Question about Garden
Pioneer chain saw mo# p411 starter pull rope does not retract spring came off post and was repositioned how do I ''pretension''
    President:
  • 2,220 Answers
The spool on my Pioneer FarmSaw says 2½ turns clockwise. Remove pull handle, place cord in notch, now it be pretensioned. Feed cord back through cover and reistall handle. Lou
Posted on Sep 02, 2009
Testimonial: "Thanks Dontbother10 worked just fine!"
  • dontbother10
    dontbother10 Sep 04, 2009
    now it can be pretensioned.
    If you get lucky you may be able to pull the cord until the spool rotates enough to pretension, then raise the spool enough to rewind the excess cord onto the spool. There are a lot pieces to complicate this.
How do you rewind the starter spring / cordand wheel back into the saw housing?
wind the spring in your hand to a size that will fit back in the housing then fit it. then fit the pulley back making sure the spring fits in the slot for it.
you should then botl the pulley back in place.
to tention spring you shuld notice a notch in the pulley that is for the rope to sit in while you turn the pulley to re tention it
Apr 03, 2010 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Drum clutch on a chain saw
Recoil Spring Rewind
I invert and secure the housing and rewind the spring large coil to small (need eye protection, both hands and no women around work area!). I'm right handed so I tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely inserted. Then bend slightly the inner most part to engage the starter spool. It will require about 2 turns of pretension for it to retract properly.
If you're lucky you can pull the cord out enough for a pretension then slightly raise and add the withdrawn cord to the spool. HTH
Lou
Oct 29, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Installing recoil spring for Poulin P3314
Lou
Oct 17, 2009 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Poulan model p3314 recoil spring won't go in correctly
You need to pretension it. Remove the pull handle, rotate the spool about 2 revolutions against the spring, rethread the cord and reinstall the handle.
Lou
Sep 04, 2009 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Starter rope will not retract.
inside the rope pull housing is a flat spring,it may have come loose from its anchor, its an easy fix...unscrew the 3 screws on housing, lift off housing, and the rope pull is inside the casing, you will then see if its broken, or just come off anchor, 10 minute job if its just loose......
Jul 21, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Recoil spring on homelite chain saw doesn't retract pull rope
Easy suggestion would be to get new spring coil. Is it older saw? Have had to change mine on poulan saws before.
Jul 04, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
My recoil inside the pullstart
I invert and secure the housing and rewind the spring large coil to small (need eye protection, both hands and no women around work area!). I'm right handed so i tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely inserted. Then bend slightly the inner most part to engage the starter spool. It will require about 2 turns of pretension to retract properly.
Both methods require about 2 turns of pretension to rewind the cord when pulled.
Jun 08, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Broken recoil spring
A new spring comes wound tight enough to be dropped into place in the starter housing (Easiest).
Lou
Mar 21, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Pull cord on chain saw will not retract.
Most of the rancher models are easy to look at. Take the four screws off that hold the starter cover on.When off have a look to see if the pulley is ok or one of the starter dogs(pawls) is jamed . If dogs ok take the screw out of the centre of pulley and remove it ,check for spring tension. if there is just be carful to leave sring in housing. look at spring if broken or out of shape renew it and rope.check for cracks in pulley. When renewing spring and rope get correct rope length and diameter. don't over tension new spring. hop this helps
Jan 02, 2009 | Husqvarna Chain Saw 20" Bar
Poulan Wild Thing 18 Inch replace starter spring?
I invert and secure the starter housing and rewind the spring large coil to small (need eye protection, both hands and no women around work area!). I'm right handed so I tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely inserted. Then bend slightly the inner most part to engage the starter spool. It will require about 2 turns of pretension to retract properly.
Lou
Oct 09, 2008 | Poulan 1630 16" Chain Saw
Garden Logo
262 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
