Question about Whirlpool Heating & Cooling
Have air conditioner that freezes up after setting it on the lowest setting. checked the freon on the unit and the suction pressure was at 42 on the 22 scale & about 70 on the psi scale, low side. no high side tap to get reading. fan motor very hot, rpm? have some #'s off of the unit 12078 ace244pt3/201s170001562.... compressor make / modle.. HIGHLY SHW73TC2GP1 ...4390H1793741 WHAT SHOULD THE LOW SIDE READ ON THIS UNIT ACCORDING TO DESIGN SPECS& SHOULD THE MOTOR BE SO HOT YOU CAN'T KEEP YOUR HAND ON IT, WHAT SHOULD THE MOTOR AMP OUT AT. NEED INFO AS FAST AS POSSIBLE BECAUSE THE AIR IS FOR ELECTRONICS ROOM FOR THE SHERIFFS DEPT.
  • 2,236 Answers
If it's freezing up, chances are the freon is low, but read the info on the panel near the taps or the compressor to find out how much you should have. you need r-22 (if that is what it takes), guages, a thermometer for dry and wet, a temperature sensor for the tubing, and an epa license for moving freon. and there has to be a high side tap. the lower the pressure, the lower the temp, but if the temp after the metering device is below 32 f, it'll freeze. also if the condensate drain is clogged and the air flow across the evaporator coils is restricted.
Posted on Jul 30, 2009
HOW TO ADD FREON TO A WATER COOLER
You need to check the line pressures on both the high and low sides before adding/removing freon. If you are not familiar with this process you should consult a professional.
Sep 11, 2014 | Heating & Cooling
Why is suction and discharge lines of Goodman WMC24-1A split ac system freezing up.?
Low on freon, dirty evap, dirty filter or maybe restricted at the metering device
Jul 20, 2014 | Goodman Heating & Cooling
Amana air conditioner unit, model ARUF182416AA keeps freezing over. filter is clean.
Freezing is caused by low freon pressure sounds like your unit needs to be charged.
Jul 26, 2012 | Amana Heating & Cooling
Have Ptac units that work fine one minute and 2 hours later just blow warm air.. some that also freeze up the front coils
I think your PTAC is under charge, if the air filter is clean and the evaporator is also clean together with the blower. Check the freon charge and refill if suction pressure is below 50psi and discharge is below 190 psi.
Sep 03, 2011 | Amana Heating & Cooling
I i`ve got a haier split type air conditionner model HSU12XCA on R22 gaz which barely cools and freezes after a while. The suction pressure is at 120 PSI and it is freezing on the liquide line. I`ve clean...
The unit has a leak and is low on freon...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jul 12, 2011 | Haier HSU12XCA Cooling Only Mini Split Air...
Unit is fully charged but suction line freezes
hi there,
this sympton persist in over charging of freon it is call super charge,exessive charging of freon resulted to freeze your suction line,this is bad for the cycling process.to reduces freon charging purge out exessive freon on low side charging port.make sure service charge pressure gauge valve was installed.to determine the exact operating pressure. have a nice day fix my rate,thanks a lot.
May 14, 2010 | Heating & Cooling
The unit outside is getting ice around the line close to where you put refrigerant in. House not as cool as needed.
Freon is low. Sounds counter-intuitive, but the large return line should be cool( even have condensation on it) but never cold enough to freeze.Either use factory pressure settings or add just enough Freon until Ice melts. If unit has a high-side sight glass there should be no bubbles present. Do not overfill.
May 28, 2009 | Whirlwind FH-778 Air Conditioner
Problem with central air condition
that depends on the size of the unit and lenght odf the line set.. to give you a general answer your suction pressure should be about 70 PSIG and you liquid line (small line) should be between 245-265 depending on the outdoor temp you will need a set of freon gauges to check this these readings are for an R-22 system if you have R-410a the readings will be much higher
Aug 20, 2008 | Whirlwind FH-778 Air Conditioner
Goodman Model CK60-1C with White Rogers mercury tube thermostat
The contactor on the outside unit is sticking and must be replaced. The inside unit cycles off and the outside continues to run causing the refrigerant lines to freeze up.
Jul 29, 2008 | Goodman CKL60AR60 Air Conditioner
Heating & Cooling Logo
90 people viewed this question
Top Whirlpool Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Tim Whalen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
