 DV Digital Camcorder
How do you program channel and set time on clock?
2001 - 2002 Models:
Press the "CLK" (clock) button until the time is displayed, then press and hold the "CLK" button for at least 3 seconds until the time indicator blinks.
While the time is blinking. turn the rotary encoder to increase or decrease the minutes.
Once you've set the clock it will automatically return to normal operation after 5 seconds.
Pre 2000 Models:
Press and hold the "CLOCK" button for 3 seconds until the time indicator blinks.
Press "PRESET 5" to adjust the hour setting.
Press "PRESET 6" to adjust the minutes.
Press "CLOCK" again to exit clock adjustment mode
Hope this helps.
And to set the stations get the station you want and hold down one of the buttons from 1-6 to progream the station. you need to hold the button for about 5 sec.
Jan 22, 2009 | Alpine CDM-7833
Delayed vocal
If you're recording to an audio program on your computer (e.g., Cubase), there typically is a slight delay in the tracks you record with the first one (such as a slight delay in the vocal when layering over the guitar track). ou can change the delay in the "Preferences" for the audio card in your computer or you can remove the delay manually.. I do the latter. I record using the Audacity 1.3.3. program on a Mac G4. I find that get a 0.3 second delay in tracks layered onto the first track. So, after I record a track, I cut the first 0.3 seconds froom the beginning of the track (I give myself at least 10 seconds of "dead air" at the start. and keep playing the tracks until they're synchronized. Takes a good ear, but really is the best way to synchronize the tracks.
Nov 10, 2007 | Alesis Multimix 8 USB 8-Channel Mixer...
Vcr to tv connection
There are probably a couple of different ways to hook things up. One is you hook the VCR "in between" the indoor antenna & the set. Hook antenna to VCR RF/Ant In, then VCR RF/Ant out to the Antenna input on TV. Your VCR will then be able to record one channel, while you watch another on TV. To play back the VCR, or do any VCR setup, TV channel must be set to either channel 3 or 4. The other way is to use the Video & audio input/outputs on the VCR & TV. You will need the appropriate cable(s). Match the VCR video/audio outs with the set of inputs on TV. Video and audio out on the TV go back to the video/audio inputs on VCR. In order to view VCR playback, menu setup, you will need to select that input (line, aux, video 1 etc.) on the TV. This hookup probably won't allow the recording of a second channel while watching one. As regards the hft channels, I assume you live in an area where such is being broadcast. The TV can probably be put into a programming mode where it will scan for all available channels, and put them into memory, or they can be programmed manually.
Jun 13, 2007 | Goldstar GVR-E435 VHS VCR
Audio problem with sony sxrd 60" hi def
i am having the same problem, but mine occurs about every 3 minutes. i get a 1 second pause in the audio that shows up in the recordings as well as live. it doesnt seem to matter if it is hd or not, but very frustrating.
Jan 20, 2007 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Sony Dvcam DSR-PD150 DV Digital Camcorder Logo
27 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
