Question about Amana Washing Machines
Water spills over tank onto floor
After completing the wash cycle, the machine starts to spin and exit the water; as it starts to spin (still full of water) water sloshes over the top of the tank and onto the floor. This, of course, happens more readily when the machine is on higher fill settings. The machine is 5 years old and this problem just started.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 12 Answers
Check for object in the drain hose going to the water pump or the pump going bad also check drain hose make sure is not blocked
Posted on Jul 31, 2009
How do i drain the washer for moving it
Mike,
I cannot tell whether you are talking about (1) the little bit of residual water in the machine after it's done, or (2) about a machine that's stopped mid-cycle with a good deal of water, so I'll respond to both cases.
(1) The lowest point in the washing machine is the drain outlet at the back to which the drain hose attaches. First remove the free end of the drain hose from the drain pipe and place it in a bucket sitting on the floor. That will get most of the water. Then place a towel on the floor and remove the other end of the drain hose from the machine. Remaining water will spill out from the outlet and hose onto the towel. You might get a little more if you lift the front of the machine, tilting it backward.
(2) If you can't drain the machine and it's full of water, you will need to siphon it. Take a piece of tubing, at least five feet long. You could use a piece of garden hose if you have nothing else. If you don't have a door or window nearby, you will need TWO buckets. Place the buckets on the floor in front of the machine. Place the siphon hose into the washer tub starting with one end to fill it with water. When it's completely in, cover one end, take it out, place it into a bucket. If the siphon doesn't automatically start, get down low on the floor, place the hose into your mouth and inhale. You may have to do this several times, possibly covering the tubing end with your tongue between inhalations. When the bucket is nearly full, switch the hose to the empty bucket and empty the first one. You will probably have several buckets of water. (Of course if your washing machine is near an outside door, you can simply start the siphon outside and omit the buckets.)
Oct 02, 2014 | Washing Machines
I have an Amana washer model NAV3330EWW purchased in November 2004. The washer will not drain during any of the cycles, It apparently went through the entire wash without draining after the wash or...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 28, 2011 | Amana Washing Machines
Somtimes my washer will put too much water in, then when it starts to agitate the water spills over the top of the tub and onto the floor. it happens (but not always) on the initial fill and when filling...
Remove the front panel. Pull the plastic hose off the air bell on the front left side of the tub.
Use a toothpick to clean the residue out of the hole in the air bell. Replace the plastic tube.
Set the washer on SPIN and turn it on. After the spin cycle finishes start the washer normally.
Aug 10, 2011 | GE Washing Machines
My washing machine is flashing err2 and is not spinning. I have lots of clothes locked in a machine full of water! Help! wm-1460tve bush washing machine
sounds like either the pump is blocked or broken.
bring machine forward so that you can tilt it back so as to be able to undo filter cover.
Be aware, lots (and i mean lots) of water will exit so a) have a big bowl and b) only undo filter cover a little so can retighten quickly.
Repeat until all water gone, remove cover completely and clean pump and filter area.
Refit cover, put machine back on floor, put on spin cycle and if it was a blockage, machine should empty. If not, new pump time I'm afraid
Dec 08, 2010 | Washing Machines
The water is not spinning out. the water is pouring out onto the floor when the spin cycle starts. not leaking when in wash cycle
You may have a pump that's bad. When it goes into spin cycle it assumes the water will be drained within a period of time before it goes into high speed spin. If it goes into high speed spin and the pump hasn't done it's job then you will get a bad mess, flood, water all over.
Rich
Western Appliance Repair
Appliance Repair Meridian
Oct 09, 2010 | Kenmore 9380x Top Load Stacked Washer /...
Keeps flashing SE
I recently had this happen but with no error message on my model, the rinse symbol just kept flashing and nothing was happening. I tried running a spin cycle or rinse and spin. The rinse & spin started but stopped when it got to spin. I finally determined that the water was not draining out. I ended up emptying a bucket and a half of water out of the emergency valve near the floor (which spills water everywhere) and found a lint ball that was plugging it. After this I tried running just a spin cycle and it worked.
Mar 30, 2009 | Samsung Washing Machines
Water level high when spin/drain cycle begins.
The water level is higher when in the rinse mode; but it should never leak. Examine the interior through the rear, there should be a loose hose somewhere. Or at the filter area. Plug off the mains caution.
Feb 28, 2009 | Kenmore 22932 Top Load Washer
GWL11 Machine adds water during spin cycle and leaks on floor
diverter valve is not switching to pump the water out. instead it is resurculating back into the tub.
Oct 14, 2007 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
62 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
