Back to:
Tags:
JVC HR-J461MS VHS VCR
JVC video recorder - replacing rubber band
posted by success10 on Nov 24, 2007
i need to replace the rubber band
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Nov 24, 2007
Inappropriate (40)
diazphi
Rank:Wiz Wiz
Rating: 80%, 210 votes
Not spinning disc
If it spins with a little help from yourself replace the spindle motor with improved motor, part number: RXQ0749A
Unable to detect discs
The laser head was the culprit. Replacing it fixed the problem. (Laser head code GRP6278A)
Dew indicator is on permanently. Cannot play or record tapes. No dew present - caused by internal fault
This Camcorder uses very fragile flexible circuits to interconnect the PCB's. They plug in to edge connectors. It seems that when they made these camcorders at the factory, they had as many problems getting these film flexy circuits back into the connectors as us service engineers have. I saw one unit that had a crease in the flexy circuit which had caused a hair-line fracture. Solution, trace the wiring and solder a sub-miniature wire across the broken track. Don't disturb any flexy connectors that you don't need to. This camcorder is a bitch to work on
Not loading properly
Usually due to incorrect head alignment or dirty head, or failure of LM324 op-amp
Doesn't record properly, ie: looks like one channel is down when recorded, pre-recorded tapes are ok
Check Q008 for dry joints
Rating Locked! (?) success10 has rated this solution as Inappropriate
Thank You!
Was the solution helpful?
Show your appreciation by commenting on JVC video recorder - replacing rubber band:
I don't want to Accept this solution
Can you Help with these VCRs problems?
VCRs
What is mdel code for VCR EWV404?
VCRs
A red light in key shape apear at my RCA VCR. I cannot use...
VCRs
Trying to engage VCR to TV [Audio logic P1430] without...
VCRs
I have a hitachi video recorder vt-rm800ev and i need a...
Not JVC, but a Sharp VC A5240. Had tried to rewind before...
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
