Question about Pride Hurricane 4 Wheel Personal Mobility Vehicle PMV
How do you remove the back wheel of a Pride Hurricane scooter
    Scholar:
  • 61 Answers
Undo the centre wheel nut and remove along with the washer, jack the rear of the scooter off the ground then slide the wheel off the axle. If it will not remove, it will need knocking off from the inside rim. Be careful not to lose the hub key (a small piece of metal that locates in a slot in the wheel and axle) as the scooter will not drive if this is missing. To remove the trye from the rim, undo the 4 bolts that hold the two wheel halves together. When refitting the wheel, be sure to apply some grease to the axle before sliding on the wheel.
Posted on Sep 17, 2010
How can I trouble & fix my scooter
hi sounds like youre circuit has shut down if your have had it in free wheel it will shut down all the lights will work take the key out put it in drive and put the key back if it has a similar circuit as a pride XL it should work...........one more thing if u leave the key turned on for 20 minutes the circuit will shut down all the lights will work take key out wait for a few minutes & put the key back in ..if this does nothing get youre batteries checked with a ..battery load tester .....good luck
Sep 05, 2015 | Pride Hurricane 4 Wheel Personal Mobility...
Shoud light red light flash behind charge indicater when switched on on hurricane
hi, is this still a issue, this is a fault ....
Regards
Rob
www.gewizrepairs.co.uk
Mar 12, 2015 | Pride Hurricane 4 Wheel Personal Mobility...
Where can i get brushes for pride hurricane in uk
I would contact pride or a service centre as if you put the wrong grade of brush in the motor you can damage the comm and motor.
The motors are not cheap.
Mar 03, 2015 | Pride Mobility Products Hurricane PMV...
Pride destiny error codes
Pride's website has a service manual for download. It will define the error codes and tell you how to fix it.
Feb 06, 2014 | Pride Hurricane 4 Wheel Personal Mobility...
I have to replace the rubber boot on the tiller is there a repair manual for that
You can call Pride Mobility 1-800-800-8586 They should be able to help you.
Good Luck
Tim
May 02, 2011 | Pride Hurricane 4 Wheel Personal Mobility...
My Pride Hurricane PMV will not go forward or backwards when I engage the trottle all I get is a click but it will not move. The battery meter shows fully charged.
Make sure that the manual brake release/freewheel lever is in the DRIVE position. The click indicates the brakes are being released but the motors are not kicking in. I hope this helps- good luck!
Nov 03, 2010 | Pride Mobility Products Hurricane PMV...
Pride hurricane batteries (2008,model)
Hi...
You'll get a little more time out of the 55ah ( like 10%)
Mar 31, 2010 | Pride Hurricane 4 Wheel Personal Mobility...
Hogh - low speed switch is incorrectly wired , but i dont know how it should be wired - Pride Hurricane scooter
Hi, I take it been taken then, do you get a error codes ?
see below
DIAGNOSTIC FLASH CODES
The diagnostic flash codes for your scooter are designed to help you perform basic troubleshooting quickly and
easily. A diagnostic flash code will flash from the status LED in the event one of the conditions listed below
develops.
NOTE: Your scooter will not run unless the flash code condition is resolved and the scooter has been
turned off, then turned back on.
Any electromechanical device occasionally requires some troubleshooting. However, most of the problems that
may arise can usually be solved with a bit of thought and common sense. Many of these problems occur because
the batteries are not fully charged or because the batteries are worn down and can no longer hold a charge.
FLASH CODE CONDITION SOLUTION
! (1) Battery charge is low. Charge batteries as soon as possible.
! ! (2)
Batteries are too low to operate the
scooter.
Charge batteries.
! ! ! (3)
The scooter’s battery voltage is too
high to operate the scooter, or the
charger is still connected to charger
port.
Unplug charger and/or turn key off, then
back on again.
! ! ! ! (4) Current limit time out.
Turn the scooter off for a few minutes,
then turn your scooter back on.
! ! ! ! ! (5)
The manual freewheel lever is in the
(forward) freewheel position.
Remove the key from the key switch,
then push the manual freewheel lever to
the (rear) drive position, and restart your
scooter.
! ! ! ! ! ! (6)
Throttle control lever not at center
position at start up.
Return the throttle control lever to center
position, turn scooter off, then back on.
! ! ! ! ! ! ! (7) Speed pot error.
Contact your authorised Pride Dealer for
assistance.
! ! ! ! ! ! ! ! (8) Motor volts error.
assistance.
! ! ! ! ! ! ! ! ! (9) Other internal errors.
Regards
GeWiz.
Oct 20, 2009 | Pride Hurricane 4 Wheel Personal Mobility...
Pride hurricane pmv just replaced batteries everything was fine went up and down the driveway (flat surface) and it stopped working
Are any of the lights coming on? If so, are any flashing, and if so, how many times or is it constant? Check to make sure the freewheel lever is not bumped which will cause a no-go status. Put in freewheel and place firmly back in drive (located at the rear of the scooter).
Go back in and make sure all of the snap connections are tight. Undo them and redo them, don't rely on a visual inspection. Check the circuit breaker; push it in to reset. If it has tripped, you will feel a click when you push. Check all the fuses.
Jun 25, 2009 | Pride Hurricane 4 Wheel Personal Mobility...
Pride Hurricane 4 Wheel Personal Mobility Vehicle PMV  Logo
438 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
