Pictures and icons look squatty How do I make them look normal?
  • 121 Answers
Change your resolution. depending on whether its a widescreen or not, this can make pictures look squatty. if its widescreen, generally 1400x900 is a good resolution. on regular ones 1280x1024 is generally good. but that also depends on what size ur screen is also
Posted on Jul 30, 2009
The picture images are fat and squatty, particularly people! Can the picture be adjusted?
Search the remote for a button that says "format" or "aspect ratio" or maybe "display." You're looking for 4:3 aspect ratio. This will probably give you bars on the sides of the pic and is usually only adjustable on analog.
Apr 05, 2011 | Panasonic Viera TX-32LX70 32 in. LCD TV
All photos I take have suddenly become blurred on my vivitar Vivicam 8225
The reasons why Photos get blurry might not always be an issue with the lens. Here are a few things you should consider -
1) Check if the Battery of the Camera is fully charged. This can hugely effect the outcome of your pictures.
2) Make sure the Memory Card is not full.
3) Check for the Macro or Normal mode. To do this, simply check the top of the LCD Screen. If you find a "Flower" Icon, then the camera is set into Macro mode. To change this, press the OK/Menu button. Find the Macro menu and press up/down to make Macro Off and Normal (Mountain Icon) to On. The camera is now changed into Normal Mode and a Mountain/Pyramid icon should be there at the top of your screen.
4) Try increasing the resolution. Again press the OK/Menu button and press Right/Left until you find a "Lines" icon. Press the Down/Up arrow to choose the resolution. 8M is the highest. Press OK to confirm.
Note - Higher the resolution, better the picture quality but lesser the number of pictures you can save.
5) Check if there is a Crossed Thunder Bolt icon on the LCD screen. If you find one, the flash has been turned off. To turn it on, press the Up/Thunder Bolt. A Crossed Arrow with an A should appear. This indicates the Camera has been set to auto Flash.
Hope the images get better with these tips. You can always call Sakar International at 877-397-8200
Aug 28, 2010 | Vivitar ViviCam 8025 Digital Camera
Display is huge and squatty
Try ajusting the resoloution to a higher number. That should work.
Apr 25, 2009 | Computers & Internet
How do I see my pictures in macro mode? If shows
click on the " flower" icon on the dial wheel to select the macro mode and then shoot normally. also, do remember to return to normal mode by pressing the flower icon again... or else you might end up getting blurry images.
Feb 18, 2009 | Canon PowerShot SX10 IS Digital Camera
Can not add pictures to Kodak
To get a good start, you reformat the frame's internal memory by following the steps below: 1. Click on the "Macintosh HD" icon. 2. Click on "Applications". 3. Click on "Utilities". 4. Click on "Disk Utility". 5. "Kodak" drive should be in the list showing a white drive icon 6. Click that icon and select “Erase”. 7. Select the “MS-DOS file system (FAT16)” option and give it a volume name e.g. "Kodak". The format will begin when you click the “Erase” button below. 8. Try to copy the files to the re-formatted internal memory of the frame. 1. Click on the "Macintosh HD" icon. 2. Click on "Applications". 3. Click on "Utilities". 4. Click on "Disk Utility". 5. "Kodak" drive should be in the list showing a white drive icon 6. Click that icon and select “Erase”. 7. Select the “MS-DOS file system (FAT16)” option and give it a volume name e.g. "Kodak". The format will begin when you click the “Erase” button below. 8. Try to copy the files to the re-formatted internal memory of the frame. Forget about using any software. Once you connected your frame onto your Macintosh, it will appear as a white drive icon on the desktop. You can copy pictures “drag and drop” from iPhoto to the frame. Just make sure that the pictures you will be copying are in JPEG or EXIF format.
Feb 11, 2009 | Kodak EasyShare SV811 (8858946) Digital...
The picture on my LCD 52" 650 series TV makes everyone look short
There is an aspect ratio setting in your menu options. You will have to change the aspect ratio so you get a normal screen.
This will most likely fix your problem.
If by slight chance it doesn't, you will have to remove the back of the tv and find the manuyal adjustments for it.
All newer Tv's have the aspect ratio/picture change setting.
Jan 17, 2009 | Samsung LN52A850 52 in. LCD HDTV
Sony dp26648 tv
I would like to help you but I do not know what squatty is
Jul 28, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Easy question!
When your camera is in picture mode, press func. set, then go down to where you will see either the letter S that is in a little hill type icon, or a white hill icon, or a white staricase looking icon. 1 setting is super fine, the other is fine, and the other is normal. If you choose normal, it will give you more memory to store and your pictures won't be as good as if they were in superfine mode, which takes more space.
Mar 06, 2007 | Canon PowerShot SD630 Digital ELPH / IXUS...
Computers & Internet Logo
357 people viewed this question
David Payne
David Payne
