Ge Model DPXR473EWOWW. Timer runs in timed dry mode no in Easy Care mode (More dry to less dry to cool down
Do you have heat?does it stay hot while in coll down?if so your heating element is grounded,open the door,look up and remove the two screws holding the top panel in place,pick top panel up just a little and move it to the left that should remove the top panel, put it on cool down or no heat and run it,if the heat stays on this is your problem the element is sagging and touching the metal cover around the element,the way the timer works is on timed dry it counts down like a clock until it turns off when on more or less or auto same thing the dryer starts,the heat comes on and when it hits temp. the heat shuts off when the heat is off the timer will advance to off when the heat starts again the timer stops,if the element isn't grounded then you still could have a bad element there are two elements in your dryer if one is broke the timer won't advance or some have only one element so if the timer doesn't advance you probably have no heat or a bad cycling thermostat or a bad sensor up front where the lint filter is.you'll have to check them with a meter.first thing to check is the heater located behind the drum.
very detailed description of what I need to do Thanks
no problem hope it helps you out.
mr. trachsel do you know how to use a meter if not it's very easy,go online or an automotive store should sell meters,get a multi meter one that you can do continuity checks with,set the meter on 20k ohms,you'll see a 1 on the screen,touch the leads together and you'll see anything but 1 whenever you do this you want the dryer unplugged,remove at least one of the wires that go to the part you're checking,put the leads one on each side where the wires connect to the part,if you see 1 the part is bad or open,if you see anything else but 1 the part is good or closed,i should have told you this but when someone writes in i just take for granted that they know this,i hope this will help you out,if you do repair the dryer and have anymore questions let me know i check in usually every night.
SOURCE: My Whirlpool Dry Model GGQ9858JQ1 turns off in heat mode after a few minutes
HI. thanks for the question. the motor seems to be at fault here. did you clean the venting from the dryer to the outside. , did you clean the lint inside the dryer. if not do that, thanks.
SOURCE: Maytag Nepyune not drying completely
There is a cheap PDF repair manual on eBay for this model. It is item number
200258764242.
Premmy
SOURCE: Dryer takes a very long time to dry a load.
Some dryers have more than one heating elliment..
A way to check is -- take the exaust hose off.. Put a mirror so you can see into the hole & hopefully see the heating elliment(s).. When running they should glow like a stove burner..
If it is not gloing its not working & needs to be replaced..
I suspect that one may have went out..
I hope this helps !!
Please rate me good ;o)
SOURCE: I have a GE front load dryer, model DBVH512EF0WW.
Try unplugging from wall for while and then see if this resets it.
