Question about GoVideo TA2050 20 in. EDTV-Ready LCD Television
My remote wont work, how do I fix it? - GoVideo TA2050 20 in. EDTV-Ready LCD Television
  • 979 Answers
Re: My remote wont work, how do I fix it?
Has it been dropped or stepped on or is it just the batteries? Maybe liquid has gotten inside. Anyway, do have the gumption to open it up and operate on it? If so, reply and I'll see what we might could do....accordianman
Posted on Nov 26, 2007
0 characters
3 Points
Vue television
Try new batteries. If that does not fix then replace the remote.
Jan 06, 2014 | Flat Panel Televisions
My remote wont work rca 40 inch lcd
Check the remote by looking through a digital camera at the remotes light while pressing the remote buttons if you see the light then the remotes working and you most likely need to replace the IR sensor. You can get the remote and the IR sensor from
Nov 09, 2012 | RCA Flat Panel Televisions
Philips has a universal remote. I have used this one and it will amaze you at how many options this remote will work. The remote number for the Philips remote is near the price bar code. Find SRP1003/27 or SRP2003/27. These are some of the best remotes for any flatscreen TVs. Thanks for asking me!
Feb 19, 2012 | Sylvania LD320SSX LCD TV
Remote control wont work
For the fix that has save many a hairs being pulled out go to control wont work.html
Dec 09, 2011 | Sharp LC-19SB25U 19 in. LCD HDTV
The remote wont work on the t.v, i have tried other remotes and used the same remote on my other vizio and it work on the other, what is wrong with the t.v and how nuch does it cost to fix?
This could be as easy as unpluging tv for 5 mins and replunging it in or it could be a remote sensor. the sensor is less then $20.00 and the labor should be a service call. ask who ever you call ,what the charges are for a service call
Apr 15, 2010 | Vizio VO420E 42 in. LCD TV
My tv wont shut off using the 551 remote
I have to shut off the box by touching the sat button ,then touch the TV button. This apparently is the fix. It works great.
Jan 09, 2010 | Flat Panel Televisions
Remote wont work
You need to have that serviced,it sounds like the IR (infrared) reciever board is faulty. you can test your remote by turning the top of the remote (where the IR beam is sent from) to a camera phone and just look at the beam through your phone to see if its the remote or the IR Board
Apr 18, 2009 | Philips 32PF5531D 32 in. LCD Television
Replace the new battery and then check it...
If its not work means u want to replace the remote..
Dec 31, 2008 | Philips Magnavox 42MF521D/37 Television
GoVideo TA2050 20 in. EDTV-Ready LCD Television Logo
63 people viewed this question
Top GoVideo Flat Panel Televisions Experts
Are you a GoVideo Flat Panel Television Expert? Answer questions, earn points and help others
