SOURCE: Canon IR 1600 Error message E000
You'll need to replace the fuser unit. Not exactly the cheapest part of the machine...
Unless, that it, you were taking things apart and happened to unplug something accidentally. If you take the cover off where the paper comes out, look at the connectors directly inside there under the black piece of paper that you'll see. If one of those are pulled out, it could cause the problem.
Otherwise you need to replace the fuser unit.
Erice
SOURCE: canon iR 2016 copier shows E019 system error
Your waste toner bottle is full. Needs to be replaced or emptied. I believe the bottle is located in an area that requires tools to remove it. If your machine is under maintanence you should call them to have it replaced. If not then you will need to empty it yourself. Be careful, take bottle out and wrap bag around the opening and turn upside down until all powder is out. then clean off and replace. Turn off machine and back on error should clear.
Hope this helps,
TankMurdock
SOURCE: Error code : E 604 of Canon IR 400
It means that you are having a problem with the hard drive boot up program... You will need to replace the hard drive.
SOURCE: canon ir 1600 my copier print copy image is very poor
iR1600 are special machine that needs a little bit more care.
First, clean the laser unit and optics ( beneath copy glass too ). Then use some polisher and polish the developing cylinder and clean/replace developer cylinder blade.
Use GENUINE CANON DRUM UNIT and GENUINE TONER.
SOURCE: USA - COPIERS - IMAGERUNNER 2230 Copier: canon IR 2230 r giving me an error E000024-0001...
eroor 000024-0001 error is found in cannon ir 2870 machine, how is solve the problem
