Question about Panasonic KV-S3065CL Path-Through Scanner
Scanner No Paper Detected Error
I have a Panasonic KV-S3065CL scanner that keeps giving a no paper detected error when there is paper in the document feeder. I have replaced the sensor and cleaned, but nothing else.
    Problem Solver:
  • 16 Answers
There is a narrow FFC cable that connects the sensors between the hoppper assembly and the main scanner unit that may be loose. Check both ends. This cable can also develop small fractures over time. These fractures can cause the sensors to not be noticed by the scanner or give false info. The cable may need to be replaced.
Posted on Sep 08, 2009
System error occurred! Please consult with a service representative.
That's indicates a double feed error from the ultra sonic sensor. The system has a transmitter on the top and a receiver on the bottom. When paper passes between them it can tell how many surfaces are present. If more than 2 (upper and lower surfaces) it will alert that a double feed has been detected. They are located just behind the brake roller on the bottom and behind the feed roller on the upper side. The look like a round white ceramic disc about 3/8 " in size and are mounted at an angle to the document path. Use air or a brush to make sure nothing like a hole punch or scrap of paper is blocking them. There are adjustments for them but you need the diagnostic utility software to so it.
Dec 14, 2011 | Panasonic KV-S3065CL Path-Through Scanner
Our panasonic scanner has a error message that states " place paper in feeder" There is paper in the scanner to be scanned. How do we get rid of this error???
This error occur for some reason, please check each one:
1; ADF document feeder is not closed really and
2; You are put the documents into a wrong place
3; the sensor of the ADR is wrong or is dirty (in this case you need a mechanic)
Please read carefully the ducument below (be care of page 23)
http://office.manualsonline.com/regman/exit/ct?url=aHR0cDovL3NlcnZpY2UudXMucGFuYXNvbmljLmNvbS9PUEVSTUFOUERGL0tWUzEwMjVDLlBERg,,&target=productDoc&idDeviceType=2727&idMfg=1569&idProduct=191533
Rgd,
Sly
Nov 22, 2010 | Panasonic KV-S1025C
Unreadable message error
That is a driver problem. You need to install the correct drivers for your operating system. Visit the Panasonic download page for the correct drivers.
Regards,
MyEfact
Jun 30, 2010 | Panasonic KV-S3065CL Path-Through Scanner
How do I turn off the beep it makes when it finishes scanning?
I donno how to control through software, but by removing the buzzer, you can cut the sound!
Scanners give a beep and they have been designed to communicate even when the operator is not around. Beeps are different for different conditions, from paper Jam to Error to Job finished. Quite an effort goes in designing the beeps, be it microwave or washing machine or Telephone handset. Lets respect the design effort and leave it as it is.
S. Mohan
Jun 05, 2009 | Panasonic KV-S3065CL Path-Through Scanner
I have a fujitsu 4120 scanner that will not pull the paper even after i changed the roller and pad.
Does the scanner displays any error message on the scanner panel? Is there any TWAIN error message?
If paper jam occurs, U1 error will be displayed on the scanner panel and TWAIN driver will display " Paper jam the ADF (Code DS32002)" error message.
This error is detected when one of the followings occurs:
1) A document does not reach the TOP sensor while the scanner has transported the document about 250 mm to pick. (The scanner
performs retry operation.)
2) The trailing edge of a document does not reach the TOP sensor after the scanner transports the document by the length (L) below. (The document may have slipped on the rollers) Scan condition Transported length.
In order to assist you with your scanner issue, Please provide the issue details with error message.
If nothing is being displayed, then the issue could be due to failure in Pick Motor function or Pick Sensor malfunction.
Hope the above information is helpful.
Thank you for contacting FixYa.
Regards,
TechSatya
Apr 24, 2009 | Fujitsu fi-4120C Path-Through Scanner
Paper jam
Is this happening regularly? Clean the rollers with Isopropyl alcohol. Dont use solvents. Everyday wipe with a damp cloth before starting scanning. Check if the paper thickness is standard and is not sticky.
S. Mohan, india
Feb 25, 2009 | Panasonic KV-S3065CL Path-Through Scanner
Red Light
This scanner has a paper detection sensor at the eject rollers where the paper comes out. Its a reflective device that can be fooled by paper dust buildup. Look in the gap where the paper is fed out, in the center you will find a little reflective patch facing up. Use a blower bulb or GENTLE puff of canned air, followed by a damp q-tip. There are similar sensors in the vertical transport that can give the same error. Don't overdo the canned air. It doesn't remove dust so much as just re-arrange it, usually to somewhere harder to reach. I don't keep it in my toolbox, and I do this for a living. Blower bulbs are much easier to control.
Jul 04, 2008 | Panasonic KV S2026C Path-Through Scanner
Deleting Blank sides of paper
The KV-S3065C scanner driver has features to help with this:
  • Image enhancement - Hole Removal
  • Blank Page Detection (and removal)
Of course, the software you are using will determine how/if you have access to these features. The Hole Removal is great, but it really looks for perfect round holes. Blank Page detection is also great; it may take a little tweaking, to get the results you are looking for, but once set it save a lot of time.
Make sure you have the latest drivers: http://panasonic.co.jp/pcc/products/en/scanner/downl_e.htm
Jan 16, 2008 | Panasonic KV-S3065CL Path-Through Scanner
Panasonic KV-S3065CL Path-Through Scanner Logo
1,035 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
