Question about Cuisinart Grind and Brew 10 Cup Coffee Maker
I clean it everynight but it still leaks coffee grins and coffee all over the place...this is the second coffee maker of its kind that i have had and they both have done the same thing. This only happens when i use fresh beans. i follow the manual and clean it every night. but no matter what i end up with water and coffee all over my kitchen counter every morning.
The coffee inlets on the top of the carafe lid get plugged with residue that sneaks through the gold filter... I stopped my machine from overflowing by soaking the carafe lid in vinegar for an hour or so then rinsing thoroughly.
Posted on Nov 22, 2009
  • 8,596 Answers
The two most common reasons for overflow or underflow have to do with the carafe lid and the filter basket - they key to smooth flow with this coffee maker is making sure the filter basket and carafe lid are making the proper contact with each other so that the center knob on the carafe lid pushes slightly up on the filter basket spring. Make sure the carafe lid is completely closed. Make sure the filter basket is pushed all the way down. Make sure you are not using the gold tone filter and a paper filter at the same time. For some reason, I get better results when the handle of the carafe is resting against the right side wall. If everything is in place, I would suspect a problem with either the filter basket being clogged or some problem with the carafe lid - call Cuisinart as they should be able to order these parts for you.
Posted on Sep 29, 2009
When brewing coffee about half the water comes out of the frothing nozzle instead of the coffee spout. The nozzle also leaks after the brewing cycle.
I would say that something has a hole in it, but if it doesn't it might have bad quality, and if it isn't that because the place where you bought it from sells good machines, then it still might have something that went wrong or something was misplaced. I'm not sure either, but that's what i think is the most likely reason. You could always try ask the place manager and ask him if there is anything wrong with your machine.
Hope it ind of helped!
May 30, 2015 | Jura Capresso Impressa E8 Espresso/Coffee...
How to repair a bunn commercial coffee maker
Hello, I thought I would help you at. I know you said your tank leaks. Problem Is i do not know if at my end it leaks because a hole in the tank or it is clogged and over flowing, A lot of times when a machine leaks, is because it backs up like a sewer system when it is clogged, meaning machine might just needs to be cleaned and descaled. So, here is the manual with all kinds of information. Please take the time to read its entirety, especially in the area of cleaning. Thanks Mike.... copy and paste this link into your browser.
http://www.bunn.com/pdfs/commercial/manuals/10424.0000.pdf
Thanks Mike ( The Bean Man)
Oct 01, 2011 | Bunn VPR Coffee Maker
The coffee is filled and yet when it begins to grin the beans it stops and tells me to add coffee. So I giggle around the coffee dispenser and sometimes it works, but the problem is getting worse. Seems...
Are the beans very oily? Oily beans can sometimes cause things like this. My suggestion is you take out the bean hopper and clean the beans under that because on my Miele CVA4066 there are usually more than a few beans and chipped off pieces of beans under the hopper which cause some trouble.
Jun 29, 2011 | Miele Coffee System
My gr10w bunn coffee maker leaks while using.I think it overflows the filter then leaks down. I use Bunn filters. please help!
If it is leaking out past the filter basket, it can be fron two things- either the basket edges are worn out, and is allowing water to leak past it, or the hole is being partially blocked by scale or caked coffee. in the first case, try replacing the filter basket. In the second case, you can either clean out thr hole or try running a drill bit through it to clear the hole.
Mar 13, 2010 | Coffee Makers & Espresso Machines
I need to know how to clean my ge coffee maker model 169165, the clean light has been on a while and it has become significantly slower in brewing
Remove the carbon filter. Place a solution of 1/2 water, 1/2 vinegar into the machine. Hold down the cleaning button for 3 seconds. Cleaning cycles on and off for 1 hour. After complete, run 1/2 pot of fresh tap water through. Replace carbon filter with a new one. This should do it!
Jan 16, 2010 | GE 106591 Coffee Maker
Coffee is leaking onto burner and spilling onto counter, yet the carafe is not leaking. The problem seems to be coming from the drip
Does the coffee seem to be overflowing the coffe maker and the running down? If so the valve where the filter is placed is not working properly. When you place the coffee pot it actuates a small arm which inurn opens a valve at the base of the filter unit. If this is the case remove the unit and correct this unit. In speaking from past experience I know this happen to our coffe maker while the unit was apart being cleaned; it was just a matter of proper reassemble.
I hope this may have helped,
Tom
Sep 07, 2009 | DeLonghi Coffee Makers & Espresso Machines
I have a Briel MultiPro espresso maker. When I try to make coffee, water/coffee starts running over the edge of the basket and it "spurts" coffee and grounds after a few seconds.
The group head gasket needs to be cleaned or replaced. First get a brush and clean put the head, then insert back wash filter(basket with no holes) in portafilter, make sure that it is seated properly(atleast 90° angle with machine), then run the head if nothing leaks around the portafilter the gasket is fine, if it leaks then replace the gasket. Make sure that you press the stop button before removing the back wash filter.
Jun 23, 2009 | Briel MultiPro Espresso Maker - Brushed...
Where is the grind switch on the cuisiart grin & brew
Once you turn the machine on, it should automatically start to grind, unless you press the Grind Off button to make it stop.
Mar 15, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Directions on how to use my Black and Decker Espresso Mio coffee maker
Be sure the red rubber gasket is in place and clean (ridge side in) and bottom water cup is screwed firmly on to avoid leaking.
HOW TO USE:
1) Fill the bottom water cup with cold water up to the inside lip.
2) Set funnel into bottom water cup
3) Fill coffee basket with expresso grind coffee and level off. (Do not tamp or pack). Make sure it's filled to the top.
4) Place filter onto coffee basket and set coffee basket into funnel
5) Place brewer over bottom water cup and screw firmly into place.
6) Place unit with lid in the center of a microwave oven set on high for 1-1/2 minutes. If boil over occurs, reduce the brew time in 10-second increments until no boil over occurs.
7) Grasp handle to remove unit from microwave when finished brewing.
8) Remove lid and check the level of espresso in the brewer cup. Standard brew is at least 2 oz. If you don't have this level brew, replace lid and microwave on high another 10 seconds. Wait 20-30 seconds for bubbling to stop.
CLEANING/ADDITIONAL BREWING:
1. Under cold running water, unscrew the bottom water cup. CAUTION: It is normal for some water to be left in the bottom water cup. Both the coffee basket and any water in the bottom water cup will be extremely hot! If you prefer, allow the unit to cool for at least 3 minutes before unscrewing it.
2) To brew additional espresso, rinse Funnel, coffee basket and filter, then repeat brewing steps 1-8 above.
3) Parts are top rack dishwasher-safe -- hand washing filter is recommended.
Mar 10, 2008 | Coffee Makers & Espresso Machines
Cuisinart Grind and Brew 10 Cup Coffee Maker Logo
545 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
